In Wall speakers worthy of music
Removed old speakers. Cut new opening size in drywall LH side. Installed 2x4 boards above an below new opening. Sealed enclosure. Install was a snap. On to the RH side, which has to be relocated further away from the the corner.
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Should say " moved end table so my feet have room to hang over when i sleep here the next few nights" :'(
Looking good so far!!
Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
2nd speaker installed, old speaker hole patched. But, the spackling is not drying as fast as I would like. In other words, I got busted! The Mrs came home and, well you know the drill. In the end, she was happy with the new speakers, just that I need to finish the spackle job and repaint.
Oh yes the old pete the puma cartoon one lump or two ha ha ha. -
A well-conceived and fairly well-executed operation. Congrats on not getting executed yourself!2nd speaker installed, old speaker hole patched. But, the spackling is not drying as fast as I would like. In other words, I got busted! The Mrs came home and, well you know the drill. In the end, she was happy with the new speakers, just that I need to finish the spackle job and repaint.
Are those your rear surround speakers?
They are the main speakers for the living room. WAF would not allow anything else. Main purpose is for casual listening, friends over at the house, walking around the 1st floor kinda stuff. Plus I got Jesse's sub hooked up in the living room as well.
Oh ok, cool. I was just having a hard time picturing the room layout, due to how the couch was positioned. I'm sure they sound great.
Did they come with grilles? -
Yep. Low profile white grills. There is another couch on the other side of the room as well. More optimal listening position.
Yeah baby! I need some diamond encrusted gold blingy speaker grills!
Spackle operation underway! RH speaker is now in a better location from the corner.
Looking forward to hearing your thoughts on them as they get some hours on them and break in. Dual woofers, I bet those are gonna rock!
I'll be breaking em in tomorrow while spackling! And other projects (kitchen crown moldings) on the main floor!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I feel that I haven't given him a proper introduction to myself and the diabolical things that happen should I darken his doorstep.
How could Mr. Sunshine, himself, darken a doorstep?
I cant believe you did all that work and left that ratty looking speaker wire rather than get some good 10 gauge OFC cables in there...
J/K...
Looks awesome.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »I cant believe you did all that work and left that ratty looking speaker wire rather than get some good 10 gauge OFC cables in there...
J/K...
Looks awesome.
I thought about it, but since this setup is for non-critical listening, I decided to keep it. Besides the wires were all stapled in place, I couldn't use it to pull new wire through.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Aren't you a walking EMP? If anything the place would light up instantly upon your arrival.
Looks pretty
man! Better sound quality is always a good thing
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Thanks brother!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
J/K...
Looks awesome.
BTW thanks John!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Looks really good! And I am sure the sound quality has improved exponentially.
I have done many a covert operation like this, but fortunately both my wife and I travel a lot for work, and when she’s gone I have multiple nights to complete the op before she returns...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I'm sure you and the the wife are going to love them !!
Did I mention I hate sparkling?
It’s like a virus, the fallout keeps spreading! Patch is growing larger and larger to feather out to the wall. 2nd coat, now more sanding!
At least the wall speakers are operational, and they sound exquisite!
Now might not be a good time to point out that in order to match the paint, you might just have to do that entire wall....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Hehe! Already got some paint to match! The wall paint is less than a year old, so still pretty free from fading. Had to do other work in the room, got the same color/formula and it match well.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Primered!
