Small Desktop or Mini Computer
Conradicles
My current desktop computer has some fan noise that is annoying when listening to music at low volumes in my small office.
I need a very simple puter for searching the internets and listening to music.
Any good suggestions? Would like to keep it under $300 and I don't do gaming or movies on this one. Only need 1 HDMI out, and I already have a 32" monitor.
Thanks folks,
Eric
Thanks folks,
Eric
A new $10 fan?
But a Noctua fan of what whateber size you need.
I’ve used Silverstone, Antec, SilenX and all sucked compared to the quiet I get from Noctua fans. I’ve been running some of them 24/7 for the last 10 years and never had a problem w em."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Interesting...a new fan. Will investigate.
If you do decide to go w a new PC, and don’t need a ton of storage or gaming as a requirement lolk at Intel NUC. Silent and small and should work great as a secondary music source."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
EndersShadow wrote: »If you do decide to go w a new PC, and don’t need a ton of storage or gaming as a requirement lolk at Intel NUC. Silent and small and should work great as a secondary music source.
3 year warranty too. Impressive. -
Yep, this. Noctua > everything elseEndersShadow wrote: »But a Noctua fan of what whateber size you need.
Asus EEEBox. No fan, SSD and about the size of a router.
http://www.macmall.com/p/ASUS-Desktop-Computers/product~DPNo~13741375~pdp.jiiddji?utm_source=google&utm_medium=cpc&adpos=1o4&source=MWBGOOGLEBASE&gclid=EAIaIQobChMIh-e-l-La2AIVF5R-Ch2AEQ_FEAYYBCABEgK7XfD_BwE2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Quantum Byte with wireless keyboard/mouse and Windows 10 for $200.
You can pick one up from Amazon.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
The Asus EEEBox has a couple USB 3.0 ports also if that's important.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
@Clipdat @EndersShadow Is the Noctua easy to install? Also, how do I know which size to get? -
Let me know the model of computer you currently have, and what fan it is that's making the noise, and I'll tell you what size you would need and how easy it would be to replace it.Conradicles wrote: »@Clipdat @EndersShadow Is the Noctua easy to install? Also, how do I know which size to get?
Conradicles wrote: »Yep, this. Noctua > everything elseEndersShadow wrote: »But a Noctua fan of what whateber size you need.
Easier than the sub you built by 2000x.
4 screws and a connection to the motherboard that’s a molex type connector. Beyond easy!
It's next to impossible to hear my music when I turn on the mini computer in my basement office.
Oh, you meant mini as in small, I get now.
Thanks for the recommendation of the fan. I just purchased the Noctua and shall see if that helps.
Conradicles wrote: »Thanks for the recommendation of the fan. I just purchased the Noctua and shall see if that helps.
I know it will! Good call!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
"Noiseblocker" fans are also great.Noctua fans are awesome for being quiet...also fans from the company BeQuiet especially the Silent Wings series...also deadly quiet for how much air they can push.
I have an HP Slice... These are the ASUS comparables.
https://www.asus.com/us/Mini-PCs/VivoMini-Products/
I got mine with a SSHD which makes it totally quiet. The only time I hear it is when the DVD opens and spins up.
I run my ROON core on it and have it hooked to my HT and my 2 channel DAC...My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Did you get the fan installed @Conradicles?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
No I just ordered it today. Will report back...
Well,if it doesn’t work I will also way that I got an intel NUC i3 off eBay with 8 gb of ram and a 120 gb SSD off eBay for about $250 several years ago and it serves as my music server and family computer and it works great. Doesn’t get a whole lot of use as a computer but it’s on 24/7 as a server and no problems...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Ended up with an Asus Chromebox. Extremely happy with this inexpensive solution so far...
The new Noctua fan worked OK, but that old computer is just too loud. -
Let me know how that Chromebox works out.... I've been debating one for a portable streaming device paired with a lil headphone amp..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I've really been eyeing those i-3 NUC's. Not sure there's much advantage over my EEEBox though, except for a faster CPU which I probably don't, but I like the somewhat smaller footprint and I could get a burgundy lid to match my acoustic paneling :^ )2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
I almost pulled the trigger on the NUC, but thought I would try this 1st.
@EndersShadow will give some feedback soon. Next step is try to figure out the best app to play flac files from an external hard drive. I am so computer audio illiterate LOL. -
Conradicles wrote: »I almost pulled the trigger on the NUC, but thought I would try this 1st.
MediaMonkey (the free version) is a quality product.... and its free...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Totally impressed with this little booger hiding on the right side of the picture under the Music Hall.
Note the CPU monitor is a 32" Dell (looks like a 15" in the picture LOL).
Those Yamaha monitors are huge. I have all new caps and resistors for them to be installed in the near future. This was a spare room in the basement that gets good use now.
