Where do you stream Netflix from
I'm streaming it from my brp, but have been thinking to switch to the tv. One less piece of gear which is on.
  • Ricardo
    Ricardo Posts: 10,634
    Xbox. Interface works pretty well.
    SOPA
    heiney9 Posts: 25,545
    Xbox, BRp or TV. Depends on which remote is closer.
    treitz3 Posts: 20,165
    In this house? Geez.......phone, Kindle Fire, TV, ROKU and 2 DVR's. Whatever is convenient at the time and whatever keeps the wife and kid happy. In the main LR, we generally use the TV.
  • Tv
  • Willow
    Willow Posts: 11,285
    This may sound dumb but if I wanted it through the tv and running hdmi do I need to turn on arc? Or do I need to run another hdmi out from tv to receiver?
    txcoastal1 Posts: 13,519
    Tivo
  • cfrizz
    cfrizz Posts: 13,415
    My TV. My Sony remote has a Netflix button right on it. I just press it and Netflix comes on.
    One caveat, in order to get surround sound, you have to use an Optical connect to your receiver/preamp to get the sound through your speakers.
    Unfortunately, when I was trying to move my rack to point at my recliner, I snapped the connector in the tv, so now I'm stuck listening to Netflix through the tv speakers. :s
    If anyone knows the right input to use with ICs from the TV's L,&R connectors to my Sunfire prepro, I would appreciate it.
    cfrizz wrote: »
    Ouch Cathy. Sorry to hear that. I looked up your TV connections and it looks like you are out of luck unless you have the optical out repaired. Looking at the hookup diagram here >>> https://www.manualslib.com/manual/981588/Sony-Kdl-48r530c.html?page=38#manual you can have the audio out for the headphones go to your receiver (will need an audio jack to IC adapter) but this may introduce a slight time delay in sound to picture. Only way to find out is to try...I am pretty sure you can pick up an adapter at Amazon for a few bucks.
    You might possibly use a Blu-Ray player or CVD that has a HDMI out (and is Netflix compatible) and connect it into the Sunfire pre-pro, HDMI out from that to the TV but I believe that you will have to get a HDMI switch box to switch from cable/sat and Sunfire pre-pro to the TV. Some of them do come with a remote and the cost is (or was) around 20 bucks.
    Sorry for the off topic post ladies and gentlemen.
    gudnoyez Posts: 8,174
    Bedroom Sony Google TV, Living room LG Blue ray player, Kitchen Roku stick, HT Oppo 105D, plus various laptops and tablets. I do prefer watching stuff on Blu Rays than streaming from Netflix.
  • Willow wrote: »
    @Willow
    Yes you do have to turn on the ARC in order for the sound from the TV to go back out to the receiver. I am streaming the Tune in Radio app right now from my smart tv to my pre/pro.
    I use my TiVo to stream Netflix. I just like the interface better than the TV or the Blu-ray player.
  • Nightfall
    Nightfall Posts: 10,083
    Xbox One
    afterburnt wrote: »
    Village Idiot of Club Polk
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited January 2017
    The first device that I had Netflix available through was a Blu-ray player. I swear, it took like five minutes to start up. Since then we've been using a Roku device and all is good.
  • Willow
    I tried this morning. Couldn't get it to work. The only device the tv found was chrome cast. Guess I'll just leave it through the brdp.
  • mantis
    mantis Posts: 17,570
    Master bed I stream it from the Last Gen Apple TV which I feel is the very best Interface.
    In my Family Room I have the new Apple TV which has the suck **** interface like everything else has.
    Dan
  • lightman1
    lightman1 Posts: 10,797
    Your Moms house.
  • rooftop59
    rooftop59 Posts: 8,120
    mantis wrote: »
    Yep my old third gen Apple TV was the fastest with an excellent interface. I now use amazon fire tvs on both setups and they are a close second.
    My BDP is pretty slow. If you have good wifi I would definitely get a fire stick. Much faster, and very cheap.
    Game Room 5.1.4:
    Bedroom 2.1
  • hochpt21
    hochpt21 Posts: 5,423
    Roku
    We're giving it a go before possibly cutting the cord.
  • lightman1 wrote: »
    Your Moms house.
    Yous a NASTY muthaf?&(\%****!!! :(;)
    Go on and git!!
  • Ricardo
    gudnoyez wrote: »
    Bingo. And that's why I have a Blu-ray account with Netflix too.
    SOPA
    Ricardo wrote: »
    gudnoyez wrote: »
    Yep I get Blu Rays sent through Netflix and Stream its worth the extra couple of bucks to have both services, and the 4k streaming they offer though limited is icing on the cake.
  • gce
    gce Posts: 2,158
    Roku 3 upstairs and a Roku Premiere+ downstairs. I find the picture quality, sound and speed to be better then streaming through my bdp or TV app's.
    Anaheim Hills CA,
  • mdaudioguy
    Willow wrote: »
    Not sure what you mean by "The only device the tv found was chrome cast." Are you trying to stream from an app on a smart TV?
    If so, most TVs have only one of their HDMI inputs labeled ARC. The HDMI out from your AVR must be connected to this input on your TV. You also will have to select TV as your source on the AVR. Optical out of the TV is often an easier option to setup.
  • andrew82
    andrew82 Posts: 144
    Chromecast and PS4. I prefer the PS4, seems to be better quality.
    EndersShadow Posts: 17,727
    Downstairs - Xbox (though the TV has it built in but I don't use)
    Loft - Roku 3 (though I could also use my HTPC if needed)
    Bedroom - Roku 3 (could use TV again lol)
    Portables- iPhone 6 Plus, Kindle Fire Kids tablet, Dell Venue tablet, LG Tablet
  • Willow
    mdaudioguy wrote: »
    Willow wrote: »
    The tv only found chrome cast when setting up arc. Im only using one input to the tv. The avr does the switching. So 3 hdmi in the avr and one out to tv. I may just try optical though I thought it didn't do dd+.
  • vcwatkins
    vcwatkins Posts: 1,992
    Amazon FireTV's and a Roku in town.
    Apple TV and FireTV's at beach.
    FireTV Sticks for porches.
  • mdaudioguy
    Willow wrote: »
    What model TV and AVR? What input is the Chromecast plugged into?
  • Jimbo18
    Jimbo18 Posts: 2,351
    vcwatkins wrote: »
    @vcwatkins How do you compare the Fire TV and Sticks Netflix interface with the one on the Roku? I have a couple Roku's and although they are fast, the interface is a bit dated. I haven't seen the one for Fire TV but read that it's better for listings and not as limited as the Roku.
    @Jimbo18
    What do you mean by dated? I recently upgraded to Roku 3's from Roku XS's and found the interface to be much snappier, although the same as the XS's.....
    Willow wrote: »
    mdaudioguy wrote: »
    Willow wrote: »
    Optical doesn't do DD+ or DTS HD Master audio. Your on the right track letting the receiver do the switching.
    I just use my TV for Netflix, works fine, fast, and the pic is pretty good.
    Cathy,
    Your Sunfire is pretty outdated but you have work arounds. You would need a BDP with analog outputs like an OPPO. If you want the newer surround codecs that is. For Netflix, use the app on a BDP, since your digital out is broken on the tv.
