Do I need a sub with these Usher MD2's?
afterburnt
Thinking about a PB16 Ultra
What kind of music do you listen to?
Yes."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
You name it, I listen to everything that's not new like techno, screamo etc. -
@EndersShadow these things go pretty low, how would it be beneficial to add a sub?
Sent you a test mix
afterburnt wrote: »
That was as clear as mud. I do not listen to new stuff like techno and screamo. I would like to be in a screamo band though. -
Sent you a test mix
@Clipdat thanks, I will have to figure out how to play that as I am disconnected from my PC and other portable devices except my Gorgo pad, but that's only a controller. I wouldn't know how or have any desire to steam music from it. After all it is evil. -
It might be techno though. lolafterburnt wrote: »@Clipdat thanks, I will have to figure out how to play that as I am disconnected from my PC and other portable devices except my Gorgo pad, but that's only a controller. I wouldn't know how or have any desire to steam music from it. After all it is evil.
Yes you need a sub. I love my JL in my 2 channel system. Once you have a sub, you will never go back!2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Specifications:
Dancer Mini-Two diamond
2-way system : Diamond DMD dome tweeter 1.25″ ,
mid-low woofer 7″x2 (8948A),
sensitivity: 90 dB @ 1 watt / 1m
nominal impedance: 4 ohms
frequency response (-3 dB): 28 Hz ~ 40 kHz
power handling: 100 watts
crossover frequencies: 2.7 kHz
I am running them with Dayens mono blocks, if you think I would benefit from running a sub it would have to be an itty bitty one. -
An SVS SB2000 would do the trick nicely.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
How many hours on them so far?
The Ushers? Damn near 24/7 365
My company pays my light bill in CA
Everything is rub in unless it needs 500 hours -
afterburnt wrote: »Thinking about a PB16 Ultra
txcoastal1 wrote: »Get you a pair of Rhythmic F12SE's
I think if you haven't yet, room treatments should come before a subwoofer . . .
Just this week I ordered room treatments and a Rythmik F15HP. I'll let you know how things turn out with my MD2s. I know I definitely need the treatments.Integrated Amp: Marantz PM-10
Speakers: Usher MD2
Subwoofer: Rythmik F15HP
DAC: North Star Design Supremo
Streaming Source: AURALiC Aries Mini
SACD Player: Marantz SA8004
Power Source: PS Audio PP3 on dedicated 20amp circuit -
Rythmik F15HP added with MD2s last week. I'm using high level inputs as recommended by some here, so I called Wireworld and had them make one cable for me to match the speaker cables I have. Works perfectly.
@afterburnt I'm glad I put this in my system. YMMV but for me adding a sub with the MD2s now gives me the overall sound I was looking for.
Speakers: Usher MD2
@Derf Wow I would love to hear your system, good stuff there. Why did you choose that particular sub?
I was thinking of a REL, mainly because of the high level input, but Ron @txcoastal1 said to check out Rythmik. Since Ron sold me the Ushers I figured he knows the sound signature of the speaks, so after researching, and seeing others on the forum also recommend Rythmik, I decided to go with it. Figured I'd defer to the experience of the masses, since mine is limited. I'm loving it. It gives the low end I feel was lacking. I listen at a relatively low level all evening long, and I wasn't getting much bass at low levels. Now, it's there where I wanted it. And when I do turn it up, WOW, it rocks the place. And as I have seen others say, it is as if the bass is coming from the speakers, not the direction of the sub. Highly recommend it.afterburnt wrote: »@Derf Wow I would love to hear your system, good stuff there. Why did you choose that particular sub?Integrated Amp: Marantz PM-10
Speakers: Usher MD2
@Derf, thanks man! I will have to fire up the printing press and ink up the rollers.
@Derf PM sent
I ain't got no money that I can depend on. Anyone think an SVS SB1000 will do the job when I cash in my bottles and cans?
Are you asking people to think on this site?
Shame on you. -
How bout two, or should I be looking for a big bad better ONE?
I would take 2 lesser rythmics over the one svs sb16.2 channel:
Theater:
txcoastal1 wrote: »
Speakers: Usher MD2
txcoastal1 wrote: »
HEY! Where did he write that? I don't think I can get half a pair! -
I am going to try to try an SVS SB1000. Can I just use some "decent" cables since they wont be carrying a lot of current?
afterburnt wrote: »I am going to try to try an SVS SB1000. Can I just use some "decent" cables since they wont be carrying a lot of current?
Check out the Outlet section on the SVS website. Might save a few bucks.Integrated Amp: Marantz PM-10
Speakers: Usher MD2
@Derf, I am not ready to buy it just yet but I see some cables on sale that I can get now. I am figuring that the cables can be a lower grade since they don't carry much current. I could be wrong??? -
If I've learned one thing around here it's that everything in the chain matters. I would think using a cable that is of the same quality, or has the same sound signature, as your speaker cables would be a good place to start.afterburnt wrote: »I am figuring that the cables can be a lower grade since they don't carry much current. I could be wrong???
Speakers: Usher MD2
