The Tale Of 3 Tweeters
1246
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Thanks Ken, but my questions about the RTA 8TL were not addressed. Specifically:
    1. Why did the RTA 8TL become a "TL" speaker with the SL2500 (rather than SL3000) tweeter, while the Monitor II series speakers with the SL2500 tweeter did not carry the "TL" designation.
    2. Why was the SL2500 used in the RTA 8TL, whereas all other "TL" speakers in the RTA and SDA series used the SL3000?
    F1nut Posts: 51,927
    You really are delusional.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    I've sent this thread to Stu...
  • DarqueKnight
    edited July 2018
    Viking64 wrote: »
    I've brought this point up before regarding the information in the TL brochure saying that the drivers were also tri-laminate and I was told that it was a marketing error or something like that. And that it was only the tweeters that were tri-laminate.
    Stu Lumsden just posted in another thread, so maybe he can clear this up. :)
    I have marketing brochures from 1985 to 1990 that mention Tri-Laminate drivers. That's a long time to publish a "marketing error". Further, the drivers are tri-laminate: paper cones with two different polymer layers.
    I think whoever you spoke to meant that the "TL" designation in a speaker's name only referred to the Tri-Laminate tweeter.
    I still have the eight SL3000 tweeters I took out of my SDA SRS 1.2TLs. I'll pop three of them into my LSiM 705s and LSiM 706 to see how they sound.
    Would that make them 705tl's ? :)
    pitdogg2 Posts: 27,206
    edited July 2018
    a tri-laminate ring radiator silly..... no cap needed just toss it in the hole :p
  • DarqueKnight
    edited July 2018
    tonyb wrote: »
    Of course. Absolutely. Plus, "705TL" sounds way cooler.
    xschop Posts: 5,331
    Hmmm.....I know a set of Bose 901's that could use a good TL'ing.
    Toolfan66 Posts: 18,149
    SoundMann1 wrote: »
    Key words,
    the best thing to do would be to slightly modify the crossover to fit the tweeter to whatever speaker you are updating
    Just accept the fact that I have totally OWNED you on every level!
    I first clicked on this thread thinking there might be a pic of something fun to dance with......I was wrong. :)
    mhardy6647 Posts: 35,190
    heiney9 wrote: »
    I put the TL tweeters in my car, replacing the factory tweets.
    I now have a VW GTi-TL..............vroooom, vroooom
    I thought Mazdas went vroom, vroom. ;)
    heiney9 Posts: 25,492
    heiney9 wrote: »
    That's Zooom, Zooom for Mazda.
    nooshinjohn Posts: 25,973
    DK doesn't do humor often, but when he does, it is priceless. :p
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    tonyb wrote: »
    I can't offer anything fun to dance with, but I can offer something fun to listen to. All this talk of TL tweeters got me to thinking of ways I could repurpose the SL3000 TL tweeters taken out of my SDA SRS 1.2TLs. One pair of SL3000s is going in my Polk Ultrafocus 8000 headphones.
    I am excited about finishing my Ultra Focus 8000TL headphones. Preliminary listening trials have been most gratifying and encouraging. The improvement in high frequency detail and clarity have been borderline magical.
    How did you come up with the name Ultrafocus 8000? Clearly in your photo there's a a pair of SL3000's, but that only adds up to 6000. Are you installing a SL2000 as a center channel?
    SDA SRS 2.3TL's
    SDA 2B TL's
    txcoastal1 Posts: 13,518
    ZLTFUL wrote: »
    tonyb wrote: »
    8000 was an arbitrary number that was created by the sub committee to the sub committee on committee sub arbitrarily coming up with designations committee.
    I thought it was determined by the fraternity of the TRI-LAM's
    Those dudes are sketchy Ron... :D:D
    heiney9 wrote: »
    heiney9 wrote: »
    Vroom, Zoom, Schmoom.
    hmmm -- maybe I was thinking of Voom.
    fraternity of the TRI-LAM's...….LMFAO !!!!!
  • DarqueKnight
    Ultrafocus 8000 is the original name of the headphones.
    ZLTFUL wrote: »
    No. No. No. The correct way to name re-tweetered TL speakers is to use the original name, but add "TL" at the end. If you start with a completely new speaker name, the marketplace won't know that it is an improved version of an already great speaker.
    To my knowledge, this is the first ever high performance modification on a pair of Polk headphones. I should get a reward or award of some kind.
    F1nut Posts: 51,927
    Ray, be sure to stuff some carpet padding in them.
  • pkquat
    pkquat Posts: 748
    edited July 2018
    And I thought you were smart (see I didn't use that word), you did it ALL WRONG. You need to replace the foam around the tweeters with the head phone covers because the foam has aged and needs to be replaced. Good foam would have been too expensive. Headphone padding is the best because ITS DESIGNED FOR THE EARS. Tweeters HAVE to be used in a speaker enclosure. They need the volume of the cabinet space to sound good. Using the padding will give the tweeters Ultra Focus, resulting in superb imaging and clarity, you will be able to see the sound better.
    As a bonus the padding also blocks the light from reflecting off the domes. While I think the tweeters look cool, at night they remind me of the movie Alien and sometimes alien eyes, and gives me nightmares. They should not be used in home theater applications for this reason.
    As for the headphones, cut the end of a SOLO cup, and yes it MUST be a SOLO, its been tested as the only one that works. Divide the SPL of the headphones by 8. This is the length in mm you need from the bottom. Get the hard plastic red straw from a slushie or a good malt shop. Cut of an 8mm long piece. Poke a hole in the bottom of the cup to fit the straw and seal it up. This will dramatically amplify and improve all the sounds buy tunneling the sound right to your ear and we all know how putting a cup to a wall amplifies the sound on the other side of the wall.
    There is no need for electronic sound cancelling either. The electronics modify and destroy the original sound. Wrap the outside in a good thick shag carpet with fine fibers and a mixed knit to block out the widest range of frequencies. It must cover the entire outside to be effective. Carpeted rooms are MUCH quieter than hard wood floors.
    Do NOT use carpet padding in headphone applications. According to the state of California, carpet padding contains toxic chemicals, which when in contact with the skin can cause irritation, and nervous system damage, along with other harmful effects.
    :D
    edited July 2018
    Coming soon, Ultrafocus 8000 Headphone Brackets, specially designed for the user in mind, because your RDO/SL Tweeters deserve the very best...
    Also coming later in the year, the one everybody has been waiting for, The highly anticipated MW Bracket that mounts directly to the top of your head using your favorite MW Driver from Polk, it will work in conjunction with the very popular Ultrafocus 8000 Headphones. Each bracket will come with a clip for the 5.8uf capacitor from Sonicap if the user decides to take these to the next level for the TL version (I highly recommend this mod)..
    We are also working on the very first clip on Dreadnought, details coming soon..
    Be prepared to shock your friends and family...
    Toolfan66 wrote: »
    No mention of Alexa? I am shocked. Shocked.
    Toolfan66 wrote: »
    I’m not able to share more than I already have!!
    Toolfan66 wrote: »
    Toolfan66 wrote: »
    Say no more.
    We'd hate to lose you.
    This conversation never happened.
  • pkquat
    pkquat Posts: 748
    Toolfan66 wrote: »
    I wasn't aware Polk was making a Mind Woofer. Please tell me more. Does this cancel the sound from the headphones make them SDA or is it like a Sub Woofer for your brain?
    Finally! Please tell me it will be a DreadnoughtTL using the voice coils from SL3000's.
