Monitor 7B upgrades
F1nut
Since I decided to keep these of course I had to upgrade them. Pretty much the standard crossover mods, but with all point to point wiring. I removed the fuse and used a 4.7uf in place of the 4.5uf to compensate. I also upgraded the chassis wire and terminated them with gold plated copper fastons. In addition, I installed new binding post plates from Trey, hence the fuse removal, along with new binding posts and a full set of Larry's rings.
I noticed afer I drilled out the rivet attaching the fuse holders to the plate and removed them that the two wires coming off the holders has serious oxidation, which has to affect the performance. If you are considering upgrading your binding posts you should address this issue.
The new stuff.
Close up.
New plates and posts.
This is one of the fuse holders. Pretty bad oxidation.
I forgot to mention......I love the smell of solder at midnight.
The new stuff.
Close up.
Nice.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Pretty boards. Uncle Jesse once again impresses with clean and professional work.
Great looking work!
Very clean, very nice!"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Nice, Jesse.
What kind of wire do you like for the chassis wire upgrades?I disabled signatures. -
Great looking work!
This guy has no idea what mediocrity is. It all been stellar that I have seen. -
I will buy them, what no longer for sale? They look good nice work definitely keepers enjoy the fruits of your labor!Home Theater
I agree, well executed F1. I 2nd the question on wires. Also any wall foam or extra dacron that you prefer?Don't take experimental gene therapies from known eugenicists.
Very nice Jesse. I've recommended removing the old fuse blocks for some time. I don't compensate downstream however.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Just some nice stranded copper speaker wire, much better than stock, but nothing special.
I though the about adding some BH5, but there's so much Dacron in there already I decided against it.Political Correctness'.........defined
President of Club Polk -
Since I lost the model and serial numbers when I replaced the binding post plates I came up with the following. I laminated them before attaching with 3M double sided adhesive sheet material. I think they are happy to have their identity back.
See! What you've done there is make me want these fab speakers even more. They look great Jesse.2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
Very nice work!
Nicely done Jesse.
Clean. Elegant. -
Nice work Jessie
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Looking good- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Nice I miss mine. Is @cincycat13 still around? Maybe he will sell them back to me...._________________________________________________
Just reading this thread makes me wanna go dig out mineJC approves....he told me so. (F-1 nut)
Nice! Very clean.
I'm thinking about upgrading my Monitor 7C's with new tweeters and a crossover rebuild. They still sound pretty good, but are around 30 years old so I figure it's time.
Can any of you who have upgraded tell me what improvement I should expect? Compared to some nice systems I've listened to, my modest system has a bit less separation and more sibilance. Some recordings can sound a bit harsh; I think the tweeter replacement should help that by balancing out the treble.
Thanks. -
What you can expect is an overall improvevent in the sound. A broad stroke, but none the less the truth. Definitely replace those tweeters.Political Correctness'.........defined
Great job...A classic all around nice sounding speaker. I bet the mods paid off. Enjoy.
