Personal Home Theater build, updated whenever
Trey should know by now that one good, long screw is better than several short, quick ones. Perhaps he needs a stud finder.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
lol!
Those are all 1' 3/4" and hitting some real lumber! :-D- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My wife tells me that 1 3/4 would not have been enough to get the job done....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Its not the size... its the quality, texture and skill set level- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
quality takes time. Any wife will tell you that. The neighborhood handiman has to pay a visit if you screw hangs up and usually while you are at work.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
One coat - still hung up on this wall, lots of corners and such- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I bet your biceps are massive from using a drill press to install drywall...
Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Be sure you use the green lid compound for the top coat. If you don't know the lightweight compound with the blue lid has styrofoam in it. It is a pia to sand and often gets pin holes. It's perfectly fine for the first few heavy coats because it drys faster since it has less water but use the green lid all purpose compound for the top.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Wife wanted the kitchen first, hang some cabinets next week
The yellow wire will be an arc fault circuit, will string plug mold across the bottom of the cabinets, will have about fifty outlets- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I'm sorry, what? Seriously 50 outlets in your kitchen??The yellow wire will be an arc fault circuit, will string plug mold across the bottom of the cabinets, will have about fifty outlets -
It's plug mold, they go along the bottom of the upper cabinets. About an outlet every 3 inches... Will be sweet and you won't see but two outlets- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ok, you have officially lost it.Political Correctness'.........defined
President of Club Polk -
mdaudioguy wrote: »
LOL Trey does nothing small time you should see his screw allowance.... -
Hey I did a similar thing in the garage. Along the bottom.
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
In my last kitchen me and Russ did this, it was great. Was very easy to plug in appliances like coffee makers and such without having cords everywhere. Wouldn't do it any other way. I also really like the clean back splash look versus having outlets every couple of feet. Only regular outlet is right next to the sink which is a GFI- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That's from the old kitchen- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Nice wire management. But what's up with the blender wire???"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
I can only imagine what it's like to live in your house.
One room has been sheetrocked for a year. Possible a couch with plastic on it.
One room is sheetrocked but the microwave is sitting on the floor.
One room is just full of inductors/caps/and wreaks of lead.
The last room has a sink and tub installed while there is only home depot bucket on the floor. The bucket at least has a delrin seat with a little dynomatting to knock down the vibrations...
Very accurate synopsis. Only thing left would be a recommendation to rotate the mattress. What a stalker lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Hahaha....that's Mr. Stalker to you good sir.
Fyi, your apples are turning and your fly is down........Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Lol, my house is definitely a construction zone for the last few years- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
edit- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Down to trimming out, then full speed ahead in the theater...errr... living room
Gorgeous tile work on the floor!
Agree very nice Trey. I bet that was a BEAR to cut and put in.
Thanks guys!
me and a Buddy came up with that about 6 years ago. This go around I just made any needed repairs and I had to redo the 1/4" of the room where the laundry room use to be...
Love the cascade countertop. I wanted to do something like that at our house when we remodel but I have a feeling I will be outvoted
