How Important is Imaging to You?
124
    heiney9 Posts: 25,488
    SDA fixes what
    K_M wrote: »
    heiney9 wrote: »
    In real life there is no such thing as Stereo. It was a contrived way to make music sound more realistic. SDA's are a closer approximation to real life. If you research both methods in depth, you will agree.
    Neither is going to recreate or substitute for a real life event, but stereo is horribly flawed in that regard.
    No, wrong again. SDA is simply an effect that was marketed as being "more real", when in reality if you read the marketing stuff closer, you would know it does not approximate how real recordings are ever made. That is the glitch in their explanation of this fun effect.
    The marketing makes some assumptions with reality of actual recordings and how recordings are made, and then presumes to fix a problem that in reality does not occur in hardly any recordings.
    WRONG! It's not trying to fix the recordings, it's fixing the playback environment more specifically stereo. You really don't have a clue.
    SDA isn't an "effect" it's an analog way of reducing a naturally occurring aural phenomenon. has nothing to do with creating music or recording music.
    Get a clue, please, before you come here and act like you know what you are talking about
  • K_M
    K_M Posts: 1,631
    edited February 2017
    heiney9 wrote: »
    During two-channel stereo recording, two microphones are placed in strategically chosen locations relative to the sound source, with both recording simultaneously. The two recorded channels will be similar, but each will have distinct time-of-arrival and sound-pressure-level information. During playback, the listener's brain uses those subtle differences in timing and sound level to triangulate the positions of the recorded objects. Stereo recordings often cannot be played on monaural systems without a significant loss of fidelity. Since each microphone records each wavefront at a slightly different time, the wavefronts are out of phase; as a result, constructive and destructive interference can occur if both tracks are played back on the same speaker. This phenomenon is known as phase cancellation.[/i]
    Problem is you copied and pasted marketing speak about the SDA effect.
    Use you own words.
    First off, 95% of recordings are NOT made in the way they describe, with 2 microphones...etc.
    They are made with multiple mono signals that are mixed together and the final position in the sound stage is determined by the person doing the mixing, The imaging and sound stage are all done mostly electronically by using level panning, and phase adjustments in the mixing phase.
    The marketing stuff you copied does not represent reality. recordings are NOT made that way for the Nth time.
    No one dares to question this though, or does not understand how recordings have been made since the 1960s.
  • dromunds
    dromunds Posts: 10,136
    Somebody say something about whiskey?
  • Nightfall
    Nightfall Posts: 10,083
    You're changing the subject.
    afterburnt wrote: »
    Village Idiot of Club Polk
    There was no marketing speak posted in any of my posts...........wrong again.
  • K_M
    K_M Posts: 1,631
    Nightfall wrote: »
    Do places master or mix on headphones? Probably. Which is essentially what SDAs try to do more or less.
    No they do not.
    They do assure that it will still sound okay ON headphones though.
    Speakers are used. Non SDA speakers...lol
    The recording process is more involved, I understand that. I posted what I posted as a simplified, general overview of stereo. Doesn't matter if it's 4 mics or 24 mics, the end result is still stereo and it's still flawed compared to the real event.
  • K_M
    K_M Posts: 1,631
    heiney9 wrote: »
    lets please let it go at that. Not feeling well today, but you have made some great points!
    Anything is going to be flawed to the real event, too many things along the way of recording and playback color the sound. Isn't that obvious to most here ? The best we can hope for is to put together systems that play to our personal preferences and be done.
    The original question was about imaging, if you care about it, seek it out. If not, sit back and enjoy too. Not worth fighting about guys....and gals.
    Not fighting............Dad, just having an intense conversation :p . Obviously we are all passionate about audio or we wouldn't care to vigorously interact about aspects of the hobby. And written words on a board like this are easily misinterpreted, misconstrued, misread, missing detailed information that would most likely have been conveyed in a face to face conversation.
    treitz3 Posts: 20,067
    *takes another shot*
    K_M, I do have a question for you. It's a simple one and I am not being controversial here. My question is this - Have you ever heard an SDA speaker properly set up with a dent recording(s)? Yes or no will suffice.
    *hiccup*
    Decent, not dent.....whiskey is apparently working.
  • K_M
    K_M Posts: 1,631
    treitz3 wrote: »
    *hiccup*
    Well, glad you are enjoying your Whiskey!! but if you drank less you might see my sig line, showing the names of 2 SDA speakers. I
    I have of course listened to them and yes set up properly. I like them a lot. I am not bashing them.
    I simply see them as a different way of doing things, not necessarily more realistic is all.
    I get that criticizing or discussing aspects one finds less than ideal can often come off as bashing something. But that is not so in my case. I have stated several times, I really like them on some recordings. On other recordings not so much.
    But I feel that way about everything, nothing is perfect.
    When one believes something is perfect, they often become defensive of it. I find them great speakers in some regards, but not ideal in all, is all!
  • K_M
    K_M Posts: 1,631
    DSkip wrote: »
    treitz3 wrote: »
    The dent must be in the bottle eh?
    Yes
    (oops wrong guy)
  • Nightfall
    Trolling complete, time for me to move on.
    Seriously though I appreciate the insight so far. Most people here care about it, a small percentage only care about tone or listen as background music while doing other things and not really paying attention.
    afterburnt wrote: »
  • voltz
    voltz Posts: 5,384
    I like to listen with my Eyes closed so Imaging doesn't mean much to me!
  • Nightfall
    voltz wrote: »
    Come again?
    afterburnt wrote: »
  • voltz
    voltz Posts: 5,384
    Nightfall wrote: »
    voltz wrote: »
    Come again?
    sorry stupid joke :# been in a weird mood today.
  • Nightfall
    I thought so but I wasn't sure. :smiley:
    afterburnt wrote: »
  • kharp1
    kharp1 Posts: 3,453
    heiney9 wrote: »
    Which "real event" are you referring? A performer/performers playing acoustic instruments, or, instruments that have been microphoned and played through mains?
  • kharp1
    kharp1 Posts: 3,453
    dromunds wrote: »
    Col. Taylor Barrel Proof, George T. Stagg Barrel Proof...Need I say more?
    *slams down shot glass*
    Now there ya' go gettin' all "Technical" and stuff kharp1. What'z up wid'dat?
    BTW, one day I would like to ask you about your observations between your 2 main system speakers. Okay, maybe I just did. PM if you care to discuss. I'm interested in your real world experience ( I have heard many a TA but not one Usher to date).
  • dromunds
    I like Woodford Reserve, triple distilled Kentucky bourbon. Realllllll smooth.
  • gp4jesus
    gp4jesus Posts: 2,019
    DSkip wrote: »
    treitz3 wrote: »
    or in someone's head
    *all connected w/Premiere ICs
  • kharp1
    kharp1 Posts: 3,453
    gp4jesus wrote: »
    DSkip wrote: »
    treitz3 wrote: »
    Can't begin to tell you how many times I've put a major dent in the bourbon bottle and then put a dent in my head...or some other body part.
    mhardy6647 Posts: 35,171
    In honor of the anniversary of "Cowboy Neal" Cassady's birthday, I am listening to the Grateful Dead's early '80s live acoustic album Reckoning tonight -- on the (on loan) Polk Forum Special/Nelson Pass "Amp Camp Amp" driving a borrowed pair of 1960s vintage KLH Fives (there's a pattern developing here, isn't there?).
    This is a superbly recorded album -- and the combination of amp, loudspeakers and recording is insanely good sounding.
    ... and yes, I am posting this in the imaging thread for a reason. Of course, this is a live "multiple-track mono mixed to stereo" recording -- but it is an exceptionally good one, and the Fives do it justice far beyond my expectations.
    Further details as events warrant.
  • Nightfall
    @mhardy6647 I want to hear your version of insanely good. Can I buy this somewhere or can you copy it? I don't even like the Dead I just want to hear.
    afterburnt wrote: »
    You can buy it -- it's just the Rhino remastered CD (the LP rekkid sounds very good as well). I am sure there are halfway decent sounding versions even on Youtube -- maybe on archive.net too, for all I know.
    Now, finding a pair of KLH 5s... you might have to hunt around a little bit :)
    I am still listening. I am still smiling.
    https://www.amazon.com/Reckoning-GRATEFUL-DEAD/dp/B000EOTFEE
    Even a Dead hater might like this album -- it is acoustic and intimate. More Americana than -- Dead. Well, OK, the Dead and Americana were sometimes synonymous. This was one of those times.
