Small Desktop or Mini Computer
My current desktop computer has some fan noise that is annoying when listening to music at low volumes in my small office.
I need a very simple puter for searching the internets and listening to music.
Any good suggestions? Would like to keep it under $300 and I don't do gaming or movies on this one. Only need 1 HDMI out, and I already have a 32" monitor.
Thanks folks,
Eric
  • ClipdatClipdat Posts: 7,739
    A new $10 fan?
  • EndersShadowEndersShadow Posts: 17,049
    But a Noctua fan of what whateber size you need.
    I’ve used Silverstone, Antec, SilenX and all sucked compared to the quiet I get from Noctua fans. I’ve been running some of them 24/7 for the last 10 years and never had a problem w em.
  • ConradiclesConradicles Posts: 5,982
    Interesting...a new fan. Will investigate.
    If you do decide to go w a new PC, and don’t need a ton of storage or gaming as a requirement lolk at Intel NUC. Silent and small and should work great as a secondary music source.
    3 year warranty too. Impressive.
    Yep, this. Noctua > everything else
  • dragon1952dragon1952 Posts: 4,717
    edited January 2018
    ____________________________
    2 channel - PS Audio Stellar S300 amp, PS Audio DirectStream DAC, audio optimized NUC7i5 running Windows 10 Pro/JRiver MC24, Matrix X-SPDIF 2 USB interface, Blackbird SSD dock with 500 GB Samsung 860 EVO, Tom Tutay modded EE Minimax preamp, Furman Elite 15 Pfi power conditioner, Martin Logan Electromotion ESL speakers, Rythmik F12SE subwoofer, Kimber 4TC speaker wire, Gabriel Gold Reflection V2 IC's, VH Audio power cords, Wireworld USB and HDMI/I2S cables
    Computer - Windows 7/JRiver, Topping D10 DAC, Fostex PMO.4n monitors
  • machonemachone Posts: 1,202
    Quantum Byte with wireless keyboard/mouse and Windows 10 for $200.
    You can pick one up from Amazon.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    The Asus EEEBox has a couple USB 3.0 ports also if that's important.
    Clipdat wrote: »
    @Clipdat @EndersShadow Is the Noctua easy to install? Also, how do I know which size to get?
    Let me know the model of computer you currently have, and what fan it is that's making the noise, and I'll tell you what size you would need and how easy it would be to replace it.
    edited January 2018
    Clipdat wrote: »
    Easier than the sub you built by 2000x.
    4 screws and a connection to the motherboard that’s a molex type connector. Beyond easy!
  • stevepstevep Posts: 120
    It's next to impossible to hear my music when I turn on the mini computer in my basement office.
    Oh, you meant mini as in small, I get now. :)
    Thanks for the recommendation of the fan. I just purchased the Noctua and shall see if that helps.
    I know it will! Good call!
    "Noiseblocker" fans are also great.
    nbrowser wrote: »
    Noctua fans are awesome for being quiet...also fans from the company BeQuiet especially the Silent Wings series...also deadly quiet for how much air they can push.
  • Mikey081057Mikey081057 Posts: 6,997
    I have an HP Slice... These are the ASUS comparables.
    https://www.asus.com/us/Mini-PCs/VivoMini-Products/
    I got mine with a SSHD which makes it totally quiet. The only time I hear it is when the DVD opens and spins up.
    I run my ROON core on it and have it hooked to my HT and my 2 channel DAC...
    Garage | Polk Monitor 5B's
  • rooftop59rooftop59 Posts: 6,316
    Did you get the fan installed @Conradicles?
    Living Room 2.1: Dynaudio Contour 1.3mkii; Energy s10.2 sub; Cambridge Azur 851A; Cambridge Azur 851C; Bryston BPD-1
    Game Room HT: Denon AVR-X4200w; Definitive Technology SM350; Definitive Technology LCR2000; Definitive Technology Procinema 800; Mirage Nanasats; Sub - HSU VTF-2 MK5
    Master Bedroom
    Cambridge Azur 551r; Definitive Technology SM45; ACI Titan Subwoofer; Squeezebox Touch
    No I just ordered it today. Will report back...
    edited March 2018
    Well,if it doesn’t work I will also way that I got an intel NUC i3 off eBay with 8 gb of ram and a 120 gb SSD off eBay for about $250 several years ago and it serves as my music server and family computer and it works great. Doesn’t get a whole lot of use as a computer but it’s on 24/7 as a server and no problems...
    Master Bedroom
    Ended up with an Asus Chromebox. Extremely happy with this inexpensive solution so far...
    The new Noctua fan worked OK, but that old computer is just too loud.
    Let me know how that Chromebox works out.... I've been debating one for a portable streaming device paired with a lil headphone amp...
    I've really been eyeing those i-3 NUC's. Not sure there's much advantage over my EEEBox though, except for a faster CPU which I probably don't, but I like the somewhat smaller footprint and I could get a burgundy lid to match my acoustic paneling :^ )
    I almost pulled the trigger on the NUC, but thought I would try this 1st.
    @EndersShadow will give some feedback soon. Next step is try to figure out the best app to play flac files from an external hard drive. I am so computer audio illiterate LOL.
    MediaMonkey (the free version) is a quality product.... and its free....
    Totally impressed with this little booger hiding on the right side of the picture under the Music Hall.
    Note the CPU monitor is a 32" Dell (looks like a 15" in the picture LOL).
    Those Yamaha monitors are huge. I have all new caps and resistors for them to be installed in the near future. This was a spare room in the basement that gets good use now.
Howdy, Stranger!
