Another speaker stand build
These will be for my Vienna Acoustics bookshelf speakers. I'm one of those people who buys something that needs assembly, and when there are extra pieces that aren't required, just can't throw those perfectly good pieces away, because, "I might need them someday!"
So, this one has been stirring around in my head for a while. I have a couple dozen extra vinyl balusters from the deck I built around 2006.wk5t0i3wevz3.jpg
They're a hair under an inch and a quarter square, so I thought 9 of them bundled together, 3x3 (about the same size as a 4x4), would make a nice post for some stands. iig38sys47sb.jpg
They can easily be filled with sand or cement. I'm initially thinking of filling 8 and leaving the center back one hollow to route the speaker cable through.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    Base and top plates will be oak, which will be stained or painted black*, and the posts will be sprayed a gloss black*. I'm thinking the base will be about 1.5" thick, while the top plate will be about 1" thick. And, of course, they'll be spiked. That's about it. It will likely be a slow project, as I want them to look nice. They should definitely be sturdy and solid. I'll post more as I progress.
  • mdaudioguy
    After looking at the 3x3 result, I decided that since I had enough material, 3x4 might be better.66o0i8ws6khi.jpg
  • mdaudioguy
  • mdaudioguy
    Top and bottom plates are cut - 1.5" thick. Post ends are plugged with 3/4" wood glued in. Corners are 4", to accommodate long bolts to fasten the top and bottom plates. Only the bottom is plugged initially, so I can add sand. Decided not to use concrete, since the posts are already very rigid.iz8zfn14ch96.jpg
  • mdaudioguy
    edited March 2018
    1" holes will be on the back, allowing speaker cables to be hidden. 11 of 12 posts will be filled with sand.1tuvm3s53fjr.jpg
  • mrbiron
    mrbiron Posts: 5,721
    What did you use to glue them together?
    Christy's PVC glue?
  • mdaudioguy
    Loctite PL Premium Polyurethane Construction Adhesive
    F1nut Posts: 52,198
    Ed, things are shaping up nicely. One question, why did you make the top plate that thick?
  • monepolk
    monepolk Posts: 1,154
    How are you attaching the wood base to the PVC?
  • mdaudioguy
    edited March 2018
    Mostly just because... 2 x 3/4" boards glued together. Thicker than most I've looked at, but I figured it couldn't hurt. They definitely look substantial and already have some weight to them even before filling with sand. Searching now for some isolation pads to go between speaker and stand. The sorbothane pads on Amazon have some reviews that seem to indicate there's the possibility of a chemical reaction on some surfaces that causes me some concern.
    Oh, and thanks!
  • delkal
    delkal Posts: 764
    mdaudioguy wrote: »
    Put a small piece of aluminum foil over the pads.
  • mdaudioguy
    delkal wrote: »
    mdaudioguy wrote: »
    The more I read about sorbothane, the less I'm interested. I'll find another solution to decouple.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    monepolk wrote: »
    I'm also curious. These are going to to be some great looking stands when completed.
    Looking forward to the finished project, good work!
  • rooftop59
    rooftop59 Posts: 8,120
    delkal wrote: »
    mdaudioguy wrote: »
    Why not just blu tack? Price is right and stereophile recommended?
    Game Room 5.1.4:
    Bedroom 2.1
  • mlistens03
    mlistens03 Posts: 2,767
    Where can I get the pvc posts? I might make myself some of these for my Boston cr75s (right now a pair of infinity tower speakers are their stands, lol)
  • Jstas
    Jstas Posts: 14,999
    Dude, I use some of this stuff on the Totem Rainmakers, works pretty well:
    https://www.target.com/p/con-tact-brand-174-grip-premium-153-non-adhesive-shelf-liner-thick-grip-black-18-x-8/-/A-14468755
    Cut it to fit. Doesn't leave stains, easy to replace if it starts to degrade too. Comes in a variety of colors, doubles up easily too.
    Expert Moron Extraordinaire
    Toolfan66 Posts: 18,310
    Love it!!! They look great!!!
  • dolbyd
    dolbyd Posts: 430
    Sweet stands.
    Makes me want a new pair of bookshelf speakers.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA7 G3, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 80J 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • mdaudioguy
    monepolk wrote: »
    Some sort of bolts or screws. The corners of each post have 4" long blocks glued in place with construction adhesive. Probably longer lag screws for the bottom, and shorter wood screws for the top.
  • mdaudioguy
    Jstas wrote: »
    I'm familiar with that stuff, but it never crossed my mind. Seems like it should do for what I want. For the price, definitely worth a shot. Thanks John!
  • mdaudioguy
    Thanks to all for the compliments and suggestions! Spikes are on the way. Hopefully I can pull off a respectable spray can paint job. All black, with the posts glossy and the wood parts satin.
  • FestYboy
    FestYboy Posts: 3,861
    And just where, pray tell, are you finding this "black paint" you speak of??
  • mdaudioguy
    Oh, I know where'n I can git some, and I ain't tellin'.
    Tony M Posts: 11,902
    unobtanium black paint. :o
  • DaveHo
    DaveHo Posts: 3,583
    You might need to use primer designed for plastic on the posts before spraying the top coat. Check top coat rattle can to see if it is rated for application to plastics. If it doesn't say, probably not.
  • westmassguy
    westmassguy Posts: 6,850
    Very nice work. I'm curious, you added mass, and plan on spiking them, per your drawing, which effectively couples them to the structure. Why then de-couple them, with sorbothane or some other isolation material?
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    F1nut Posts: 52,198
    Because that is the recommended method. It was explained to me once in great detail by the owner of a speaker company after which I was convinced he knew what he was talking about.
  • westmassguy
    It seems counter intuitive to me.
    F1nut Posts: 52,198
    Yep, I thought so too and why I consulted an expert.
