SENCORE TC28 "THE HYBRIDER" Vacuum TUBE TRANSISTOR TESTER
snow
For sale is a used and working SENCORE TC28 "THE HYBRIDER" Vacuum TUBE TRANSISTOR TESTER I tested a few tubes on this to be sure it worked and it seems to work fine, I did not test any transistors but no reason to assume that it does not work for them too.
I have enough tube testers as it is and this one just sits around collecting dust and taking up space it would make a great tester for someone that needs to check out a few tubes every so often and it appears to test most commonly used types and is very simple to use.
$125.00 + shipping
It is a heavy little beast so likely shipping will be a fair amount.
Regards Snow
$125.00 + shipping
Regards Snow
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Snow would this work for @WagnerRC
http://forum.polkaudio.com/discussion/175992/time-for-more-joule-electra#latest2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Sold and I can add this to the tubes we dealt with today. Thank you
Glad it worked out for you guys
Thumbs up
Your welcome I will send you a total when I get it packed up.
Regards sNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Apropos of nothing: I've never seen this particular Sencore before -- cool & interesting piece from the 'transitional' era. Sencore made excellent "service-person" grade test equipment.
WagnerRC, it should be a good, rugged, dependable emissions-type (tube) tester. Presuming it has the heritage of Sencore's Mighty-Mite testers, it should have excellent sensitivity to test grid leakage.
Hey Mark I have something you may be interested in.
Regards SnowWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Hi Mark per your request here are a couple of pics of the inside.
Thank you very much, sir!
