SDA2B Upgrades
What exactly is it doing to the signal?Don't take experimental gene therapies from known eugenicists.
I missed this thread before.
So the consensus here is to remove the 750pF cap while using RD0194s?
We remove that whenever we recap the XO it is no longer needed....
It has nothing to do with the RD0194
Thanks Pitt, What was it doing to the original signal is what I should have asked.Don't take experimental gene therapies from known eugenicists.
smoothing out the sound due to the Mylar type caps used. Bypass caps in most instances inject artifact's that at first sound great but then become fatiguing the ear.
The caps we use today in most cases are leaps and bounds better than 30 +yrs. ago. therefore negating the need for them. -
Thanks again Pitt. I knew I should have yanked them when I yanked those nasty Polyswitches.Don't take experimental gene therapies from known eugenicists.
