Basement Leak at Verb's House!
verb
verb Posts: 10,176
Well today was a little dramatic. 2 days constant rain, super high water table, and this morning I noticed a little wet spot on the carpeted floor in the basement. Schiesse!
So I started following the wetness along the baseboard. About 3 feet from the doorway in the spare bedroom.
Popped the baseboard off, lower paneling, and ugh, drywall! What a mess! This is what I found:
A little pin hole in the wall, peeing steadily! What?!
«134
  • verb
    verb Posts: 10,176
    Here is a picture of the mess I just created:
    txcoastal1 Posts: 13,519
  • verb
    verb Posts: 10,176
    Hard to tell in the above pic, but there is a steady stream flowing into the blue bucket. I put a fan next to the wet area to help drying. A little later, I hooked up a funnel with a hose near the hole to better direct the water into the bucket. Ugh!
    Viking64 Posts: 7,636
    Merde! Gardez l'eau!
  • verb
    verb Posts: 10,176
    Eventually I exposed the true size and nature of the hole. 5/8" diameter, used to hold the forms together as the concrete walls are poured. This guy was never fulled sealed, as the concrete at the pin hole easily popped off, exposing the hole.
    pitdogg2 Posts: 27,370
    That'll buff right out....
  • verb
    verb Posts: 10,176
    Off to the big box store. Got a rubber cork, with tapered diameters, and pounded that sucker in place!
    Leak immediately stopped!
  • verb
    verb Posts: 10,176
    So now I'm thinking about hydraulic pressure, building behind the cork, and eventually blasting that sucker out of the hole! So I nailed a backer board in place to hold the cork in.
  • verb
    verb Posts: 10,176
    nbrowser wrote: »
    You do know that a correct proper repair should be made from...the...sad to say...OUTSIDE!
    Yep. This is just temporary.
    Hydraulic cement dude come on
    Close the door. Turn the basement rig up loud so you can't hear the trickle. Problem solved.
  • FestYboy
    FestYboy Posts: 3,861
    Only one way to fix it properly... Capture and redirect via perfed PVC.
  • verb
    verb Posts: 10,176
    I did find these new patented plugs that are designed to seal the holes. Called TRX Plugs, they act kinda like a boat seal with a threaded fastener in the middle to increase the outside diameter. What's interesting about these is the rubber compound actually expands when exposed to water!
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    The basement rig is only about 10 feet away! Ugh! Needless to say I'm gonna keep a close eye on it.
  • MrBuhl
    MrBuhl Posts: 2,419
    That stinks to find - but at least you found it so you could limit the damage.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • verb
    verb Posts: 10,176
    edited April 2018
    This stuff expands considerably. The Mrs. reminded me of they act kinda like, uh, something else, that is what I may say, uh, gender specific? :smiley:
  • verb
    verb Posts: 10,176
    Just ordered a pack of 5 from Amazon. These things are not even available locally yet.
    In the meantime, after stopping the bleeding, I mean leaking, upstairs in my nearfield setup enjoying some Linkin Park!
    mhardy6647 Posts: 35,260
    Darth Vader himself might've said:
    Never underestimate the power of the hydrostatic pressure of water.
  • verb
    verb Posts: 10,176
    Ah yes, P(h)=rho*g*h :smile:
  • verb
    verb Posts: 10,176
    Just checked the basement again. No leaks! Celebrating.
  • charley95
    charley95 Posts: 908
    That sucks. What's the grade like outside the house? Do you have downspouts extended away from the house, gutters clean? First thing I did when I moved into my 50's ranch was build the grade up all around the foundation to run downhill away from the house. I put in pop up drains for the gutters at least 10ft. away from the house. Don't have any trees near the gutters but still clean them out several times a year from flying leaves all around. Haven't had any water issues what so ever since doing so and I have no sump pump.
  • Upstatemax
    Upstatemax Posts: 2,815
    That’s a clear indication that you might need to do some work on your water management.
    As others have mentioned about downspouts and grading.
    But you either need your French drain checked, or have one installed.
    Hydrostatic pressure on that plug is the least of your concerns. A basement wall heaving or buckling is a MUCH bigger issue.
    You need to get the water away from your foundation.
    Do you have a sump pump?
    Upstatemax wrote: »
    ...Hydrostatic pressure on that plug is the least of your concerns. A basement wall heaving or buckling is a MUCH bigger issue.
    concur, and that was my point -- water pouring through a crack or hole is indicative of a pretty serious water reservoir outside the wall -- and water is pretty uncooperative when it comes to being held at bay.
    msg Posts: 10,479
    And sell it.
    la2vegas wrote: »
    Great now patch the wall, spread some mud and paint it. Easy peasy. :D
  • verb
    verb Posts: 10,176
    Thanks to all for your comments and suggestions. My plan is to regrade further the area around the suspect wall to ensure the water drains away from the house. I did the same on the other walls last year with good results.
    Downspouts are all good, in fact they are all plumbed to an underground system that dumps the water about 100 feet from the house.
    The gutters need a bit of work. They are all in good repair, but I noticed that a few of which the grade needs to be adjusted to allow better flow. Especially at the corners, near the suspect area, where some of the water splashes over. That is also on my list this year!
    So this issue of the re-bar holes not being sealed and leaking is quite common, after further reading and talking to my colleagues at work. My plan is to use the TRX plug to permanently seal that particular hole. I probably won't re-drywall for some time, at least through spring, to ensure the fix is robust.
    Sump pump is good, operating normally too.
    Ahh, the joys of home ownership!
    Just got home today and all is good. Dry as a bone! Not to mention big points from the Mrs. for solving a problem! You know how that is, fellas! :smile:
  • verb
    verb Posts: 10,176
    la2vegas wrote: »
    Forget all that high tech mumbo jumbo. :D
    BTW @la2vegas how did you know I was of Dutch heritage? 1st generation American! Those Dutchies sure know all about water management! :smile:
  • verb
    verb Posts: 10,176
    Of my trips to Europe, visited Holland, never saw anything like this before. Makes sense when virtualy the entire country is below sea level!
  • verb
    verb Posts: 10,176
    edited April 2018
    Cool. We actually stopped for a bit and watched a few of those ships, including huge freighters travel across the overpass! Amazing!
    If I ever went to Verb's house, I would probably take a leak in his basement. Just sayin'.
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    I'm sure you will! :smile:v0jiqzdfl6s1.png
