Cool over the fireplace TV swing/pull down wall mount.
Tony M
Tony M Posts: 11,017
  • Jstas
    Jstas Posts: 14,712
    Heat kills electronics.
    Worst place to put a TV.
    Hard pass.
    Expert Moron Extraordinaire
    pitdogg2 Posts: 24,582
    edited August 2018
    Jstas wrote: »
    Hard pass.
    as well as that little bit of soot that likes to creep up the mantel
    I never understood the attraction to hanging a TV over a fireplace. Yet EVERYONE I know with a fireplace has their TV mounted over it. When there is always at least 2 better walls to run their stuff on. CRAZY I tell you...
    I don't believe many people light fires in their fireplaces when they have a TV mounted over it. But...
    I think I've seen a pic. on the web a long time ago where somebody did light a fire and melted the bottom half of their TV. Maybe their flue damper was 3/4 shut. :s
    I have a friend who has his TV over his fireplace now. That's where he wanted to put it. But while I've been over there a couple of times, I didn't like looking up that high. I never have, having a bad neck that starts to tense up when I look up for more than a few minutes.
    I also think there's a lot of other reasons to have a pull down and out TV mount than just for over fireplaces. But the ad said fireplace and I thought about my friends living room. I asked my friend about the height placement and he said he likes the TV up there a lot. To each their own, for sure. ;)
  • Dabutcher
    Dabutcher Posts: 2,591
    They do look really nice up there. But I never knew the logic? I would think it would f it up one way or another? Peace. D
    F1nut Posts: 49,804
    I hide my TV over the fireplace behind a Rembrandt.
    Viking64 Posts: 6,692
    A Monoprice wall mount will probably burst into flames whether you light a fire in the fireplace or not.
  • westmassguy
    westmassguy Posts: 6,850
    I've never understood why people mount their TVs so high. The centerline of the screen should be as close to eye level as possible, from your viewing position. Mounting it high up the wall, is like arriving late to the movie theater, and the only seats left are in the front row.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Willow
    Willow Posts: 10,877
    Two focal points on one wall...bad idea on top of what has already been said.
    That has been my goal with all the TV's I've ever owned. Sometimes, my TV will be a little bit high, but not a lot.
    Remember when TVs came in all those floor consoles? I had a cool SONY XBR one. I didn't even have a complaint about looking down toward it. I had it for years too.
  • OleBoot
    OleBoot Posts: 2,127
    I have my TV in the fireplace and the Rembrandt above it. Although, it's not really a Rembrandt, it's more of Vermeer. Oh OK, it's a Brueghel. Brueghel did paint oriental women with blue faces and big, ermm those things, didn't he? The TV is a little burnt out.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Those brackets seem like a cool idea, but I've put up a few and have never been impressed. They look silly in the down position.
  • mdaudioguy
    A lot of new homes are being built such that the only place is above the fireplace. And, the builders pre-wire for it, with an outlet and HDMI/cable jack. I don't get it.
  • afterburnt
    afterburnt Posts: 7,892
    Me too, do you have the one with the eyes that follow you?
  • jeremymarcinko
    mdaudioguy wrote: »
    I think it’s okay as long as there is another place to watch movies and games.
  • mantis
    mantis Posts: 17,057
    edited August 2018
    I have done a mount called Perfect Vision. It's like this one. It has a motorized arm that moves the TV out and then down for good viewing. Then goes back up when you turn the TV off.
    As a Professional Installer I always try to detour a client from mounting their TV over a fireplace. When thats where they want it I explain all the negative things that come with it and if they still want it there then so be it.
    I would never place my Tv over a fireplace as I find it to be to high and risk of damage from heat. I also think it looks stupid as a nice piece of ART should be there instead.
    One solution Samsung came up with is the ART TV. But it sucks as a Tv and really cool as a ART Frame with Digital images. They can look very good and almost like the real thing. For a room that is more into looks then watching TV this is the perfect cheaper alternative to lets say Vision art. They are amazingly expensive but look incredible when done right. If money is no object this is the way to go. BUT the Samsung does have 1 huge advantage , you can change the Art at will and right from your phone app.
    Dan
  • verb
    verb Posts: 10,176
    I had a TV and center channel above the fireplace at the old house. A Polk CS245i center channel sat on the mantel. The heat eventually caused the vinyl veneer on the face to delaminate and shrink, exposing the MDF. Rookie mistake. The new house has artwork above the fireplace. Still have the speaker though, and pondering how to fix it.
    Good luck with it Dave. ;)
  • verb
    verb Posts: 10,176
    Thanks Tony. I used that as an opportunity to upgrade, I now have a CS400i in the basement TV setup! :smile:
    The 245 may wind up in the garage setup, when I eventually get to it.
    NICE! Doesn't get much better than the CS400i does it.
    I've heard one or two, but never owned one.
