help!
egp823
egp823 Posts: 74
edited November 2004 in Troubleshooting
bought a new set of drivers for my CRS and I noticed that speaker terminals does not have the + and - signs. Where do I put the positive wires? Should I just follow the terminals on the old drivers? Thanks a lot .
Post edited by egp823 on
  • amulford
    amulford Posts: 5,020
    look at the connectors very carefully...
  • egp823
    egp823 Posts: 74
    no sign on the connectors. old drivers had a red dot beside the connector for the positive.
    F1nut Posts: 49,875
    Hook them up the same way as the originals.
  • amulford
    are the connectors slightly different sizes?
    F1nut Posts: 49,875
    Anthony, all the SDA mid drivers have the same size terminal pins.
  • ntculenuff
    ntculenuff Posts: 1,146
    if you have not figured this out yet you can take a 9volt battery and touch the 2 terminals if the speaker extends out this is the correct way to wire the (+) and (-) if the speaker sucks in this is backwards
    the battery will not hurt the speaker., you can do this tweeters too but use a smaller battery and it is tougher to see
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • RuSsMaN
    RuSsMaN Posts: 17,987
    DO NOT TAKE A NINE VOLT BATTERY TO THE TERMINALS.
    If you want to use the battery method, AA or AAA (1.2v).
    Cheers,
    Russ
