Turntables
12346
    mhardy6647 Posts: 35,230
    I am drolly amused by the fact that the turntable industry's cribbing some notes from the "1960s third-grade lunchbox" industry ;)
  • tratliff
    tratliff Posts: 1,811
    I had a chance to see both the sgt peppers and George Harrison tables. They were both very nice.
    Actually considering getting one as a secondary table. Something about Beatles stuff seems to open my wallet.
    tratliff wrote: »
    Yeah, I (still) have that problem, too...
  • kharp1
    kharp1 Posts: 3,453
    tratliff wrote: »
    Man, you guys must be old :)
    So old that there was a gofundme page for "dirt" on-line when I was borned...
    I don't think I would buy a Beatles rekkid playa, tho...
    although I did find a Michael Jackson "Thriller" rekkid playa at the Harvard (MA) town dump years back... I was thinkin' about grabbing it, since it must have collectors value... but I demurred. At least I think I did. Maybe I should check the basement again...
  • tratliff
    Understood. I would have never even considered it but since I already have a VPI Prime and the wife wants something she can use I thought this would be a good compromise. Not that its a great table but it sure is cool as hell.
    tratliff wrote: »
    That's a good reason!
    I don't think my wife wants her own turntable (although she did have one, an SL-D2 when she was in grad school. Actually, a series of three of them; but that's another story for another day ;)
    She certainly wouldn't like to use the one I am now rockin' upstairs -- it has no damped cue on the arm :/
    35993349896_36ea634cf3_b.jpgDSC_8876 (4) by Mark Hardy, on Flickr
  • dromunds
    dromunds Posts: 10,139
    I have a Michael Jackson "Beat It" T-Shirt that I'll sell for a "reasonable" stipend.
  • kharp1
    kharp1 Posts: 3,453
    Here's a question, what about clamps vs weight? The PLX-1000 doesn't have a threaded spindle, so, is there a clamp that will work well (besides The Clamp that just sold in the flea market), can I change the spindle, or, is a weight good enough? If weight, what amount of weight should I be looking for?
  • voltz
    voltz Posts: 5,384
  • kharp1
    kharp1 Posts: 3,453
    I looked at the RPM 9.2 on sale from AA, but, ended up with a Pioneer PLX-1000 with a Denon 110 cart for the grand total of 8 bills. Decided on going with a DD tabe built like a tank for my first table and seeing how that goes.
    nooshinjohn Posts: 26,000
    I like DD's, but I found them to be quite a handful.
  • Dawgfish
    Dawgfish Posts: 2,554
    kharp1 wrote: »
    You can use a weight or a clamp with this. I find that a center weight with outer ring is the absolute best at flattening warped vinyl as well as making the most sound improvement. The thing is though an outer ring will more than likely not fit the PLX-1000 though to the power/switch that sticks up at or above the level of the top of the Platter. This is also true of the Technics 1200. Also I don't like to put a lot of weight on a direct drive table due to undue wear on the bearing and the breaking mechanism. I unfortunately caused the demise of a very high end vintage direct drive table by doing this. Where I'm going with all this is a good clamp like the Clearaudio Twister is recommended for a direct drive table like your Pioneer. Center weights can sound very good on your table too, but make sure you use one under 1.5 lbs.
  • kharp1
    kharp1 Posts: 3,453
    Thanks @Dawgfish I appreciate the info. I ordered the Clearaudio Twister. My understanding is this table has a pretty flexible braking range. I'm looking forward to getting it in house and getting some hands on experience with it.
    How so?
  • FestYboy
    FestYboy Posts: 3,861
    How so?
    Oh common...!!!
    More than a mouthful is a waste... :#:o
    txcoastal1 Posts: 13,519
    How so?
    In context....If you had hands like shack, they'd be AA's
  • Dawgfish
    kharp1 wrote: »
    You're welcome! Looking forward to hearing your impressions of everything!
    Triumph commissioned Rega to make 2 of these to spotlight their new café racer and are giving them away on facebook or twitter.
    Harman Kardon HK 505
    Harman Kardon HT 500
    Optonica RP 3636 mkll
    Luxman L210
    Luxman T240
    Luxman PD-289
    Audio Technica at12sa
    Audio Technica at440mla
    Signet tk5ea
    Shure M97xE
    ADC XLM mkII
    Pioneer CT-F9191
    Pioneer RT 707
    Pioneer DV 563A
    JVC XL-V251
    Cerwin Vega Sub 150
    Polk Monitor 10's
    Polk Monitor 7's
    Wharfedale w70d
    Wharfedale w60d
    Wharfedale w40d
    Advent Baby II
  • soundfreak1
    soundfreak1 Posts: 3,414
    Hope they didn't have Lucas do the wiring!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • tonyp063
    tonyp063 Posts: 1,136
    All hail the Prince of Darkness :)
    :) Indeed.
    Stock up now:
    All this being said -- I've gotta say, I like the aesthetic of that tt (even though I knocked the "Beatles lunch box" tts earlier on).
    edited August 2017
    I mean, it ain't a 1952 Vincent Black Lightning, but still...
  • Dawgfish
    Nice handle! Go Dawgs!
  • soundfreak1
    :) Indeed.
    Stock up now:
    HUH, and all this time I thought the SMOKE I'd see from under the hood of my Lotus was a standard fare, not added for effect. LOL.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    That's right -- when Lucas ("Prince of Darkness") made the electronics, the smoke was a feature (in the most Microsoft-ish sense of the term imaginable).
  • It really wasn't Lucas fault per say. It all comes down to, you get what you pay for. I knew someone that work for Triumph. He was one of the factory reps for Triumph Motorcycle Ltd in the US during the 70's. He said the manufacturer would give Lucas a cost per unit and "say offer what you can at this price", no more, and if you can make it for less do so.
    Lucas was at that time and still is a premier manufacturer of electrical components. But you want junk, they will fix you up too.....lol.
    – Kevin Alfred Strom
  • soundfreak1
    Lucan is the reason the British drink warm beer,
    Lucas made the refrigerators! LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
