Another speaker stand build
  • mdaudioguy
    mdaudioguy Posts: 5,164
    Because that is the recommended method. It was explained to me once in great detail by the owner of a speaker company after which I was convinced he knew what he was talking about.
    It seems counter intuitive to me.
    Hmmm, I don't know much, but my theory is that if you couple the speaker to the stand (or shelf, or whatever), any resonance created by the speaker is transferred to the other object and has an effect on the sound. Since the speaker designer has no idea what the speaker may be in contact with, they can't account for it in the design. By decoupling the speaker from the stand, you only hear the speaker. Maybe that's a bunch of bunk, but it works for me. Based on all the solutions out there, it seems like it's common to decouple bookshelf speakers from their stands, so that's the model I'm trying to follow. I guess it can't hurt to experiment, however, so maybe I'll try and evaluate both options.
  • Jstas
    Jstas Posts: 14,990
    mdaudioguy wrote: »
    Nope, that's basically it.
    It's about the transfer of energy.
    It's also why you add mass. You want your stand to be like setting the speaker on the ground. It doesn't have enough energy to vibrate the earth. But it might for a stand (hence the reason I used black pipe for mine). So you make the stand heavy/dead enough that the speaker behaves like it's sitting on the ground.
    Two ways you do that.
    One, mass. Make it big and heavy so that the speaker is incapable of vibrating it.
    Two, density. If you can't make it big and heavy, make it dense by adding damping material like sand or shot or even concrete. That will make things pack real tight in the voids and that makes all the dissimilar materials act like one big damping apparatus. It will tame the vibrations and kill any resonances because the different materials have different resonance points. Those points overlap and they cancel each other out...well more like damp each other. It's the whole idea behind Polk's Dynamic Balance tech.
    Anyway, by decoupling the speaker from the stand, you further reduce the transferred energy. Transferred energy is wasted energy and it can detract from the performance of the speaker. If the speaker moves around when playing then there is energy going into moving the speaker instead of playing sound. If the speaker is on a stand, it might not be moving around but it might be moving that stand and wasting energy moving the stand. So make it so it can't move the stand and further help it out by making it so it can't physically act on the stand because of whatever damping material you put between it and the stand.
    Expert Moron Extraordinaire
  • westmassguy
    westmassguy Posts: 6,850
    Interesting perspectives by all.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Jstas
    Jstas Posts: 14,990
    It's not a perspective, it's physics. There's actual science around it.
  • Easy Runnin
    Easy Runnin Posts: 501
    Yeah, and he slept at a Holiday Inn Express last night ;)
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • westmassguy
    Jstas wrote: »
    I wasn't questioning the science.
  • mdaudioguy
    edited March 2018
    Finished! I'm pleased with the results. 30.75" tall, and despite being constructed of wood and vinyl, they weigh in at 28.2 lbs each, thanks to a generous helping of audiophile-grade sand. :)
  • FestYboy
    FestYboy Posts: 3,861
    Loving the T screws, that's a super clean look.
    txcoastal1 Posts: 13,514
    I see you found the black paint
    They look great
  • Hermitism
    Hermitism Posts: 4,329
    Well. that's just great, now I'm going to have to write a fictional story about "Ed Stands". Thanks for ruining next weekend for me!
    Nice stands, very professional looking.
    F1nut Posts: 51,881
    Stands look good!
    I don't think that's black paint, looks similar just not true black. :p
  • monepolk
    monepolk Posts: 1,154
    Very nice job.
    Note the perfect hair
  • mdaudioguy
    Thanks guys! Still plugging away at this room. The ceiling isn't yet finished... but somehow the stands got prioritized ahead of that. ;)
  • mdaudioguy
    So much blackness.
  • verb
    verb Posts: 10,176
    Very nice!
    I too can never throw surplus parts away, as there is always a use for them. Every so often I get vindicated by not having to run to the store to pick up an esoteric fastener or something. Well done sir! :smile:
    BTW, did you paint the oak, or stain it?
  • mdaudioguy
    verb wrote: »
    Very nice!
    Thank you. Spray paint - gloss for the posts and satin for the wood. I do like how the grain shows through.
  • Hermitism
    I might have missed it in a previous post, it's been awhile since I read this thread, but what are the two holes for in the top plate of each stand? Are the speakers bolted to the top plates, similar to a "Foundation Mount"? Also, is the wall the same color as your shirt?
  • mdaudioguy
    The speakers have 8mm threaded mounting holes, and I wanted to use them, since the speakers are somewhat in the open. You know, just in case. As discussed earlier in this thread, I still wanted the speakers to remain decoupled from the stands as much as possible. Some neoprene washers and o-rings did the trick. The walls are probably in the same spectrum as my shirt, but this pillow is a closer match.
  • Hermitism
    mdaudioguy wrote: »
    When you stand against the wall I bet you look just like the killer that blended into the wall in the movie "When A Stranger Calls Back".
  • pumpkinman
    pumpkinman Posts: 10,264
    Beautiful job thanks for sharing
    Because I am The Pumpkinking
  • mlistens03
    mlistens03 Posts: 2,767
    Nice job man! I might make myself something like this if I ever get some nice bookshelves... great idea.
    Once again, good job!
  • cortico
    cortico Posts: 587
    Great job! can you please explain your paint process. I like to see the grain texture.
  • mdaudioguy
    cortico wrote: »
    Nothing special, really - unfinished oak and several light coats of Krylon satin black!
  • Mike Reeter
    Mike Reeter Posts: 4,315
    They turned out very nice, good work!
  • mlistens03
    edited March 2018
    mdaudioguy wrote: »
    satin black!
    WHERE!?!WHERE DID YOU GET IT!
  • mdaudioguy
    mlistens03 wrote: »
    mdaudioguy wrote: »
    satin black!
    If I told you, I'd have to... you know.
  • FestYboy
    Give him Eskimo kisses?
