Nippon Chemicon or Nichicon?
24
    heiney9 Posts: 25,492
    daddyjt wrote: »
    My advice to the OP was rooted in physics and the electrical principals of amplifier design, and the interest of not having him or her spend additional money on parts that will not yield a measurable sonic improvement.
    Except you can't generalize like that. Any amp designer worth their salt will tell you the best sound is achieved by paying close attention to the power supply design. It can make or break any piece of gear.
    P.s. I agree for his particular piece of gear and his situation get some nicer caps and be done. But you dismissed ALL power supplies as not having any effect on the final sound............and that's not true.
    edited February 2017
    DSkip wrote: »
    Backert Labs is essentially founded solely on the power supply they developed.
    Most if not all higher end companies pay very close attention to the power supply section.
    Yes, probably took this farther than needed for the OP as an older receiver probably won't benefit for ultra pricey caps. But, just wanted to point out there are instances where it is very important and audible differences can be heard by updating the power section.
  • daddyjt
    daddyjt Posts: 3,127
    heiney9 wrote: »
    The largest cost of a high end components is the power supply section, so if your statement is fact
    What I can tell you, it's that from a physics standpoint, there is no audible link between the power supply and the sonic charachteristics of an amplifier
    Why would they spend all that money on the power supply section. This is especially true for digital playback gear like DAC's and CDp's, etc.
    The cost of the power supply is irrelevant to the proposition that "audio grade" capacitors make a difference in it. They spend "all that money" because transformers and large filter caps are expensive.
    BTW, you cut my quote short - the rest or it was stipulating that the supply was producing specified voltage and current, with under spec ripple.
    ― Aleksandr Solzhenitsyn
    Sorry about cutting it short, in all my examples I asked about the specified voltage and current were in spec.
    And you didn't say anything about caps, you said;
    What I can tell you, it's that from a physics standpoint, there is no audible link between the power supply and the sonic charachteristics of an amplifier.
    Which infers you are talking about anything in the power supply, not just caps
    Yes, big trannys are expensive......but beyond on a big tranny they pay special attention to rectifiers, regulators, didodes and even the resistors used in the power supply because it does influence the final sound.
    Inexpensive switching supplies are all in spec to make the gear perform, but they sound pretty bad compared to the same piece of gear with a properly designed linear power supply.
    xschop Posts: 5,347
    Well, maybe I should have mentioned this is my kitchen/dining rig. If I really wanted ultimate clarity and soundstage while whipping up my favorite Mexican dish, I would hire a live mariachi band.
  • daddyjt
    heiney9 wrote: »
    I'm sorry, I thought this thread was about capacitors...?
    Yes, I know what goes into a power supply - and as I stated, aside from the transformer, the gain stages use more expensive, and tighter spec parts. Most power supplies use 5% resistors and 20% caps, while most amp boards use 1% resistors and 10% caps.
    Look, I am not trying to overcome your expectation bias with science and measurable charachteristics - as I said previously, if it sounds better to you, great. I was simply explaining to the OP that there is no measurable benefit to spending more money on "Audio grade" capacitors in the power supply. Period.
  • daddyjt
    xschop wrote: »
    I apologize that your thread has become hijacked, and your light-hearted approach to our diatribe is appreciated. Your LED mod looks great, btw :smiley:
    daddyjt wrote: »
    I was simply explaining to the OP that there is no measurable benefit to spending more money on "Audio grade" capacitors in the power supply, In My Opinion.
    Fixed it for you
  • daddyjt
    heiney9 wrote: »
    daddyjt wrote: »
    Fixed it for you
    Ok, I'll bite - what specifically is the measurable benefit? Because if you cannot provide a measurable benefit, then it's not "my opinion" that there is no measurable benefit.
    xschop Posts: 5,347
    No, you are in the right, as my first post asked for opinions and experiences.
    And my replies can be facetious. I've only become sarcastic since joining this forum however..hehe.
    xschop Posts: 5,347
    Doubtful, but at that point I would simply cease to participate.
    Although I'm not showing my custom CRS build...
    They're not forum friendly.
    F1nut Posts: 51,944
    daddyjt wrote: »
    heiney9 wrote: »
    daddyjt wrote: »
    Fixed it for you
    Science can't measure things such as sound stage, imaging, etc., so while measurements play a role they do not tell you everything.......far from it.
  • lightman1
    lightman1 Posts: 10,797
    xschop wrote: »
    Trouble maker!
    I hearby declare your new screen name to be..........
    Wait
    Here it comes......
    xschop-capri!!!
    Who's yer Daddy???!!!
    xschop Posts: 5,347
    ???...did someone forget to take their scripts?
  • lightman1
    xschop wrote: »
    Yes
  • K_M
    K_M Posts: 1,631
    daddyjt wrote: »
    heiney9 wrote: »
    daddyjt wrote: »
    Fixed it for you
    Nor are you able to definitely provide proof of many things you claim to be able to hear or differentiate when telling about them on the forum.
    Does that mean your anecdotes are not real, or simply expectation?
    Imaging and sound stage are not Directly measurable yes, as they occur within the listeners mind, just as how bias and expectation do.
    txcoastal1 Posts: 13,519
    ^^^Nor can you debate what we hear or don't hear.
    I've offered demonstrations and was never taken up on them. Even at a public venue.
    K_M wrote: »
  • K_M
    K_M Posts: 1,631
    heiney9 wrote: »
    K_M wrote: »
    Hey! Don't use my own GIF against me..... ;)
    xschop Posts: 5,347
    Guess we'll never hear a definitive answer from the horse's mouth.
    K_M wrote: »
    If the GIF fits......................
    F1nut Posts: 51,944
    K_M wrote: »
    daddyjt wrote: »
    heiney9 wrote: »
    daddyjt wrote: »
    Fixed it for you
    I can provide proof, I experienced it therefore it is. You have absolutely no way to prove otherwise. Pretty obvious you're the one with bias issues around here.
    I have a question for you. Don't you ever get tired of failing?
    xschop Posts: 5,347
    How do you guys discharge the large capacitors and live to tell about it?
    xschop wrote: »
    :p
    Just kidding, crappy insulated screw driver and short it, yes it will pop and likely leave a couple char marks
  • ken brydson
    ken brydson Posts: 9,016
    txcoastal1 wrote: »
    You forgot the part about standing in a bucket of water...
  • daddyjt
    xschop wrote: »
    Shorting can damage traces on the pcb. I use a 150w incandescent light bulb - short it with the bulb in series, only takes a couple seconds.
  • Unknown
  • ken brydson
    Yep2 wrote: »
    Discharge with a piece of spkr wire to ****.
