I've been given the green light
FestYboy
Ok, I'm a happy boy!! Caety just gave permission to purchase an amp to mate to the karma speakers I just received.
So in that vein, I'm throwing myself at the mercy of the forum for suggestions on a small form factor amp (tube possibly) that sounds good and won't break the bank. I know I can add Bluetooth with an add-on, but if there's an integrated out there...
So what's your budget? Times that by 3. Club Polk = blow the budget.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Ain't that the truth!!! O_o -
Find a used Acurus A 250, you wont regret it.
Ummm was hoping for something smaller, and that definitely doesn't have any WAF. Think half rack sized. -
Parasound hca100- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ok full disclosure: her studio is all of 6x7... 4 tube watts would be more than enough. In most cases I would side with Tim Taylor, but budget and WAF constraints prevail...
W4s amps have power and smaller in size.
Sounds like you should look at the parasound Z series, also check out Teac.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
Tried googling that an only got a vintage tube amp for a hit, and at almost 16" wide it's kinda big... Got a lint to what you're thinking about?
Edit: found it! Wired 4 sound... Yeah, they're expensive!
I don't mind used and was hoping to keep it in the 300 or less range. I always wondered about the larger headphone amps with the tube pres and wondered how'd they hold up since I know some have 5-ways in the back...? -
If you don't need a ton of juice, How about a Parasound HCA-600, Acurus A80, or an older Carver 0.5t? All are pretty close to half-rack. Some of the Rotel stuff is fairly thin.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
I'm probably using half rack incorrectly. What I mean is half width, hight isn't as much an issue.
How about something line this? It's a 12 incher, that should make any wife happy.
https://musicdirect.com/integrated-amp/Jolida-Fusion-1102-Integrated-Amplifier-Black-DEMO
"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Yeah, she likes the look, but definitely NOT the price...
Want smaller? How about an 8 incher???
https://musicdirect.com/integrated-amp/jolida-fx10-integrated-tube-amp
How about a PS Audio Sprout? Features are 50WPC Amp, Phonostage, 24-Bit Asynchronous DAC, and aptX Bluetooth Receiver. Slightly over budget but she might like it's features.
psaudio.com/products/sprout/
Probably ur best option, and u can find a better deal used: http://www.audioadvisor.com/prodinfo.asp?number=PAZAMPV3&variation=BLK&gclid=CjwKCAjwuvjNBRBPEiwApYq0ztkajdfR3eG6L04MdEgPIWIHlRLwmt3ZR1rDwxfk9ob6MVf4yL75xhoCL8YQAvD_BwE
I will say that when I had one briefly I compared it to an audiosource amp200 (not exactly an audiophile amp lol) and the audiosource destroyed it power wise. More bass, better dynamics and authority, everything was better. But driving Polk monitor 5s with peerless newrfiled in my office, the parasound was GREAT.
Daytons t-amp is also a good option for efficient speakers in a small space...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Oh wow, that's awesome (yes over budget, but...) I wonder if I wait a bit the holidays may bring the price down?? -
Doubtful. I owned one for a while and it was a great piece. I look every week, because I want another, but haven't found one under $400 used yet...Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
Keep 'em coming guys!! I'm looking at all suggestions.
So far the sprout and spark are the for runners... Both a bit higher than I was hoping but if I add a BT receiver to the spark, they're in a dead heat. -
I'm also searching, here's what I found:
NAD D 3020
TEAC AI 301DA
Any experience with those? Crutchfield has both listed at 400, so they're very close to the above options. -
Oh wow, that's awesome (yes over budget, but...) I wonder if I wait a bit the holidays may bring the price down??Doubtful. I owned one for a while and it was a great piece. I look every week, because I want another, but haven't found one under $400 used yet...
Here's a 5 month old Sprout $395 + 12.38 shipping, no bids, 21 hours to the end of the auction.
ebay.com/itm/PS-Audio-Sprout-Integrated-Amp-Only-5-months-old-/192304075245?hash=item2cc63751ed:g:of8AAOSwgKpZtsni
No biding wars between you two....
Haha thanks, and it's right up the road from me...
Puritan PSM156 -
I have the previous generation of that amp and love it. Always had a fondness for NAD.
Yeah, NAD's headroom is constantly amazing.
Dayens Ampino. Tube sound in a solid state design. It's tiny but has mucho power.
The iFi Stereo 50 is a superb unit but likely out of your price range.
the Dayens prove to me that some lower wpc amps and integrated amps can drive some serious speakers. I heard them on multiple speakers and wouldn't hesitate to run my Usher with them or some 703's with them.
I'd still own a pair of Dayens some day.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
