New interconnect options for SDA
Hi all, I have a pair of SDA SRS 2's that I need to have a new interconnect cable built. I am wondering if these will work for the Blade/Blade version?
https://www.parts-express.com/neutrik-nlt4mp-bag-speakon-stx-4-pole-male-chassis-connector-black-chrome-metal-housing--092-340
https://www.parts-express.com/neutrik-nlt4fx-bag-speakon-stx-4-pole-female-cable-connector-black-chrome-metal-housing--092-336
I believe they work for pin/blade SDAs which I also need but I need to replace the Blade/Blade version first.
Thanks as always.
Best Answers
    F1nut Posts: 52,000
    edited July 2017 Answer ✓
    The Neutrik connectors will work for either SDA version.
    Get this socket instead, it's air tight. https://www.parts-express.com/neutrik-nl4mp-uc-speakon-connector-4-pole-panel-mount--092-067#lblProductDetails
  • Stew
    Stew Posts: 645
    Answer ✓
    The NLT4FX-BAG works great as long as you plan to solder the connections (up to 10 ga.). The NL4FX has set screws but only accepts 12 ga. and requires a special screwdriver (Pozidriv #1).
    SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
    1000VA Dreadnought
    Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
    Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
    RTiA3, Onkyo TX-SR605
  • dkfreebird
    dkfreebird Posts: 1,186
    Answer ✓
    Same cable for the interconnect if you can.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • dkfreebird
    Answer ✓
    Yes,you have to make the hole bigger. Drill out the rivets that hold the old socket in. I used a dremel to enlarge the hole
    Oppo 103
    Pangea PC
Answers
  • chandler9a
    chandler9a Posts: 878
    Okay thanks, that answers that.
    Any recommendations on what cable to use? I use modest Audioquest type 4 speaker cable for the SDAs at the moment.
  • codycatalist
    codycatalist Posts: 2,661
    edited July 2017
    I have a parts express coupon if you end up wanting it. Don't remember how much you need to spend before the discount kicks in but I will check when I get home.
  • chandler9a
    okay thanks guys. It looks pretty straight forward, I think I saw a post here a while ago on how to actually do this so I will try to find that again and get this done.
  • Stew
    Stew Posts: 645
    1000VA Dreadnought
  • chandler9a
    Ah okay, thank you for that
    F1nut Posts: 52,000
    Don't forget to seal the hole you make for the socket on the backside of the binding post plate. Hot glue works well for that.
  • chandler9a
    yes I remember reading somewhere that it would need to be resealed. I want to make sure the cabinets stay air tight.
  • chandler9a
    I am about to put these cables together using Audioquest type 4 and wanted to make sure I am soldering the correct things here before I go.
    Am I connecting Positive (red) cable to -2 and negative (black) to -1?
    These will be for my SDA 2.3 speakers so my next question is how should I wire the inside of the speaker to the female Neutrik?
  • dkfreebird
    The way I've read most on here and the way I did mine are +1 goes to the blue/pin wire the -1 goes to the white/blade wire.
    Oppo 103
    Pangea PC
  • chandler9a
    okay so does that change how I solder the IC cable to the female Neutriks? Sorry, I meant male neutrik in my earlier post above where I was talking about inside the speaker.
    F1nut Posts: 52,000
    Your 2.3's are pin/blade. For the socket connect the blue wire to 1+ and the white wire to 1-. For your interconnect cable one wire gets connected to the 1+ and the other wire to 1- at both ends.
  • chandler9a
    got it, thanks. That makes sense.
  • chandler9a
    so I am finally getting to install the Speakon connections in my SDA 2.3's and have another quick question. The Neutrik NL4MP-UC socket is too big to fit in the existing hole where the original socket is. For some reason I thought they would be the same size. Am I now drilling out a bigger hole in the terminal plate?
    I just installed the RDO-194's, can't wait to get these speakers back up and running.
  • chandler9a
    Okay great, thank you.
    F1nut Posts: 52,000
    Ah yeah, you've got to make the hole bigger.
  • teekay0007
    teekay0007 Posts: 2,288
    That's what she said....
    S'cuze me!
  • chandler9a
    At this point I may as well do the binding posts while I'm in there, this rabbit hole just gets deeper. It's one of the few mods I've never done on SDA's
    pitdogg2 Posts: 27,319
    chandler9a wrote: »
    YES NO BRAINER!!
  • verb
    verb Posts: 10,176
    chandler9a wrote: »
    Jump in dude! Check out my thread:
    http://forum.polkaudio.com/discussion/179960/another-1c-upgrade-path/p1
  • chandler9a
    I have hooked everything up and all seemed well until i did the balance test and when I put it all the way to the left, I get sound from the stereo drivers on the right. If my memory serves me, I should only be getting sound from the dimensional drivers on the opposite side.
    Furthermore, I am still getting more output on the left speaker dimensional drivers than I am the right. I will have to get in there and make sure all MW's are wired up correctly but I thought the Nuetriks would have solved this problem.
    Any suggestions?
  • codycatalist
    chandler9a wrote: »
    Any suggestions?
    Sounds like an internal wiring issue, do the stereo drivers have colored wires attached or black and white? Last I opened my SDAs the black/white was the stereo driver wires, colored was dimensional.
  • chandler9a
    Yes, I checked and the black and white are the stereo drivers on both sides.
    I just tried it without the interconnect and the right channel does the same exact thing either way. Could there be something wrong with the crossovers?
  • westmassguy
    westmassguy Posts: 6,850
    Blade/Blade SRS-2, 3rd generation? If so, verify the ground leads on the stereo and dimensional woofers are correct. Some had Black/Green for the Stereo Harnesses, and Blue/Green for the Dimensional harnesses. Some had Black/White for stereo and Blue/White for Dimensional. Some even had Black/White for Stereo, and Blue/Green for Dimensional. The point is, the grounds or neutrals are different for each harness. If they're mixed up for some reason, the crossovers won't work properly.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • chandler9a
    westmassguy,
    These are actually SRS 2.3's non-TL. I tried to get in there today and take a good look at all of the wiring but I had my apprentices with me, ages 3 and 6 months and I just couldn't get all I wanted done. So, after bedtime, I will try to see whats going on.
    chandler9a wrote: »
    westmassguy,
    Go get the wiring schematic from the vintage speaker area. Should be pretty self explanatory but i myself have fouled it up once or twice.
