New Amplifier In The House!
  • kharp1
    kharp1 Posts: 3,453
    I'm +1 on the Joule Electra. Was blown away by the height, depth and warmth it added.
  • halo
    halo Posts: 5,619
    edited January 2017
    Congrats on the "new" amp!
    Ya, it's the journey that counts. lol. I enjoyed the Jolida Fusion preamp I had here and it is well within your budget (pre-owned). You can probably pick up a separate phono pre and some nice NOS tubes up to your budget.
    I had a pre-owned VTL 2.5 as well and it was a fabulous piece of equipment but it's a bit out of your stated budget.
    Good luck with the search!
    You don't have that VTL 2.5 anymore ? WTF man, that's a nice pre.
  • halo
    halo Posts: 5,619
    tonyb wrote: »
    Nope. That 2.5 went to a fellow Polkie in '08 or '09 but I agree, it was a nice pre!
  • nspindel
    nspindel Posts: 5,343
    I had my Krell KAV-2250 paired up with a Dared MC-7P, results were super. Definitely warmed things up a lot.
  • erniejade
    erniejade Posts: 6,321
    Do you still have the Dared 2000?
  • hochpt21
    hochpt21 Posts: 5,423
    erniejade wrote: »
    Yes, that is what I'm using now. I've switched my signature below so you can see what I'm currently running. I may end up keeping the Dared in the system for awhile, until I find a nice deal on a nicer tubed pre. Getting some really good TFK 5965's to put in it. The Psvane's in there now actually sound really good also.
  • erniejade
    Its a good unit. I think it should mate well with the Amp.
  • RamZet
    RamZet Posts: 792
    edited January 2017
    When it quits on you its just the power supply.
    -From a Krell dealer
    B&W CM9Classé Sigma
