time for more Joule Electra
135
  • WagnerRC
    WagnerRC Posts: 2,202
    The peak voltage is 88 and can be reduced down for a more laid back sound. The bias can go back some too, and The feedback is way adjustable. break out the marshmello'a2vb8dga7t42.jpg
    s
  • WagnerRC
    Yep2 wrote: »
    DSkip wrote: »
    Careful man. Are they actually intended for variation? Normally the tubes are optimized to have those settings fixed. My 845 SET amps do have adjustable setting that aren't for biasing the tubes, but I'm not sure about yours.
    Blow that first picture up.
    Recessed panel with knobs.
    I can do that tomorrow. That is the eight bias adjust buttons and pots.
  • dhart86
    dhart86 Posts: 1,594
    Bob , did you get a manual with the amp?
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
    pitdogg2 Posts: 27,032
    WagnerRC wrote: »
    s
    Reminds me of jack o lanterns in the distance...
    Very nice
  • WagnerRC
    dhart86 wrote: »
    Yes I did complete and more.
  • WagnerRC
    I can try to do a PDF recreate of the manual this weekend , time allowing. Thanks for the warming Skip. I wa very Leary making adjustments at first. Jud did a hell of a job spelling out the do!s and Don'ts . I would to have loved to met Jud andMarianne in person. He is quite a guy as far as I can tell.
    tonyb Posts: 33,072
    edited February 2017
    DSkip wrote: »
    I would second that thought. Normally tubes have a small range to work in when adjusting bias. Anything too much shortens their life and given the amount of tubes you have in there, might get costly.
    I might also suggest if you plan on keeping that beauty, a small investment in a tube tester should be your next purchase.
    Judd was also very specific in his manuals, a trait not often seen with today's electronics, as Bob pointed out. It helps immensely, so you don't make costly mistakes. It only reaffirms that the man put as much detail and attention into building his products as he did in his manuals.
  • megasat16
    megasat16 Posts: 3,521
    What's Joule Addiction? All the time, I am only thinking we have Joey Addiction and his new audio ****; etc. :smiley:
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • WagnerRC
    I would never exceed the voltage limits or the peak bias settings. You can reduce to change the sounds produced.
  • WagnerRC
    Yep2 wrote: »
    DSkip wrote: »
  • erniejade
    erniejade Posts: 6,321
    His amp goes to 11 !!
    tonyb Posts: 33,072
    erniejade wrote: »
    LOL...INDEED, top end....unlimited.
    Those are a working man's hands Bob.....or a collector for the mob. :)
    tonyb Posts: 33,072
    Bob, I hope your listening on a Sunday to that amp. Put up some impressions/comparisons will ya....I've been changing shorts every day waiting for your thoughts. F1NUT even combed his hair waiting, Russ shaved, and Brock already has a lineup of tubes for you to roll.
  • WagnerRC
    Pass amp is back on line. I believe I had a power tube fail. I was getting some static/hum out of the right speaker. Then the volume shot up and the pre amp had no control and I had to pull the plug. I don't know how old these tubes are but I have some tubes coming next week anyway. This was an odd failure as I had no control and no fuses blew. The voltage was was less than 86 and I started to check the bias when it all went wrong. No damage and the Pass is working well.
  • erniejade
    Ouch. I'm glad you didn't get any speaker damage.
  • WagnerRC
    I guess you can't test the power tubes with a multimeter. I will have try something else. Tony you mentioned a tube tester should be my next investment. Do you have a recommendation? I would like the option of testing the array of tubes being used. Thanks
    txcoastal1 Posts: 13,511
  • vcwatkins
    vcwatkins Posts: 1,993
    Please put me in line.
    Thanks,
    Craig
    tonyb Posts: 33,072
    Most of them do a good job Bob, the one Ron mentioned should suffice. I brought it up because of the amount of tubes you have in all the gear. It's a worthy investment especially with tube amps to save you from those situations you just experienced. Plus when or if you buy used tubes from someone, you can test them pronto and have that opportunity to send them back if they don't cut the mustard. Good tubes aren't cheap, you want that option instead of waiting 3 months before you try them out and can't return anything.
    The old "ounce of prevention is worth a pound of cure" thing. :)
    Still no thoughts ??
  • kharp1
    kharp1 Posts: 3,453
    If I'm not mistaken, I think the fuses in most tube amps are designed to blow on a dead short only.
    tonyb Posts: 33,072
    Sounds good Bob, only one song though sounded good ? lol Tell us how the new baby compares to the old. Strengths, weaknesses...
  • mikeyb128
    mikeyb128 Posts: 2,885
    I will get my hands on an xa30.5 one day. Or something bigger!
    2 channel:
    Theater:
    tonyb Posts: 33,072
    mikeyb128 wrote: »
    Yeah right....last time I said I wanted something bigger I got married. lol
  • WagnerRC
    I am very happy with both amps and both pre's. The tubes have greater detail and a wider stage. The pass amp is easy to use and sounds fantastic. I really have not spent enough time listening to both combination.
    I really like tubes for detail and I like the ss for turn it on and go.
    When I get this joule vzn back up and running I can give a better detail. I am just finding out what tubes were sent with this amp
    The 6dj8's are amperex ecc88's The 5751 are GE and the 6350's are Calvertron??
    I am not sure what tube(s) caused the issue yesterday.
    The 6c33 looks like a tough tube to test.
    More to follow.
  • Yep,, not the easiest tube to test. Did you happen to notice if any of the tubes red plated?
