In Wall speakers worthy of music
2
  • verb
    verb Posts: 10,176
    Removed old speakers. Cut new opening size in drywall LH side. Installed 2x4 boards above an below new opening. Sealed enclosure. Install was a snap. On to the RH side, which has to be relocated further away from the the corner.
  • Manticore
    Manticore Posts: 408
    verb wrote: »
    Should say " moved end table so my feet have room to hang over when i sleep here the next few nights" :'(
    Looking good so far!!
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • verb
    verb Posts: 10,176
    2nd speaker installed, old speaker hole patched. But, the spackling is not drying as fast as I would like. In other words, I got busted! The Mrs came home and, well you know the drill. In the end, she was happy with the new speakers, just that I need to finish the spackle job and repaint.
    pitdogg2 Posts: 27,310
    verb wrote: »
    Manticore wrote: »
    Just explain to her that due to the leak in the wall by making the holes larger it reduces the back pressure on the dingamijig... you get the point :o:o:o
    Genius! I see another lump coming! :smile:
    Oh yes the old pete the puma cartoon one lump or two ha ha ha.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    verb wrote: »
    A well-conceived and fairly well-executed operation. Congrats on not getting executed yourself!
    Clipdat Posts: 13,100
    Are those your rear surround speakers?
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    They are the main speakers for the living room. WAF would not allow anything else. Main purpose is for casual listening, friends over at the house, walking around the 1st floor kinda stuff. Plus I got Jesse's sub hooked up in the living room as well.
    edited July 2018
    Oh ok, cool. I was just having a hard time picturing the room layout, due to how the couch was positioned. I'm sure they sound great.
    Did they come with grilles?
    Viking64 Posts: 7,627
    Clipdat wrote: »
    U no it!
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Yep. Low profile white grills. There is another couch on the other side of the room as well. More optimal listening position.
    Viking64 wrote: »
    Clipdat wrote: »
    U no it!
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    Clipdat wrote: »
    U no it!
    Yeah baby! I need some diamond encrusted gold blingy speaker grills! :smile:
  • verb
    verb Posts: 10,176
    Spackle operation underway! RH speaker is now in a better location from the corner.
    Looking forward to hearing your thoughts on them as they get some hours on them and break in. Dual woofers, I bet those are gonna rock!
  • verb
    verb Posts: 10,176
    I'll be breaking em in tomorrow while spackling! And other projects (kitchen crown moldings) on the main floor!
  • lightman1
    lightman1 Posts: 10,797
    edited July 2018
    David @verb is pooty whipped.
    As a general consensus.... Do I have the go ahead to pick on Dave?
  • lightman1
    I feel that I haven't given him a proper introduction to myself and the diabolical things that happen should I darken his doorstep.
  • FestYboy
    FestYboy Posts: 3,861
    How could Mr. Sunshine, himself, darken a doorstep? :*
    FestYboy wrote: »
    By making it brown?
    nooshinjohn Posts: 25,998
    I cant believe you did all that work and left that ratty looking speaker wire rather than get some good 10 gauge OFC cables in there... :p
    J/K...
    Looks awesome.
  • verb
    verb Posts: 10,176
    J/K...
    Looks awesome.
    I thought about it, but since this setup is for non-critical listening, I decided to keep it. Besides the wires were all stapled in place, I couldn't use it to pull new wire through.
  • verb
    verb Posts: 10,176
    lightman1 wrote: »
    Aren't you a walking EMP? If anything the place would light up instantly upon your arrival. :smile:
  • halo
    halo Posts: 5,618
    Looks pretty B) man! Better sound quality is always a good thing ;)
  • verb
    verb Posts: 10,176
    Thanks brother!
  • verb
    verb Posts: 10,176
    verb wrote: »
    J/K...
    Looks awesome.
    BTW thanks John!
  • rooftop59
    rooftop59 Posts: 8,120
    Looks really good! And I am sure the sound quality has improved exponentially.
    I have done many a covert operation like this, but fortunately both my wife and I travel a lot for work, and when she’s gone I have multiple nights to complete the op before she returns...
    Game Room 5.1.4:
    Bedroom 2.1
  • TopperDude
    TopperDude Posts: 166
    I'm sure you and the the wife are going to love them !!
  • verb
    verb Posts: 10,176
    Did I mention I hate sparkling? :smile: It’s like a virus, the fallout keeps spreading! Patch is growing larger and larger to feather out to the wall. 2nd coat, now more sanding!
    At least the wall speakers are operational, and they sound exquisite!
    Now might not be a good time to point out that in order to match the paint, you might just have to do that entire wall....
  • verb
    verb Posts: 10,176
    Hehe! Already got some paint to match! The wall paint is less than a year old, so still pretty free from fading. Had to do other work in the room, got the same color/formula and it match well.
  • verb
    verb Posts: 10,176
    Primered!
