What is the largest center channel speaker?
I just bought (thru Amazon) a Polk Audio CSI A6. It is 24 inches wide by 14 inches deep and about 8 inches high. A Very large center channel! But, is it the largest mass production center channel speaker ever produced? No!
The Klipsch RC-64 has four 6.5 inch mid-range/woofers plus a horn tweeter. It is a little over 35 inches wide and 13.25 inches deep. Is the RC-64 the largest center channel? I have not seen a larger center channel.
The RC-64 also costs an arm and two legs while the CSI A6 only costs an arm.
  • vmaxer
    vmaxer Posts: 5,120
    edited February 2017
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Nightfall
    Nightfall Posts: 10,084
    Axiom VP180 is almost 40" wide near 60 pounds
    http://www.axiomaudio.com/vp180-center-channel-speaker
    afterburnt wrote: »
    Village Idiot of Club Polk
    VR3 Posts: 29,397
    Definitive C/L/R 3000 is up there - dual 6.5" with a 10" subwoofer (powered)
    VR3 Posts: 29,397
  • daddyjt
    daddyjt Posts: 3,038
    Legacy Audio Marquis - dual 15" drivers!
    ― Aleksandr Solzhenitsyn
  • BlueFox
    BlueFox Posts: 15,251
    Nightfall wrote: »
    I might have to buy this. I have half-way been looking for a new center.
  • daddyjt
    Yep2 wrote: »
    Klipsch dual 8" w/tractix horn.
    Model # escapes me?
    It was HUGE!
    It's the RC 7 - the center of the Reference "7" line up. I run the full Reference 7 set in my HT. Very beefy center indeed...
  • Unknown
    pitdogg2 Posts: 26,958
    daddyjt wrote: »
    Seen it heard it SERIOUS center blow your well you know WHAT back.
  • boston1450
    boston1450 Posts: 7,758
    I have been more than happy with the Polk Cs1000p. I got it adjusted to where I like it-just recently & it does the job just fine. The subs are adjusted to pleasing bass right at you. I'm not too bass needy or I'd add a decent sub. But with SDA's why bother :) You can put a 55 inch tv on it if needed & do yourself a favor & don't move it often cause it is frign heavy
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    tonyb Posts: 33,068
    daddyjt wrote: »
    OOOH, That's my baby right there. One day gents....one day.
  • Thorton
    Thorton Posts: 1,324
    31.5W x 13D x 12H Salk Soundscape 7C. 86 lbs of sweet Salk sound and it's in my entertainment center and sounds fantastic.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • lawdogg
    lawdogg Posts: 468
    I have a Klipsch KV4 in the garage, two 8" woofers with a horn in the middle just like that one above. Came with a pair of Forte IIs. One of the rubber surrounds is torn though, gotta figure that out. Don't use center channels not sure what to do with it!
    Biggest? This guy built a pretty large one ...
    http://www.audioheritage.org/vbulletin/showthread.php?39208-My-JBL-4355-Homecinema-Soundbar-build
    Post edited by lawdogg on
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • Gatecrasher
    Gatecrasher Posts: 1,550
    If you are talking about the largest center speaker Polk has ever made, it is probably the CS1000p as far as physical size goes.
    CS1000p Specs:
    Size: 34"W x 14"D x 8.6"H
    Weight: 60lbs.
    Power Handling: 20 Watts to 250 Watts
    But if you are talking about the baddest center speaker Polk ever made it has to be the SRT center speaker.
    SRT Center Speaker Specs:
    Size: 26"W x 17.5D x 6"H
    Weight: 40lbs.
    Power Handling: 100 Watts to More than 1,000 Watts
  • I think I have the SRT series speaker. Bought new in 1996 ish. It has opened where there were seams. Is this under warranty? Thank you for the support.
    This channel rocked and wud hurt ears < 15' away alone. POLK POWERED HOME. lr4bktrexegh.jpg
    F1nut Posts: 51,695
    No.
