help!
egp823
bought a new set of drivers for my CRS and I noticed that speaker terminals does not have the + and - signs. Where do I put the positive wires? Should I just follow the terminals on the old drivers? Thanks a lot .
Post edited by egp823 on
look at the connectors very carefully...
no sign on the connectors. old drivers had a red dot beside the connector for the positive.
Hook them up the same way as the originals.Political Correctness'.........defined
President of Club Polk -
are the connectors slightly different sizes?
Anthony, all the SDA mid drivers have the same size terminal pins.Political Correctness'.........defined
if you have not figured this out yet you can take a 9volt battery and touch the 2 terminals if the speaker extends out this is the correct way to wire the (+) and (-) if the speaker sucks in this is backwards
the battery will not hurt the speaker., you can do this tweeters too but use a smaller battery and it is tougher to seeSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
DO NOT TAKE A NINE VOLT BATTERY TO THE TERMINALS.
If you want to use the battery method, AA or AAA (1.2v).
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
