$100 Polk SDA SRS
Just scored a set up Polk SDA SRS for $100. I may have the amp that was originally bought with them as well for $20. They couldn't tell me what the amp was because it was in storage and they will dig it out but they said it's about 50 lbs.
The SRS are a little banged up but all tweeters and drivers are functioning and not a mark on them. The scaring is limited to the wood and a few small tears in the fabric.
I'll keep ya all posted with picks.
The speaker fairy was good to me this year.
Home Theater & Listening
RECEIVER Yamaha HTR6180
FRONT AMP McIntosh MC2125
THEATER AMP EMOTIVA XPA 7
FRONT Polk SDA 1B
CENTER Polk CsiA4
SURROUND LR KEF Cresta 30
REAR Polk Monitor 5
SUB Tannoy TS 10 Subwoofer
NAS 20 TB Raid 3 QNAP
Office
AMP Luxman L210
SPEAKERS Tannoy
  • xsmi
    xsmi Posts: 1,804
    WOW! Congratulations!!
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • ZaPHoN
    ZaPHoN Posts: 90
    Now trying to figure out what I'l do with them so my first questions are:
    1. Does Polk still sell the MW6511 SDA drivers?
    2. Can the SRS crossover be vr3 modded for 1.2TL
    Assuming of course I'd be swapping out the tweeters for the RDO's as per VR3 mod.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
    F1nut Posts: 51,936
    edited July 2018
    You'd have build entirely new crossovers.
  • ZaPHoN
    ZaPHoN Posts: 90
    So I take it the inductors are not the same?
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
  • ZaPHoN
    ZaPHoN Posts: 90
    Does Polk still sell the interconnect cable? This set was missing them but for $100 I wasn't going to pass them up.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
    F1nut Posts: 51,936
    ZaPHoN wrote: »
    Without double checking I do not believe anything is the same.
    Polk sells the blade/blade cable you need.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited July 2018
    ZaPHoN wrote: »
    Polk does sell replacement MW6511 drivers, they are sonically identical, but not cosmetically identical, to the original MW6511. The new MW6511 drivers have dull gray cones whereas the original MW6511s have shiny black cones.
    However, the SDA SRS does not use the MW6511 dimensional driver. It uses the MW6503. The MW6511 and MW6503 are not interchangeable.
    ZaPHoN wrote: »
    No. The original SRS and the 1.2TL are entirely different speakers. Even the cabinets are constructed differently. The only things they have in common are the MW6503 stereo drivers and SW150 passive radiators.
    If you bought these with the idea of converting them to 1.2TLs, that is not possible.
    Only the SRS 1.2 can be converted to a SRS 1.2TL.
    ZaPHoN wrote: »
    Your prior comment about modding the SRS into a 1.2TL leads me to think that you might be considering replacing the SRS's SL2000 tweeters with RD0198 (SL3000 equivalent). You can only use the RD0194 (SL2000 equivalent) tweeter in the SRS.
    Post edited by DarqueKnight on
  • ZaPHoN
    ZaPHoN Posts: 90
    SRS it is then but I'm thinking of doing the VR3 Monastery mod with related tweeters.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
    Toolfan66 Posts: 18,149
    Can you post pictures of the front of your speakers, as well as the crossovers?
  • ZaPHoN
    ZaPHoN Posts: 90
    Picks coming.
    How do the fabric covered panels come off so I can recover then (Couple small holes in the sides) and what type of wood is the top and sides? I have to shave down one side a bit and try and match up a veneer because there is a gouge on it. Front fabric is surprisingly in decent shape but planning on replacing fabric anyway because the edges of the grill frame seem to be creased into the fabric,
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
  • ZaPHoN
    ZaPHoN Posts: 90
    weekend. Working my but off with clients right now.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
  • ZaPHoN
    ZaPHoN Posts: 90
    edited July 2018
    Here they are. I also have a McIntosh MC2125 coming from the same previous owner for $20. All together with nine hours of driving ($150 Gas) $100 for the SDA SRS and $20 for the McIntosh I'm a happy camper.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
  • vmaxer
    vmaxer Posts: 5,120
    Great deal.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Yep, that is a steal of a deal..
  • ZaPHoN
    ZaPHoN Posts: 90
    Only down side is I have to make an interconnect cable. Blade Blade
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
  • FestYboy
    FestYboy Posts: 3,861
    I'd say you're lucky you don't have magnet shift.
    And you got a killer deal, one for the ages no doubt.
    pitdogg2 Posts: 27,215
    FestYboy wrote: »
    Yep i agree you got lucky that you didn't get a few slipped.
    That is just plain a STEAL on that gear.
  • agfrost
    agfrost Posts: 2,474
    Was going to offer up my extra b-b cable but realized I already found a new owner for it back in December...
    Enjoy those handsome beasts!
    Jay
  • skrol
    skrol Posts: 3,456
    You should be thrown in jail for stealing those.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ZaPHoN
    ZaPHoN Posts: 90
    Ok just got the McIntosh MC2125. She's rough! Face plate is bubbling and VU meters light up but don't work and they look like they overheated.
    It works though and sounds good.
    Any idea what this thing would be worth as is because I don't think I'll be putting the money into it.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
  • sbb2112
    sbb2112 Posts: 134
    OMG, send it to me. seriously, McIntosh sells new faceplates and meters. The discoloration is from the bulbs behind the meters more than likely. That amp sells on ebay for about $1000-1200 in working order. I put new meters in one of my amps and new bulbs in the other. I also bought new blue filters for the meters but haven't put those in to change the color to match the newer LED versions. There are also LED retrofit kits available.
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • sbb2112
    sbb2112 Posts: 134
    forgot to add, I have a blade/blade cable if you pay for the shipping. OEM
    Main System
    Oppo 203 Bluray
    Rythmik F15HP sub
    Mac Mini Server
    Office System
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • sbb2112
    sbb2112 Posts: 134
    and there is a NEW faceplate on ebay now for $250. McIntosh might be cheaper. I don't recall what they told me but I think it was about $100 for a new glass for my CD/DVD player that I cracked the glass on. I have it in a box now so not a high priority to buy.
    Main System
    Oppo 203 Bluray
    Rythmik F15HP sub
    Mac Mini Server
    Office System
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • MrBuhl
    MrBuhl Posts: 2,419
    That was a stunning deal. Congrats man!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • ZaPHoN
    ZaPHoN Posts: 90
    Hmm. Maybe I'll look into fixing it up then but in the end I need more power, I may take you up on that cable offer. I'll PM you.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
    F1nut Posts: 51,936
    edited July 2018
    That amp has plenty of power, it'll make the emo run for mommy.
    BTW, I hope that skinny zip cord speaker cable in your pic was just for testing purposes. If not it's time to step up your game.
  • ZaPHoN
    ZaPHoN Posts: 90
    Ya was just testing it.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
  • ZaPHoN
    ZaPHoN Posts: 90
    edited July 2018
    F1nut you're not kidding about plenty of power. I tested the amp out on my SDA 1B and was shocked. I can't even get itthe Mac to clip out the protection circuit and no distortion in the highs of the 1B's. (Not maxed but very close)
    Any fool that says these SDA's don't have enough bass doesn't know what their talking about. The magic of of their bass make it impossible to pinpoint the source. I had a friend over who swore I had a sub running so I had him unplug it and ran the receiver pure direct to prove it.
    Safe to say sbb2112 and F1nut this Mac isn't going anywhere but to a shop to get a new lease on life.
    Now to find another bigger one for the SRS and a better processor.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
