Two Question on 11TL's
CGTIII
CGTIII Posts: 1,266
Last week I picked up a very nice pair of 11TL's nearby for $100. :-)
No damage or serious scratches. All drivers working and appear original. Case tight. Grills good and excellent. Crossovers look good for original.
1) Are these drivers subject to magnet shift so I should Loctite them?
2) Would they benefit by adding batting? If so, how much, what shape, and where?
Thanks in advance.
Boston - CR7, CR6s, CR4s.
​Thompson Adventures, Inc.
  • westmassguy
    westmassguy Posts: 6,850
    Yes, they are susceptible to magnet shift. All the original MW65** original woofers appear to be.
    There should already be Dacron Batting in the upper section behind the woofers.
    They do benefit from adding BH5 or Sonic Barrier on the back wall.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    pitdogg2 Posts: 27,650
    Adding to Dave's post.
    A little BH5 or Sonic Barrier goes a long way. Just behind the woofers.
  • CGTIII
    CGTIII Posts: 1,266
    My (admittedly limited) understanding is the two woofers in 11TL's are passive. You don't mean behind the mid-woofers then. You mean below the batting behind the mid-woofers to the bottom? Only on the back wall or back and sides? Or back, sides, and bottom?
    Thank you again.
  • westmassguy
    There are only two woofers in the 11tls, and two passive radiators. The BH5 or Sonic Barrier should be applied to the back wall. There's internal bracing, so a couple of 3" X 6" or 4" X 7" wide sections behind the two woofers is plenty. See what fits. Doing the sidewalls may over-damp the enclosure. You just want to catch some of the reflected back-waves, not suck the life out of the music. The bottom section, behind the passives should be completely empty.
  • CGTIII
    CGTIII Posts: 1,266
    edited May 2017
    There is batting to the top and upper sides of each MW. I'll put Sonic Barrier on the back and Rope Caulk EVERYTHING.
    Thanks again.
    (Just kidding about the rope caulk! LOL)
  • westmassguy
    CGTIII wrote: »
    Thanks again.
    Great. Rope Caulk NEVER.
  • CGTIII
    CGTIII Posts: 1,266
    edited July 2017
    Batting back in place. Sonic Barrier installed. MWs glued.
    Bass is definitely tighter. Thank you all.
    They still seem bass-forward though. Tweeters are definitely working. Is that the nature of 11TLs?
    I suspect they're actually treble-diminished due to 25 years of crossover degradation. What say the experts? Could there be another reason?
  • codycatalist
    codycatalist Posts: 2,661
    CGTIII wrote: »
    I'm no expert but my 11TLs never seemed bass forward and the treble laid back, that is with the stock crossovers as well. Could be an issue with the crossover.
  • stevep
    stevep Posts: 364
    Any difference between the two speakers? One of my original tweeters was much louder than the other and followed the tweeter on a swap. New RD0-198 tweeters fixed that problem.
  • skrol
    skrol Posts: 3,483
    I always found that the bass integrates well with the rest of the RTA-11TL.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • CGTIII
    CGTIII Posts: 1,266
    edited August 2017
    FLAC file through a FiiO DAC sounds rich. Still seems mid-bass forward though on Yamaha Pure Direct mode (RX-V671.) May just be the nature of the beast (and being spoiled to the 10As. :-) ) Switching to Straight Mode so the M&K kicks in balances it out -- even with the receiver crossover down to 40 Hz.
    Post edited by CGTIII on
