Monitor 5/5A Upgrade worth it?
2
    F1nut Posts: 51,930
    SoundMann1 wrote: »
    Still waiting for you to name those production speakers that use carpet padding.
    You will be waiting an awfully long time!
    Yep, because they don't exist.
    nooshinjohn Posts: 25,974
    Do you think roofing material makes excellent material for vibration control too?
    mhardy6647 Posts: 35,191
    C'mon Doc, you know those are the best tweeters. ;)
    Nothin' wrong that a little carpet padding wouldn't cure :|
    F1nut Posts: 51,930
    edited July 2018
    SoundMann1 wrote: »
    Those who are bothered by the audible cabinet colorations of this particular model, and are looking for an easy fix should try replacing the poly-fiber batting with a product called rock wool.
    Install a length-wise sheet(s) running from the top of the cabinet to the bottom of the mid-woofers frame.
    You will need to experiment to see how many it will need.
    It may or may not sufficiently fix it.
    Being an inventor, engineer and presumably using the rock wool in your Monitor 5's one would think you'd be able to tell others exactly how much and whether or not it works because your last sentence leaves much doubt.
    BTW, what happened to your highly recommended carpet padding?
  • Unknown
    edited July 2018
    And drywall and duct tape make great cabinets.... >:)
    SoundMann1 wrote: »
    Mocking me will get you nowhere!
    You are correct. My apologies.... you make a mockery of yourself without requiring any assistance.
    F1nut Posts: 51,930
    edited July 2018
    SoundMann1 wrote: »
    Assumptions have a way of leading one astray! I used fiberglass in mine, but DO NOT try this yourselves!
    Industrial carpet pad + rubber cement is for constraint-layer damping!
    So, you used neither rock wool or carpet padding, yet recommended both. Ummmm......you're not doing your credibility any favors. In fact, I'd have to say you have none.
  • motorhead43026
    motorhead43026 Posts: 4,023
    Rockwool is a very good medium for growing pot hydroponically.
    – Kevin Alfred Strom
    And woven hemp can be used to make speaker cones, cabinets and damping material. Smoking the leftovers will convince you they actually sound good. :p
  • Unknown
    edited July 2018
    F1nut Posts: 51,930
    Allow me to clue you in, no one here is taking you seriously, but we do find you amusing......sort of.
    SoundMann1 wrote: »
    Only insecure people care what others think of them!
    If the shoe fits....
    SoundMann1 wrote: »
    Constrained layer damping, perhaps?
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited July 2018
    Actually roofing felt and rock wool have been used by British speaker designers for many years, also raw (uncombed) wool has the benefit of random fiber densities absorbing a wider range of frequencies than synthetic materials.
    The DIY magazine Speaker Builder has lots of people using different materials with success.
  • motorhead43026
    This Soundman has to be someone we know. Someone who has been banned in the past.
    Who are you , whooooooo arrrrrrrrrrrrrrre yooooooooooooou!
  • motorhead43026
    Never heard a British speaker I liked.
  • mlistens03
    mlistens03 Posts: 2,767
    edited July 2018
    I like my Missions, but they use traditional poly fill rather than the stuff you (SoundMann1) are talking about.
    True that wool felt of various kinds is useful in some enclosures; long fiber wool is a common recommendation for stuffing TQWTs, I know. Rockwool still shows up in the high sensitivity arena as a lining material.
    I don't know about small monkey coffin type enclosures, though -- especially when loaded with a PR.
  • [Deleted User]
    If you had to bury a rather large monkey would that require an ape coffin?
    don't forget orangutans.
    ... but we digress
    F1nut Posts: 51,930
    I know all about coffins.....just saying.
  • ZaPHoN
    ZaPHoN Posts: 90
    Can we please keep this on topic!
    Home Theater & Listening
    RECEIVER Yamaha HTR6180
    FRONT AMP McIntosh MC2125
    THEATER AMP EMOTIVA XPA 7
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    SURROUND LR KEF Cresta 30
    REAR Polk Monitor 5
    SUB Tannoy TS 10 Subwoofer
    NAS 20 TB Raid 3 QNAP
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
