New 1C Purchase Questions
Last thing was to install spikes bought here:
https://meniscusaudio.com/product/mirror-image-pts-gold/
I started by removing the plastic feet on the bottom cap. Then I drilled a 7/32" hole, sprayed a little water in it, added a drop of Guerilla glue, then screwed in the stud. This anchors them in solid.
Any glue that foams creating air bubbles in it cannot make a good bond. Throw that stuff away and next time try 5 minute epoxy.
The spikes do look good.Political Correctness'.........defined
President of Club Polk -
The expansion actually allows it to penetrate the pores in the wood and fill any gaps in the studs' threads. I've used this stuff on a boat I restored and it is wicked strong. Epoxy would have been a PITA because I needed such a small amount in each hole. I may use epoxy to anchor the spike bases to the cap though. Haven't decided if that's necessary yet.
I like these spikes because you can tilt the speakers back and unscrew the points, get placement dialed in, then reinstall.Gustard X26 Pro DAC
On similar speaker bottoms I have just ran a bolt/washer through from inside the cabinet and tightened down good and tight on the same spikes. I buy mine in 1/4" x 20tpi pattern and just buy some new bolts instead of the threaded rod sent with.
Hey I noticed you put some dynamat on the brace in between the MW's. Never seen that before. Is that recommended?
I tapped along the cabinet area looking for potential resonance points and found that and in the center of the 4 drivers as questionable. May have been unnecessary but WTH. Can't hurt right???
Well finally got my crossovers back from @westmassguy and after getting them hooked up correctly... (Thanks Dave. What would we do without you) I've been running them low volume 24/7 to burn in the new components and the dreadnaught. First impressions are VERY good! I'm noticing things like the ring of piano keys sounding like the piano is in the living room with me. I know how this sounds because, up until recently, there was a piano in here. Details in strings and drums are present now. I wasn't alone during my initial audition but I actually had to turn it down on the first track of Spin Doctors - Pocket Full of Kryptonite because everyone, including myself, jumped. These put out more sound than the Klipsch KG4's I replaced them with! Hopefully this weekend I can give them a more thorough review.
What do ya have on the RH wall under cover? Looks like it could be a motorcycle? Only asking because many years ago I keep my brand new 1978 Triumph Bonneville in the kitchen.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
motorhead43026 wrote: »What do ya have on the RH wall under cover? Looks like it could be a motorcycle? Only asking because many years ago I keep my brand new 1978 Triumph Bonneville in the kitchen.
I used to keep my brand new 1978 Pontiac Bonneville in the kitchen.
My Pleasure Sir.Home Theater/2 Channel:
dhsspeakerservice.com/ -
It's a Keyston Saddle.Gustard X26 Pro DAC
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
What do ya know, I was right again. After you upgrade the 1C's think about moving to something other than Carver SS power, you'll thank me.
As arrogant as ever. Love your knowledge Jesse...You and heind end hang out often? LolToo much **** to list.... -
I too went down the Carver path. Had 2 M1.0t's, moved to a TFM35x, and with a little enabling and tutelage from Polkies here went down the rabbit hole with a Conrad Johnson MF2300A. All I can say is wow! What a difference!
And yes, @F1nut Father Jesse was right!
Post edited by verb onBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I took went down
HAHAHA That reminds me of the SCTV skit about the "Western Redundancy Playhouse Theater" where the actors say things two ways, like is common in many old westerns in an attempt to sound more "western", I suppose.
"Hey wife-woman. Git-hop into the kitchen-pantry and fix-cook-up a heaping-mess of food-vittles for that baby-child." -
I took went down
Foiled again! Got me Jimmy!
When I'm editing, I constantly see remnants of ideas and phrases that didn't quite get deleted. Trust me. You are in excellent company.
I just wanted to see if you were still out there! Yeah right.
Ya, ya, ya. Maybe I'm not playing my music loud enough... Since having my 1.0 rebuild done, there is a HUGE improvement from how it sounded prior. BUT. You rotten bastadges are making me look. Damn it! Just really hesitant to spend without doing an A/B comparison. There is an Aragon 8008BB and a Sonic Frontiers SFS80 that I have been eyeing...Gustard X26 Pro DAC
HAHAHA That reminds me of the SCTV skit..
GOD do I miss SCTV. They just don't make TV like that anymoreGustard X26 Pro DAC
Hehe. Are you gonna make @f1nut proclaim he is RIGHT once again? Lordy help us!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
That's beneath him...Gustard X26 Pro DAC
The 8008 will require a jumper wire across the negative terminals, or an isolation transformer (Dreadnaught) in the SDA cable, to overcome the 20-ohm resistance preventing "true" common-ground of the negative terminals.There is an Aragon 8008BB and a Sonic Frontiers SFS80 that I have been eyeing...
Aside from that...very recommended.
Dreadnaught... Got one!Gustard X26 Pro DAC
There is an Aragon 8008BB that I have been eyeing...
Great amps the 8008 and 4004 series made by Mondial designs. I have not heard the newer amps by Klipsch or Indy audio designs.
Mondial designs had others beside those two but they were much more expensive.
That's some seriously long reading...Gustard X26 Pro DAC
