sacrilage
“...newer aluminum coated driver that has a 40oz magnet which is more efficient than the original...”
Who knew - magnet size determines efficiency!“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
Why. Just why?Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
Wow! Buyer beware!!! All of sellers comments are far from the truth. The high gloss spray over them looks very bad too.
That guy is a tard...
I was wondering when someone else saw those. Made me laugh when I saw them.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Well with a 98.4% Positive feedback...enough said! LolDenon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
sac-ri-lege: the intentional desecration or disrespectful treatment of persons, places, things, or ideas held sacred.
"The have the sound quality on par with Snell Acoustics"
HAHAHA! -
Well, to some extent it does (sensitivity, at any rate), but the strength of the magnetic field alters other driver parameters, too.
At any rate, I am sure that they sound amazing. I have been amazed by many things -- not all of them good.
I dunno -- it's slightly less jarring to see a rewoofering compared to the gomers who put horn tweeters into Polk Monitor Series loudspeakers.
Slightly.
^ eww
I mean -- ya gotta admit -- those new woofers go with those tweeters!
did you miss this tidbit?
The 10" passive radiators have been replaced with 10" Infinity subwoofer drivers which adds an awesome amount of tremendously tight the bass! -
Whoa! I did miss that!
OK, I'm biddin', I'm biddin' -- don't you guys try to snipe me!
you can tell he is a audi file because he took out the peerless tweeters to replace with the "better" SL2000 tweeters......
oh god I'm going to be sick......RALPH..... -
Pfff, forget it then.AMAZING SOUND! UPGRADED POLK AUDIO MODEL 7 SPEAKERS!!
After upgrading all of the drivers I took a listen to these speakers and was amazed at the quality of the sound. The sound is very refined and detailed. The highs are sweet and clean while the mids and bass is natural sounding,tight,transparent and very strong. The original polk audio silk dome tweeters were replaced with Polk Audio Silver coil tweeters which are more efficent and have a more refined sound. The mid bass driver has been upgraded to newer aluminum coated driver that has a 40oz magnet which is more efficient than the original and almost three times the size of the original Polk driver. As a result the mids have a wider frequency range and much smoother than the original mids. The 10" passive radiators have been replaced with 10" Infinity subwoofer drivers which adds an awesome amount of tremendously tight the bass! The upgrades have changed the sound dynamics greatly. The have the sound quality on par with Snell Acoustics and Infinity Kappa speakers. They are simply a pair of the sweetest sounding speakers you will find under a $1000. These speakers are very well made at around 45 lbs each and were built to last.. The foam surrounds on the woofers are new so the new owner will have many years of trouble free use. Please be mindful that since I do not have the original boxes I will have to use $30 dollars just for the packing materials and boxes, I do not skimp on packing materials because I want my items to arrive undamaged to their new owners, The stands are not included in this auction,Thank you very much for looking! God bless!
With this ad, I have to wonder, are these new 10" woofers active or just there to replace the passives.did you miss this tidbit?
The 10" passive radiators have been replaced with 10" Infinity subwoofer drivers which adds an awesome amount of tremendously tight the bass!I disabled signatures. -
Yeah -- I mean, he should throw in some amazing, upgraded stands, too, right?...
The mind boggles vis-a-vis the possibilities.
One of a kind Monitor 7 cabinets......
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
Collectors' items, as John Dorsey used to say -- "and the collector comes every Tuesday morning!"
One of a kind
That's their only redeeming factor. The satisfaction of knowing there aren't any more of those out there.
It looks like he just slathered red stain all over everything, then hit it with gloss. Even the tweeter diaphragms are reddish.Home Theater/2 Channel:
dhsspeakerservice.com/
