Monitor 7B upgrades
F1nut
F1nut Posts: 51,872
edited March 2017 in DIY, Mods & Tweaks
Since I decided to keep these of course I had to upgrade them. Pretty much the standard crossover mods, but with all point to point wiring. I removed the fuse and used a 4.7uf in place of the 4.5uf to compensate. I also upgraded the chassis wire and terminated them with gold plated copper fastons. In addition, I installed new binding post plates from Trey, hence the fuse removal, along with new binding posts and a full set of Larry's rings.
I noticed afer I drilled out the rivet attaching the fuse holders to the plate and removed them that the two wires coming off the holders has serious oxidation, which has to affect the performance. If you are considering upgrading your binding posts you should address this issue.
The new stuff.
Close up.
New plates and posts.
This is one of the fuse holders. Pretty bad oxidation.
I forgot to mention......I love the smell of solder at midnight.
  • vmaxer
    vmaxer Posts: 5,120
    Nice.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Pretty boards. Uncle Jesse once again impresses with clean and professional work.
  • K_M
    K_M Posts: 1,631
    Great looking work!
    heiney9 Posts: 25,482
    Very clean, very nice!
    msg Posts: 10,452
    Nice, Jesse.
    What kind of wire do you like for the chassis wire upgrades?
    pitdogg2 Posts: 27,151
    K_M wrote: »
    Great looking work!
    This guy has no idea what mediocrity is. It all been stellar that I have seen.
    gudnoyez Posts: 8,169
    I will buy them, what no longer for sale? They look good nice work definitely keepers enjoy the fruits of your labor!
    xschop Posts: 5,247
    I agree, well executed F1. I 2nd the question on wires. Also any wall foam or extra dacron that you prefer?
  • westmassguy
    westmassguy Posts: 6,850
    Very nice Jesse. I've recommended removing the old fuse blocks for some time. I don't compensate downstream however.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    F1nut Posts: 51,872
    Just some nice stranded copper speaker wire, much better than stock, but nothing special.
    I though the about adding some BH5, but there's so much Dacron in there already I decided against it.
    F1nut Posts: 51,872
    Since I lost the model and serial numbers when I replaced the binding post plates I came up with the following. I laminated them before attaching with 3M double sided adhesive sheet material. I think they are happy to have their identity back.
  • HzTweaker
    HzTweaker Posts: 1,000
    See! What you've done there is make me want these fab speakers even more. They look great Jesse.
  • Faustin
    Faustin Posts: 1,151
    Very nice work!
  • tonyp063
    tonyp063 Posts: 1,135
    Nicely done Jesse.
    Clean. Elegant.
  • machone
    machone Posts: 1,561
    Nice work Jessie :)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    VR3 Posts: 29,487
    Looking good
  • Ricardo
    Ricardo Posts: 10,634
    Nice I miss mine. Is @cincycat13 still around? Maybe he will sell them back to me....
    SOPA
  • george daniel
    george daniel Posts: 12,096
    Just reading this thread makes me wanna go dig out mine
  • Kilgore
    Kilgore Posts: 4
    Nice! Very clean.
    I'm thinking about upgrading my Monitor 7C's with new tweeters and a crossover rebuild. They still sound pretty good, but are around 30 years old so I figure it's time.
    Can any of you who have upgraded tell me what improvement I should expect? Compared to some nice systems I've listened to, my modest system has a bit less separation and more sibilance. Some recordings can sound a bit harsh; I think the tweeter replacement should help that by balancing out the treble.
    Thanks.
    F1nut Posts: 51,872
    edited March 2017
    What you can expect is an overall improvevent in the sound. A broad stroke, but none the less the truth. Definitely replace those tweeters.
  • Conradicles
    Conradicles Posts: 6,357
    Great job...A classic all around nice sounding speaker. I bet the mods paid off. Enjoy.
