Vintage Monitor and SDA Speaker Deals
@pitdogg2, I was going by the wood grain across the front of the end caps, but you might be right. I have asked the seller. Waiting for a response.HTAdcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).2 Channel (Living Room)Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.2 Channel (Office)Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).2 Channel (Garage)Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
250GTLusso wrote: »@pitdogg2, I was going by the wood grain across the front of the end caps, but you might be right. I have asked the seller. Waiting for a response.
yep but they have some torn surrounds as well not a 1100.00 speaker IMHO. If they do not have a cable to go with as well, then I'd be hard pressed to offer half that amount. I'd have to get eyes on them before any discussion could also have froze VC's -
these look like a better deal but they kinda look like they might have been wet.
https://ebay.com/itm/Polk-Audio-SDA-SRS-2-3TL-Reference-Speakers/282772232369?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D44040%26meid%3Dc882c4f190db4489acdec0c80b1c1d6e%26pid%3D100623%26rk%3D2%26rkt%3D6%26sd%3D302594236826&_trksid=p2047675.c100623.m-1"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Why is the right one higher off the floor? Good observation! Low water damage like you think is probably right. Warpage.Most people just listen to music and watch movies. I EXPERIENCE them.
It is missing the feet. Gee, you would think the one with feet would have stayed out of the water. HAHAHA -
Those have been up for months. The description he gives for them are 2.3’s not tl’s. I guess he doesn’t know what they are.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Those are less than a mile from me. I can go look at them if someone is interested in them.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Those are less than a mile from me. I can go look at them if someone is interested in them.
That's pretty nice of you to offer that! Go, John.
@Tony M , and @TNTsTunes you have sharp eyes! I didn't notice the tear in the butyl rubber surround until you said that. Not too worried about the dust caps on the voice coils, as I have pulled out countless ones of those. Going to need a new MW6510.
@pitdogg2 I agree with you, not a $1100 speaker. $600-700 all day long though if they pass the VC test.
About 90 minutes from me (on a good day!).HTAdcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).2 Channel (Living Room)Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.2 Channel (Office)Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).2 Channel (Garage)Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut). -
^^^ arrrggghhhh!!! ^^^ I would love to grab those puppies!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
^^ whew - I misread - they are Monitor 5's - had em, nice enough, but I'm holding out for 7's someday... ^^ crisis averted. Side note. Damn Pugs are cute dogs.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Update on the 2.3TLs in the LA area. Seller sent me these photos, which appear to show that they are Walnut, but the seller says "I believe the caps are Oak".
I have also inquired about the torn butyl rubber surrounds.
Looks like they were left behind in a house that is being flipped... get me a phone number and I will go look at them.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Some mis-identified 1.2TL's in Riverside...900.00 or best offer.
https://www.ebay.com/itm/Polk-Audio-Crossover-Speakers/322818292288?hash=item4b29783a40:g:0QIAAOSwWGlZ3UbAThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Monitor 5's in Portland. If i didn't all ready have a spare room full of speakers I don't know what to do with I'd grab them.
https://portland.craigslist.org/mlt/ele/d/polk-audio-series-5-speakers/6450575173.html
You could stack them like me.
Another set of Monitor 5's, these are in Victorville. Seems like they are flooding the market at the moment. No affiliation.
https://inlandempire.craigslist.org/ele/d/vintage-pair-of-polk-audio/6427247456.htmlHTAdcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).2 Channel (Living Room)Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.2 Channel (Office)Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).2 Channel (Garage)Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut). -
Well after I queried the seller regarding the torn surrounds in the photo in his ebay listing for his 2.3TLs he came to the realization that he uploaded the "wrong" photo (the initial photo was of a 2.3TL that he was looking into buying several years ago on ebay). Seems very strange, but I guess it can happen. He has updated his listing to show the new photos. I had added the front baffle photos here-
https://www.ebay.com/itm/Polk-Audio-SDA-SRS-2-3TL-Reference-Speakers/302594236826?hash=item467405a19a:g:uIEAAOSwObhaVr-NHTAdcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).2 Channel (Living Room)Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.2 Channel (Office)Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).2 Channel (Garage)Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut). -
I always wanted to get a pair of RTA-11Ts when they came out, but never did. This pair seems very nice. What is the going price for these in good condition? Seller is asking $200.
https://inlandempire.craigslist.org/ele/d/polk-audio-rta-11t-speakers/6420416363.htmlHTAdcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).2 Channel (Living Room)Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.2 Channel (Office)Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).2 Channel (Garage)Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut). -
250GTLusso wrote: »I always wanted to get a pair of RTA-11Ts when they came out, but never did. This pair seems very nice. What is the going price for these in good condition? Seller is asking $200.
Good price. -
Definitely a better price then the guy that has these locally where I am......
No affiliation:
https://phoenix.craigslist.org/nph/ele/d/awesome-vintage-polk-audio/6449122298.html -
Someone has a pair of Monitor 5's for $30 locally but needs a woofer replaced.....
No affiliation
https://offerup.co/lLdq/lfFLxfoOBJ -
"250GT Lusso" -- great moniker.
The single most beautiful automobile ever made, as far as I am concerned.
sorry for the temporary hijack.
Good price.
In the past 6 months I have purchased two sets of 11t's. One in great condition for 20 bucks. The other was 40 or 50 bucks I believe.
Again I shall reiterate: You, sir, are much like a Hoover...
@mhardy6647 I completely agree with you. We have had 2 Lussos over the years. Sadly not right now.HTAdcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).2 Channel (Living Room)Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.2 Channel (Office)Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).2 Channel (Garage)Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
@la2vegas , you got some SMOKIN deals on those I think. What do you think of their sound?HTAdcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).2 Channel (Living Room)Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.2 Channel (Office)Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).2 Channel (Garage)Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
That car and a Jaguar XKE in RED would look good in my garage if I had one.
Where???
