Vibration Pods Recomendations
Audio Advisor offers Vibration pods. I want to place them them under my DAC that sits on my desktop to reduce vibration from the speakers that are placed a few feet away. AA has about 6 different types, looking for recommendations from someone using them.
    pitdogg2 Posts: 24,576
    pangea sorbathane
    gudnoyez Posts: 8,066
    edited February 2018
    I saw those they have adhesive backing and some clear disc that goes underneath only you adhere them to the sides of the stock feet, while others you place under the feet. If you have them do they still look presentable underneath with the stock feet just hanging there? I had the tunes pretty loud the other night and started worrying about the DAC subcoming to excessive vibration.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Steve, I am going to text you some pictures and post them up here with what I use with my Shciit Sys.
    They are the 1/2" Sorbothane hemispheres and I got them off Amazon. I also have them on a couple of CD players, my Peachtree DACiT and have the HUGE ones for my turntable.
    They are dirt cheap on Amazon and great.
    They are available in a HUGE array of sizes...
    https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias=aps&field-keywords=Sorbothane+feet
    I do not know about adhesive sorbothane is sticky by nature. the disc is to keep them from sticking to furniture or shelving. I've used Audioquest sorbothane for years big believer in its ability to stop vibration. it will always be under any CD/SACD player i ever have. I will buy the pangea the next time its cheaper and works the same way. The feet from pangea I seen at RMAF had no adhesive what so ever. I in most cases do not put them under the feet I will put them beside if possible
    F1nut Posts: 49,799
    Sorbothane is extremely effective at preventing vibrations transfering from the surface your gear sits on, but do not let it come in direct contact with any finished furniture surface as it will leave a stain.
    Thanks for the input guys, your the best. I am going to order both the Isolate IT ones, and the Pangea ones to compare, I have a lot of stuff that needs isolating anyways.
    Yep agree. Mine has always been on metal or laminated surfaces so that was never a concern.
  • marvda1
    marvda1 Posts: 4,873
    don't forget herbies. http://herbiesaudiolab.net/
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • ZLTFUL
    ZLTFUL Posts: 5,640
    marvda1 wrote: »
    I do love my Herbie's TT mat...
  • deronb1
    deronb1 Posts: 5,021
    I got ur vibration pod...right here!! Sorry, its the beer talking.
  • afterburnt
    afterburnt Posts: 7,892
    If you use the pods make sure they are sized for the weight.
    F1nut Posts: 49,799
    afterburnt wrote: »
    Great advice as that is very important.
    Cancelled first order and got these instead set of 4ea
    https://www.isolateit.com/hemispheres/sorbothane-hemispheres-bumpers/0-5-sorbothane-hemisphere-0510101.html
    Also ordered a Wireworld Starlight 7 1.0 meter USB cable so the Isolate IT hemisphere bumpers qualified for free shipping from Amazon B)
    Took Ryan's advise and got these I can see why I will need wax paper under these, I will have to get some before I apply them, these are beefy and I'm sure they will serve their purpose.
  • kharp1
    kharp1 Posts: 3,453
    Waiting to hear what you think about them. I had ordered some Vibrapods, but, I'm not real enthused about them.
    F1nut Posts: 49,799
    kharp1 wrote: »
    Years ago I tried them, Sorbothane works way better. I believe the Vibrapods went out with the trash.
    Never liked vibrapods, mine also went the way of the dodo
  • machone
    machone Posts: 1,475
    kharp1 wrote: »
    Worked way better as in better SQ?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    edited March 2018
    machone wrote: »
    kharp1 wrote: »
    As in way better isolation of components. I first tried vibrapods because I had a CD player that skipped pretty much all the time when my kids and dog were running through the house. They didn't work so well and I had a local place sell me the first generation of audioquest sorbothane pucks put those under my CD player and I could body-slam anybody in that room and it would never skip at all. Made me a firm believer. When I bought the autoquest sorbothane pods again this time they were in the big hemispheres and little hemispheres and I bought four sets of four of those from HCM audio for half price when they were clearing them out.
    F1nut Posts: 49,799
    Ed Zachary
  • headrott
    headrott Posts: 5,484
    I would very highly suggest some Marigo Audio Labs Mystery Feet, here: http://marigoaudio.com/isolation-feet/mystery-feet/
    These have made a massive difference in isolation (clarity, detail,etc.) Compared to any other isolation feet I have used. They are expensive, so I suggest buying used. They don't wear out. These, IMO will be the last isolation feet you ever buy.
