Subaru did what now?!?
  • FestYboy
    FestYboy Posts: 3,861
    edited November 2017
    Not a problem.
    Here we go: from HU harness →speaker harness
    Left front + black→ white
    Left front - green → brown
    Right front + red → black/red
    Right front - white → white/red
    Left rear + white/blue → black/blue
    Left rear - orange/blue → white/blue
    Right rear + blue/yellow → yellow
    Right rear - blue/green → white/black
    If you're feeling slick, I'd do this: remove connector R317 and extend pins 1 & 5 back to the amp. Then back probe R316 pins and extend those to R317 as they correspond to the colors above.
    Or easier: from R316 to R317 (pin numbers)
    2:10
    3:4
    4:9
    5:3
    17:6
    18:2
    22:8
    23:7
    And you'll want to disconnect pins 1, 2, 3, and 9 from R315
  • halo
    halo Posts: 5,616
    FestYboy wrote: »
    Not a problem.
    2:10
    3:4
    4:9
    5:3
    17:6
    18:2
    22:8
    23:7
    Ok, the wire colors I understand..but removing the connector R317 (which one is that? & same for R316). Back probe? That doesn't sound pleasant. lol. Seriously though, that's Greek to me.
  • FestYboy
    Ok there are 3 connectors for the in house amp and they are labeled as such: R315 feeds the tweets and sub, R316 is the input from the HU, and 317 is power to the amp and output to the speakers. Sorry I don't have colors for the plugs, but R315 is 12 pins, 316 is 24 pins and 317 is 10 pins, so they're dummy proof in that respect.
    Back probing is simply inserting another pin to the back side of the connector so that it can remain inserted in it's intended spot while being able to feed or tap the wire at the same time. I'll look for the proper pins in a moment.
  • halo
    halo Posts: 5,616
    FestYboy wrote: »
    The wiring diagram shows that R315 is Blue. I'm still not grasping the back probing concept. Sorry about that :(
    mhardy6647 Posts: 34,921
    Sounds like piggybacking another wire (connector) onto a multi-pin plug (to me).
  • FestYboy
    These should work with some solder and heat shrink. Gikfun Female and male Pin Connector Terminal 2.54mm for Dupont Jumper Wire Each 100pcs EK8284 https://www.amazon.com/dp/B0146DJR9Q/ref=cm_sw_r_cp_apa_5EmhAbNSXYQ5T
  • halo
    halo Posts: 5,616
    Looks like I’ll have to yank out the OEM amp and replace it with a 4-channel amp (2 for the front door components & 2 for the DVC sub) and I’ll run the rear door speakers off the head unit. Dang it. At least I know now I can disconnect the OEM amp without any issues.
    At least that’s the plan for now.
  • ken brydson
    ken brydson Posts: 8,986
    FestYboy wrote: »
    Not a problem.
    2:10
    3:4
    4:9
    5:3
    17:6
    18:2
    22:8
    23:7
    What was that middle part again? Otto (Name the movie and actor for a karma)
  • FestYboy
    halo wrote: »
    Ummm nope!!! Not even close. there's absolutely no reason to pull the factory amp (unless you WANT to). And if you're using the HU to power the rear speakers, you're half way there anyway. And if you ARE going to run an aftermarket amp, get a 5 channel.
  • FestYboy
    Not quite where I was going with that @nbrowser . If the directions are followed, the OEM amp winds up only running the sub and the new HU runs the doors, no other amplification needed. I got a PM from @halo that the OEM amp doesn't play well with other speakers, but no clarification as to which ones....
  • FestYboy
    In that case, I'll agree. But then if he goes that route, there's the joy of fishing a wad of RCA's through the center console, and you'll still be splicing into the factory harness for the speaker wires because running separates is a total PITA.
    Post edited by FestYboy on
  • halo
    halo Posts: 5,616
    FestYboy wrote: »
    Hi guys,
    The OEM amp is tuned specifically to work with the OEM speakers (frequency cutoffs, crossover points) and I have no idea what those specific values are. It's been tried before on the Outback and Legacy GT forums and the consensus is that the OEM makes anything but OEM speakers sound wonky.
    halo wrote: »
    FestYboy wrote: »
    Hi guys,
    Not to go all left-brained analytical scientist on y'all -- but it seems to me that the operating parameters of the amplifier(s) ought to be pretty straightforward to figure out with a frequency generator (and/or some pink noise) and a DMM or a 'scope or even a calibrated microphone/SPL meter.
    Not that I am thinking very hard about this -- I am just a dilettante with respect to this topic. My son-in-law & daughter just bought a 2010 Outback, though, so my interest isn't 100% academic. :)
  • WLDock
    WLDock Posts: 3,073
    I remember Manville Smith from JL Audio did a very nice stealth system in a 2005 Legacy GT Wagon. Very nice pictures: http://www.jlaudio.com/galleries/Galleries/Mobile+User+Installations/2001+Audi+A6/JL+Audio’s+Demo+Vehicles/2005+Subaru+Legacy+GT+Wagon/718600
    Here are some AWESOME SQ builds also...several Subie builds: http://www.simplicityinsound.com/index.php/galleries/sound-quality-builds
    Clipdat Posts: 13,087
    Simplicity In Sound is the best! Wish I could afford to have them do a system in my FR-S.
    WLDock wrote: »
  • halo
    halo Posts: 5,616
    Hi Mark,
    The 2010 Outback is the first model year in the next (4th) generation of the Outback and it’s a different animal from the 3rd gen (2005-2009) Outbacks.
    I actually sort of knew that; thanks :)
    I do know that it has a fairly low-tech 'infotainment system' (compared to our son-in-law's mother's 2016 Outback).
