SRS 2s in a 15' x 25' room with a 38wpc tube amp?
  • nspindel
    nspindel Posts: 5,343
    The b/b is 3rd generation. It's 4 ohms out of the gate. With a lower DCR Sub-Bass Drive Inductor, even lower still.
    I'm just wondering how capable my amp would be to drive these things. It does have 4 ohm speaker taps, but I just don't know if it's got the guts for the job. I don't want to replace the amp to suit the speakers I don't have yet. I want to find speakers that work with the gear I have. It's an integrated amp - replacing it would mean needing to do amp, pre, phono stage, headphone amp, cables, power... I love this amp. The room is a nice size, but it's not SO big that this amp can't be paired with speakers that will sound great in here. I just need to figure out what those speakers are....
  • FestYboy
    FestYboy Posts: 3,861
    Something with a horn maybe? Or a DIY high sensitivity pair?
  • westmassguy
    westmassguy Posts: 6,850
    nspindel wrote: »
    Guys way smarter than me can advise on tubes Neil. Don't know diddley about those glowey things.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    pitdogg2 Posts: 27,155
    nspindel wrote: »
    nspindel wrote: »
    Can the pin blade XO be modded to pin blade spec and use the AI-1? Can these be TL’ed? Just because they’re here in my town doesn’t mean they’re the ones I want.
    Ok are you trying to ask if B/b can be modded to P/b?
    If so short answer NO!
    B/b use all mw6509
    P/b use 2x6510 and 2x6511
    Yes can be pin/blade can be TL'd
    Inspiredsports i believe had a good thread on it. It has been a number of years ago.
    Between my CRS+s and the spare parts I have, I have a pretty good start towards changing out the drivers to 6510 & 6511. If I had the drivers to do it, are the cabinets basically the same?
    Most likely all new inductors as well. Cabinets should be the same.
    Awful lot of work Neil
  • nspindel
    If they're stock, other than the drivers I'd probably do it all anyway. Not for $700 for the cabinets, of course! I'm just thinking out loud, doubt I'm pulling the trigger on those.
  • Mikey081057
    Mikey081057 Posts: 7,127
    I have a pair of 2.3's with all mods done 2 hours south of Tampa.
    And they sounded fine with my KT88's
    Garage | Polk Monitor 5B's
  • nspindel
    Interesting. Would you mind if I popped by and showed you what the VPI 299D looks like?
  • Mikey081057
    No problem...
  • nspindel
    And this would be the reason why Club Polk is so awesome. I’ll get in touch and figure out a time when I can shoot down. Thanks!
