The LP Lover's thread...
135
  • schwarcw
    schwarcw Posts: 7,358
    SCompRacer wrote: »
    Rich, did you and Carl perform the the new body mods on your 103R's? Are the Aluminum bodies preferred over the Wood bodies?
    I just setup a new "stock" 103R, and like most everyone else, I'm taken aback by its performance as is. But, I'm also looking at taking it to the next level.
    I think Carl sent his 103R in to SoundSmith for the body/cantilever mod. I just added the aluminum body. I purchased the Midas aluminum body from a Lenco turntable forum member who had them made.
    The goal of the aluminum or wood body on the 103R is for broad band resonance control and improve the low compliance nature of the cartridge. Either body material tightens up the bass and seems to extend the low frequencies.
    Aluminum will add more weight than the wood and increase compliance. IIRC ZU chose aluminum as most arms and head shells are made of aluminum. The reasoning, matching materials are less likely to reflect resonances as dissimilar materials do. Wood bodies allows choice of different types of exotic woods.
    IMO the Midas aluminum body I am using offers better neutrality, clarity and high frequency air and extension than a wood body. I do not consider it bright at all. Regarding wood or aluminum depends on the presentation that you like and perhaps the arm that you use it on. SoundSmith ruby cantilever and stylus upgrades will elevate the performance even more. Once I wear my 103R out, I’ll send it there for an upgrade. I still prefer my AT33PTG/II over the aluminum bodied Denon for sound quality, so unsure when I'll wear it out...lol.
    If you proceed, watch the videos on you tube for nuding the cartridge. A steady confident hand is needed. Also purchase your body from a reputable supplier. One where the cartridge will drop in without havingr the insight to carve out material or force the nuded cartridge in.
    Thanks for the insightful explanation Rich. I'll check out the videos and maybe try my hand at this delicate surgery.
    Hey Mike, Rich is correct is sent my Denon to the Soundsmith for the ruby cantilever and the contour diamond. With the help of my friend Larry, I nuded the Denon and mounted it into the Zu aluminum body. An excellent mod in all respects! Deep, tight bass, smooth highs and mids. Just like butta!
    Carl
  • Mike Reeter
    Mike Reeter Posts: 4,315
    schwarcw wrote: »
    SCompRacer wrote: »
    Thanks Carl, I've looked into just buying another 103R from Zu, but there seems to be a waiting list. Patience is not one of my best virtues, but I really don't know if I can handle the delicate 103 without jacking something up.
    I'll come up with something one day, for the time being I just going to enjoy the stock 103R, it has pretty much kicked my S.S. Zephyr to the curb...amazing cartridge for the price of admission!
  • Mike Reeter
    mikeyb128 wrote: »
    Best video I have found here:
    http://www.dailymotion.com/video/x3022v1
    And the body I will use from here:
    http://calamightysound.com/uwe-and-midas-bodies-for-denon-dl-103/
    Same body used in the video posted above.
    Thanks for links, very helpful!
  • Dawgfish
    Dawgfish Posts: 2,554
    edited July 2017
    I have the ZU 103R and 103 grade 2 prime. The 103 has the Soundsmith level 3 stylus and ruby cantilever. I also have a 103R with a brown ebony body and a 103 with black and white ebony body. Both the wood bodies have the stock stylus. All sound great, but I find myself gravitating towards the wood bodies for their warmth and tone. I also have an aluminum bodied 103S. I did both wood body mods and the aluminum body mod on the 103S. It's pretty easy to do. Just take your time and it's pretty simple. If you have the stylus guard, make sure you use it when cutting the plastic body away from the metal bottom plate and sides.
    After you have tried the wood or aluminum body mod and you decide you like it, don't overlook potting the body, it makes a noticeable difference. I used clear epoxy on all of mine, but I hear potting with lead shot like what Paradox does with the Pulse 103/103R makes a greater difference. http://www.paradoxpulse.com
  • Mike Reeter
    Dawgfish wrote: »
    Dawgfish, You certainly have all the bases covered on the 103! Thanks for your insight. I will investigate further. As long as the new replacement body ( wood or metal) have threads in them, that's a big plus for me, I really dislike non-threaded bodies, those little taps are such a pain.
  • Dawgfish
    edited July 2017
    Thanks! I am a big fan of the 103 family. I also have a 103D and 103M. I would like to have a 103SA one day, but I haven't found one yet for a price I would consider pulling the trigger on.
    If you need any help/advice with anything 103 related, hit me up anytime. Oh and couldn't agree more with having threaded inserts! Makes life so much easier. Just be careful with the wood bodies and the screws. It is possible to overtighten the screws and strip the wood threads.
  • mikeyb128
    mikeyb128 Posts: 2,885
    I'm liking what I hear about these denon dl103's. I had an audio buddy of mine come over on the weekend. He swore he tried the dl103 and never liked it. We were sitting listening to tunes and drinking beers, and he commented on the bass in my system. I told him the 103 was on deck, and he almost spat out his beer! lol I think I changed his mind on this cheap little gem.
    2 channel:
    Theater:
  • miner
    miner Posts: 1,305
  • Wardsweb
    Wardsweb Posts: 942
    Ok, I'll play. Here is my main system turntable. It is a Clearaudio Champion II with an SME 309 arm and a Benz Micro Glider cartridge. This replaced a Rega Planar III with an RB250 arm and Audio Note cartridge. The difference is amazing. The new setup extracts so much more from the record. The down side is a bad pressing, bad production or noise is brought front and center.
  • Wardsweb
    Wardsweb Posts: 942
    A second table in my main system is a Maplenoll. This is an air bearing platter and air bearing linear tracking arm. These are pressurized with 60psi from an air compressor in the garage. The cartridge is a Sumiko Blue Point Special EVO III. While the sound on this one is very good, the table is very tricky to setup, weights in around 80 pounds and tracks very light, so can be an issue on shallow groove records.
  • Wardsweb
    Wardsweb Posts: 942
    My other vinyl rig runs a custom Roksan Radius 5 table that I replaced the factory birch MDF plinths with 1" solid bubinga. The Rega arm is fitted with a Rega Exact 2 cart. This table is a lot more forgiving of old and noisy records.
  • schwarcw
    Nice Luther!
    Carl
  • soundfreak1
    soundfreak1 Posts: 3,414
    OK OK OK enough with the picts of TT I'd die for!!!! Getting a serious case of PHONO ENVY!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Dawgfish
    Wow! Y'all have some seriously nice decks!
  • Dawgfish
    edited July 2017
    My main deck is a Sota Saphire with a Jelco 750D tonearm, a Koetsu Black cartridge at time of photo, low-slung counter-weight, and Shuggie collar:
  • Dawgfish
    edited July 2017
    One I like to put in the rotation, a JVC QL-A75 with Ortofon Rondo Red Cart (currently running Clearaudio Virtuoso on it): dur9hex712n8.jpg
    Post edited by Dawgfish on
  • Dawgfish
    Another one in the rotation, Sonagraphe SG-3, Sumiko MMT tonearm, Nagaoka MP-50 cart:
  • Dawgfish
    Pioneer PL-L1000 Linear Tracker with Technics EPC-205CMKIV cart:
  • Dawgfish
    Harman Kardon T-60 with Dynavector Karat 23R cart:
  • Dawgfish
    Sony PS-X75 with Cartridge Man Music Maker 3 cart:
  • soundfreak1
    Hey dawgfish......bite me! LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    txcoastal1 Posts: 13,505
    This thread is like going to a biker rally
    Makes we really want one until I figure out I really can't afford one :/
  • mikeyb128
    edited July 2017
    Here's my beast. Haven't included the full shot yet.
    2 channel:
    Theater:
  • Mike Reeter
    Beautiful Tables everyone!
  • mikeyb128
    I thought I had a nice table, until I see the tables above. Lots of really nice tables here gentlemen.
    2 channel:
    Theater:
    SCompRacer Posts: 9,092
    edited July 2017
    One of these days my table will match my Walnut Bottlehead Eros phono stage...a PTP5 stainless top plate Lenco. The motor is separate of the main bearing plate. I'll keep my air bearing linear, maybe stick a pivoted arm on it too.
  • Dabutcher
    Dabutcher Posts: 2,604
    Very nice turntables gentlemen. Thanks for sharing.Peace. D
  • Dawgfish
    mikeyb128 wrote: »
    Yeah the key to the 103s (except for the higher compliance 103D, 103M, and 103S) is having a tonearm with enough mass to work well with the lower compliance of the 103s. Your 12' Jelco arm and heavier headshell is the perfect match! I bet she sounds beautiful! That's a really nice rig!
  • Dawgfish
    edited July 2017
    Thanks! Lol!
  • Dawgfish
    SCompRacer wrote: »
    That is simply gorgeous! I would love to hear your Lenco! I just got my first idler drive table, a mint Dual 1019. Unfortunately it's running a little slow speed wise. I've got to do some more work on it to get it right. I'm very much looking forward to hearing an idler.
