Polk Monitor Series II 5jr
redpackman
I picked up a pair of Monitor Series II (5jr's?) today. the woofers are fine, both of the SL2500 tweeters are shot. Can I use SL2000's in this speaker (I know they aren't preferred, but I can't drop another bunch of $$ for what the SL2500's cost).
Suggestions? Offers?
Yes, or the RDO-194.
Jay
Wait a second, I was just reading in another thread discussing the purchase of 194s (back ordered) to replace some 2500s and someone mentioned using 198s and the idea was shot down due to lack of TL mods meaning that the 2500 and 194 are compatible whereas the 3000 and 198 are interchangeable (TL).
SL2000-->RD0-194
SL2500 & SL3000-->RD0-198
http://forum.polkaudio.com/discussion/88802/monitor-7-series-2-tweeters
http://forum.polkaudio.com/discussion/99662/monitor-10-series-2-tweeterJay
The RD-0194-1 is also the correct replacement for the SL1000Home Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »The RD-0194-1 is also the correct replacement for the SL1000
Thanks--I always mentally leave that one off because
a) I've never seen one (SL1000) in the flesh, and
b) my understanding is that it's not quite as simple a replacement due to size difference in the mounting plate.Jay
Ok, I'll stand corrected. Thanks @agfrost
Edit: just had an epiphany! Both of my (soon to be 3) pair of 5jr+ are TL -
if they are 5jr+'s nothing to modify. the rdo-194's are plug and play. I had installed them in mine without any modifications to the cabinet.
