Dreadnought Cases...........
Toolfan66
Ok here we go..
Easy enough as always, the cases are ready to go, just need boxed up..
Cases are $100 shipped just as in the past...
Please when sending PayPal Payment put in the notes what you are buying, it will make this easier with the ring thread as well..
I'm in for one.Will send you my info and payment as soon as you let me know where to send it. Thanks2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
One for me too pm payment info
Payment sent.
I'll take one. Please PM payment info.SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
RTiA3, Onkyo TX-SR605 -
Larry, I am in for two of the cases. Please PM payment info and I will get it in ASAP.
Thanks -
I see one largish hole. Forgive me but how does that work? If we need to drill our own holes for speaker terminals what would we use? A standard drill bit.
Thanks for any feed back.
I want one please
PM me with the payment info.
What about the rings? -
honestaquarian wrote: »I want one please
http://forum.polkaudio.com/discussion/175963/driver-speaker-rings-for-your-vintage-polk-sdas-monitors#latest
Keep up
I need one please. PM me payment information.Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB -
You might as well go Neutrik, everyone else has.Political Correctness'.........defined
President of Club Polk -
One case please, thanks.
Hey Brock, even if you don't want to Neutrik your speaker cabinets at this time, you can terminate your SDA cables with Neutrik on the transformer ends, with whatever terminations you prefer at the speaker end.
Working with the Neutrik is a treat.
Bonus: You get bragging rights because your SDA cables will be directional.
Jay
Sorry for polluting your buy thread, Larry, but thought I'd share an idea I had when assembling my own Dreadnought: For not too much extra $$, I ordered extra cable, techflex, and Neutrik connectors to make a longer SDA cable to use without the Dreadnought.
My thinking being that if I moved to a different set of SDAs down the road, I'd be able to sell my current ones with a working interconnect for the new person while keeping the Dreadnought for my next pair. (Additionally, if you're a glutton for punishment, you can A/B with/without the Dreadnought to hear its effects. I don't have the time for such exercises.)
Jay
Good idea, I was thinking that too after I pondered it a bit. That way when I do modify or replace my terminal cups I'm already 1/2 way there with Neutriks on the tranny end.
I am requesting one Dreadnought Case @ $100 including shipping.
Don't have info to use PayPal for payment ie email address.
(On Driver/Speaker rings, request one set SDA 1C's $70.64 with tweeter brackets $20)"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
I think those would work on the cable. They do have the higher amperage rating 40A continuous/50A music signal rating you'll want. I used 4-pole Neutrik (NLT4FX-BAG on the cables, NL4MP-UC on the transformer case). I liked the metal casing on the NLT4FX-BAG over the plastic on others.
A consideration is the fact that the NLT4FX-BAG has solder cups only (it was modestly challenging to solder) rather than the "solderable" connections with screw terminals in the ones you linked. I believe solder is preferred for higher current applications; frankly I have no idea what kind of current goes thru these SDA cables.
You want the "D" size chassis mounts to fit Larry's chassis (oh that sounds so wrong), and you'll want the ones with higher amperage rating as well (The NL4MP-UC fits this bill). I also bought Neutrik's SCDP gaskets.
Hopefully Jesse comes by to concur with what I've said/suggested here. I followed his lead in constructing my cables. (With considerably less expensive cable
This isn't the only solution, but it's what I used:
My cable connectors
My Chassis connectors
My GasketsJay
Going to need one. Please send payment information.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I'm talking with Vr3 mods and will probably get his custom terminal cups and go all Neutrik.
Thanks for the part numbers and explanation.
Someone really should write up a comprehensive DIY with part numbers, etc. had no idea there are so many choices.
Jay nailed it.Political Correctness'.........defined
Is the Neutrik rubber gasket necessary on the transformer chassis? That's another $20+
Brock, I think I found a deal when I did mine--I may have ordered a set in blue as well. If I can find them (and you can deal with blue gaskets) I'll send them to you [ i ]gratis[ /i].
Jay
I just looked at Parts Express they are wayyyy cheaper than Amazon on everything. 50% cheaper on the entire purchase so I can get the gaskets from them. Gaskets are $2.38 at PE and $9.49 at Amazon, WTF!
That's why I didn't want to spend the extra $20, but I can do $5......lol"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
May I ask what this case is for? Sorry for my ingnorance.Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
Stuff laying around. Too much to list but don't want to sell either. -
dalylaleahthor wrote: »May I ask what this case is for? Sorry for my ingnorance.
Dreadnought for SDA speakers.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Put me in for a case as wellThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I need one also, thanks
SDA SRS 2.3tls; RDO 198's, Dynamatted, Armaflexed, Gimpod Boards, Crossovers by quadzilla: Clarity ESA 630V, Mills Resistors, Track Audio Spikes, Musky's Curly Maple Caps
CSi5, FXi5, Rythmik D15SE sub, Pro-Ject Xpression III/Ortofon MC-3 Turbo. Pro-Ject Speed Box. Pro-Ject Tube Box II -
Ok. Thanks.Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
If you have paid, it's shipping today..
