New 1C Purchase Questions
13»
    audioluvr Posts: 5,916
    Last thing was to install spikes bought here:
    https://meniscusaudio.com/product/mirror-image-pts-gold/
    I started by removing the plastic feet on the bottom cap. Then I drilled a 7/32" hole, sprayed a little water in it, added a drop of Guerilla glue, then screwed in the stud. This anchors them in solid. cqqel85fewl3.jpeg
    F1nut Posts: 51,783
    Any glue that foams creating air bubbles in it cannot make a good bond. Throw that stuff away and next time try 5 minute epoxy.
    The spikes do look good.
    The expansion actually allows it to penetrate the pores in the wood and fill any gaps in the studs' threads. I've used this stuff on a boat I restored and it is wicked strong. Epoxy would have been a PITA because I needed such a small amount in each hole. I may use epoxy to anchor the spike bases to the cap though. Haven't decided if that's necessary yet.
    I like these spikes because you can tilt the speakers back and unscrew the points, get placement dialed in, then reinstall.
    pitdogg2 Posts: 27,055
    edited February 2018
    On similar speaker bottoms I have just ran a bolt/washer through from inside the cabinet and tightened down good and tight on the same spikes. I buy mine in 1/4" x 20tpi pattern and just buy some new bolts instead of the threaded rod sent with.
    verb wrote: »
    Hey I noticed you put some dynamat on the brace in between the MW's. Never seen that before. Is that recommended?
    I tapped along the cabinet area looking for potential resonance points and found that and in the center of the 4 drivers as questionable. May have been unnecessary but WTH. Can't hurt right??? :#
    Well finally got my crossovers back from @westmassguy and after getting them hooked up correctly... (Thanks Dave. What would we do without you) I've been running them low volume 24/7 to burn in the new components and the dreadnaught. First impressions are VERY good! I'm noticing things like the ring of piano keys sounding like the piano is in the living room with me. I know how this sounds because, up until recently, there was a piano in here. Details in strings and drums are present now. I wasn't alone during my initial audition but I actually had to turn it down on the first track of Spin Doctors - Pocket Full of Kryptonite because everyone, including myself, jumped. These put out more sound than the Klipsch KG4's I replaced them with! Hopefully this weekend I can give them a more thorough review.
  • motorhead43026
    motorhead43026 Posts: 4,012
    What do ya have on the RH wall under cover? Looks like it could be a motorcycle? Only asking because many years ago I keep my brand new 1978 Triumph Bonneville in the kitchen.
    – Kevin Alfred Strom
    Viking64 Posts: 7,563
    I used to keep my brand new 1978 Pontiac Bonneville in the kitchen.
  • westmassguy
    westmassguy Posts: 6,850
    audioluvr wrote: »
    My Pleasure Sir.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    edited March 2018
    It's a Keyston Saddle.
  • dpowell
    dpowell Posts: 3,081
    The Dreadnought will allow you to use any non-common ground amp including mono blocks. The sound is vastly improved using the Dreadnought even with common ground amps.
    Guess I need to get off my lazy azz and get to building mine...
    Yes you do John! ;)
  • SDA1C
    SDA1C Posts: 2,072
    What do ya know, I was right again. After you upgrade the 1C's think about moving to something other than Carver SS power, you'll thank me.
    As arrogant as ever. Love your knowledge Jesse...You and heind end hang out often? Lol
    Too much **** to list....
  • verb
    verb Posts: 10,176
    edited March 2018
    I too went down the Carver path. Had 2 M1.0t's, moved to a TFM35x, and with a little enabling and tutelage from Polkies here went down the rabbit hole with a Conrad Johnson MF2300A. All I can say is wow! What a difference!
    And yes, @F1nut Father Jesse was right! :smile:
    Post edited by verb on
    verb wrote: »
    I took went down
    HAHAHA That reminds me of the SCTV skit about the "Western Redundancy Playhouse Theater" where the actors say things two ways, like is common in many old westerns in an attempt to sound more "western", I suppose. :p
    "Hey wife-woman. Git-hop into the kitchen-pantry and fix-cook-up a heaping-mess of food-vittles for that baby-child."
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    verb wrote: »
    I took went down
    Foiled again! Got me Jimmy! :smile:
    verb wrote: »
    When I'm editing, I constantly see remnants of ideas and phrases that didn't quite get deleted. Trust me. You are in excellent company. :)
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    verb wrote: »
    I just wanted to see if you were still out there! Yeah right. :smile:
    verb wrote: »
    Ya, ya, ya. Maybe I'm not playing my music loud enough... Since having my 1.0 rebuild done, there is a HUGE improvement from how it sounded prior. BUT. You rotten bastadges are making me look. Damn it! Just really hesitant to spend without doing an A/B comparison. There is an Aragon 8008BB and a Sonic Frontiers SFS80 that I have been eyeing...
    Viking64 wrote: »
    HAHAHA That reminds me of the SCTV skit..
    GOD do I miss SCTV. They just don't make TV like that anymore
  • verb
    verb Posts: 10,176
    Hehe. Are you gonna make @f1nut proclaim he is RIGHT once again? Lordy help us!
    verb wrote: »
    That's beneath him...
  • Schurkey
    Schurkey Posts: 2,122
    audioluvr wrote: »
    The 8008 will require a jumper wire across the negative terminals, or an isolation transformer (Dreadnaught) in the SDA cable, to overcome the 20-ohm resistance preventing "true" common-ground of the negative terminals.
    Aside from that...very recommended.
    Dreadnaught... Got one!
    edited March 2018
    audioluvr wrote: »
    There is an Aragon 8008BB that I have been eyeing...
    Great amps the 8008 and 4004 series made by Mondial designs. I have not heard the newer amps by Klipsch or Indy audio designs.
    Mondial designs had others beside those two but they were much more expensive.
    That's some seriously long reading...
