Personal Home Theater build, updated whenever
gutted the room, knocked down the chimney, in wall home theater rack, framed for future 70" TV, in ceiling center and surrounds, Definitive BP8060ST mains with Atmos tops, no electronics selected gxspakcim5ty.jpg
«1345
  • skrol
    skrol Posts: 3,338
    The third pic looks like a scene from an Arnold movie.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    VR3 Posts: 28,040
    I'd like to have Arnold, me and two other Sledge hammers and about 6,000 pounds of bricks!! :P
    Looking good @VR3
    Glad to see your still around, even if your just being the creepy neighbor lurking in the shadows and peeking in the windows occasionally :smile:
  • mrbiron
    mrbiron Posts: 5,711
    Sheetrock hoist....possibly one of "the" best purchases i have ever made at a whopping $120.
    WHat are your plans with Mr. Pole?
    Do you have poly on top of your kraft faced insulation? That's an extra step which isn't necessary.
    MO FOTOS PEAS!!!
    VR3 Posts: 28,040
    edited September 2016
    I am actually remodeling my kitchen at the same time and there is to be a corner separating the rooms that was removed. That pole will be moved, it's just temporarily placed right now n but will be placed going through a future bar/table then encased in random rock out some type of veneer.
    The way my house is framed, it doesn't really allow the Kraft faced insulation to form a vapor barrier, Lots of oversized cavities, undersized cavities, boards ruining at angles, etc etc so I cut slits in the facing and simply applied a 6 mil barrier through the whole room. Excessive but it works
  • mrbiron
    Kitchen....i thought you did your kitchen already?
    There can't be much left in that house to change...
    VR3 Posts: 28,040
    I had never really updated anything in the kitchen beyond some minor wood working and paint.
    In the kitchen, I relocated the master bedroom door from being in the kitchen to the hallway, then I used that old doorway to frame in a pantry. The washer and dryer use to be in the kitchen in a little room, I tore out the room and moved those appliances to the back of the house where there is a perfect spot for them.avo4if66cbig.jpg
    In the master bedroom I sealed off the old closets then built new master closets in the bedroom. Those old master closets, I punched out the wall another 10" in the living room and will make that a coat closet and half bathroom.
  • scubalab
    scubalab Posts: 3,101
    Love the tile work Trey!
    I built an in-wall equipment rack in our HT and love the space savings!
    Also, all I could think of when I saw the fourth pic in your first post was this:
    https://www.youtube.com/watch?v=Ar6xC8KM-jk
    Oh YEAH!
    Keep up the good work and keep the pics coming!
    VR3 Posts: 28,040
    Slowly making progress - once I have the sheetrock up on the right wall, will be moving back into the kitchen area...
    My right shoulder is still recovering from the accident and those 5/8" sheetrock sheets are killing meb0a4xg5nbbsd.jpg
  • lightman1
    lightman1 Posts: 10,776
    Looks good, Trey. The fireplace chimney is gone?
    nooshinjohn Posts: 25,100
    Hope it's not too late on the framing... I would increase the opening for the tv to take a 75 inch panel. Nobody is going to produce 70" anymore. Just heard this last week while shopping with my wife for a new tv in the living room.
    VR3 Posts: 28,040
    Hey Russ! Are you still in NC? We need to grab a drink or something! Yes! That 10,00 chimney is gone, level earth where she once stood!
    Thanks guys! :)
  • oldrocker
    oldrocker Posts: 2,590
    Looking good!!!
  • honestaquarian
    honestaquarian Posts: 3,186
    How many pairs of Def Techs do you have??
    Looks like you're opening a showroom ;)
    VR3 Posts: 28,040
    Thanks guys :)
    I have a pair of the 2000, 2002, 2006. I'm fixing up the 2002/2006 currently, new socks, refinished caps, changing filter caps on amp, binding post, removable power cord, crossovers, dynamat sub baskets
    VR3 Posts: 28,040
    This little guy is impressive...
  • scubalab
    Nice progress Trey!
    VR3 Posts: 28,040
    so this was actually part of the house remodel... getting tools to a place... disregard the mess, had to throw things back in before night fall hehe
    VR3 Posts: 28,040
    I have been procrastinating quite a bit on this due to corner bead. I did a lot of research and had a hard as heck time finding one of the three wide leg corner beads I found in my research. The one place I found happened to have like 60 pieces of it from an order like 5 years ago that was never picked up... lucky me!
    But I freaking love it, will be very hard for me to use standard metal corner bead again... mjudobmg7t5w.jpg
  • mrbiron
    HOLY HELL!!! The screws!!!!
    Did you do a load calc on the structure before installing that much metal? An easier way to install cornerbead is a staple gun.
    Just an FYI ;)
    Hurry up!
  • lightman1
    mrbiron wrote: »
    Just an FYI ;)
    Hurry up!
    Frederique...... I have personally helped the lad reframe a lot of that house. After seeing the amount of course thread screws he used, I bought hot stock in the manufacturer. I flipped it two months later at about 450%.
    Dude has a fastener fetish......
    EndersShadow Posts: 17,533
    edited July 2017
    He just likes scre-wing..... he's recently married and a man... so did you expect anything less @lightman1 @mrbiron
    VR3 Posts: 28,040
    Hahaha...
    My house was built in 1903... as such... it is as out of round, out of square, out of level as they come... and staples just wont cut it.
    I also don't want any popped joints due to an infinite baffle subwoofer :p
    ^Only one thing gonna be "popping" in that room.... and it aint no joints lol
    treitz3 Posts: 18,333
    Trey's motto when it comes to screws?
    If it requires one, place 20 in and around the same spot just to make sure.
  • lightman1
    treitz3 wrote: »
    ^^^^this is a true statement. Don't forget the two tubes of liquid nail on every corner post set or cabinet shelf.
    Did he say "NAILED IT" each time? :wink:
    VR3 Posts: 28,040
    hahhaha!
    You guys are a riot.
    Tom... I'm gonna call you in for an inspection on the rock before I prime... just saying... :p
    edited July 2017
    Trey... can I throw an idea out at you? Your room is PERFECT for this concept......
    Instead of artwork in the middle imagine its your TV
    IMG_0524.JPG?psid=1&width=319&height=240
    IMG_0578.JPG?psid=1&width=319&height=240
    That way you can install a nice PJ in ceiling to use at times (when good movies are playing) while using the 70" TV for normal stuff to save your PJ bulb...
    VR3 Posts: 28,040
    Nah, no projector for me. Too many windows, door is in the way of where the projector would go... cool concept though!
