New Subwoofer Prospects
papatom
papatom Posts: 137
edited December 2016 in Speakers
Greetings all and Happy Holidays!
My current setup is:
Polk Signature S55 Fronts
Polk Signature S35 Center
Polk Signature S15 Surrounds
Velodyne DPS-10 Subwoofer
Room dimensions are 17x20 and 7' high. Budget is no more than $800 or so.
My Velodyne DPS-10 is going on 12 years old in the coming months. Ever since we moved into the new house last year, I'm unsure if my sub has what it takes to fill my room since its dramatically bigger than the room in my old house. In addition, I've been having some flaky issues with the amplifier on it; sometimes it doesn't turn on, turns off on it's own, etc. I've been looking at SVS and had my eye on the PB-2000 OR...I'll bite the bullet and possibly do dual PB-1000's. I would like to know, if anyone with experience with either of these subs can tell if I'm on the right track of thinking with this.
Obviously, I'm looking for improved bass/sound compared to what I have and to properly fill the room. Also, if someone could tell me the difference between ported and non-ported; what's the benefits, pros/cons, etc. that would be helpful!
Many, many thanks to everyone!
Marantz SR5011 / Polk Audio Signature S55 towers / Polk Audio Signature S35 Center/ Polk Audio Signature S15 surrounds / Velodyne DPS-10 / Samsung 60" KS8000 / Samsung UBD-K8500
  • Well like I've been saying all over this forum (*which is essentially echoing what they are saying in the HI-Fi rags*)
    Two (*or more if possible*) smaller subs can do a far better job of spreading the bass out evenly in the room than one big one.
  • rpf65
    rpf65 Posts: 2,127
    I would go for the PB-2000. In six months you'll find some excuse for a second one
  • papatom
    papatom Posts: 137
    If I were to buy a PB-2000, wife would not let me get a 2nd one...guarantee that lol.
  • Willow
    Willow Posts: 11,245
    Then get the 16" if only one ;)
  • papatom
    papatom Posts: 137
    Willow wrote: »
    Haha, I wish. That would probably be way overkill, plus wife wouldn't allow me to spend that much.
  • mikeyb128
    mikeyb128 Posts: 2,885
    papatom wrote: »
    Willow wrote: »
    No such thing.
    2 channel:
    Theater:
    txcoastal1 Posts: 13,518
    Better to ask for forgiveness than permission....you can blame it on me and Club Polk :)
  • Joey_V
    Joey_V Posts: 8,603
    B stock svs sb13u... Take advantage of all the people who traded it for the 16.
  • polrbehr
    polrbehr Posts: 2,846
    Don't discount Polk DSW550 subs, they perform well above their price point, and you can get 2 of them with your budget.
  • papatom
    papatom Posts: 137
    polrbehr wrote: »
    I saw those, but figured people would scald me for mentioning anythung ither than svs, hsu, etc., lol.
    But it is an attractive sub.
    F1nut Posts: 51,912
    It appears you want this for HT, so you would likely be happier with a ported sub. A single DSW660 will do the job as your room really isn't that big.
  • I have a small living room and an even smaller bedroom and I use two Polk subs in each.It isn't just MORE bass,it's BETTER bass that I get using more than one.
    pitdogg2 Posts: 27,190
    Depending on the configuration they can be used to cancel or enhance certain frequencies which does make mo'better. I run two in opposite corners of my 12×15 room. 1 Cerwin Vega CVT 300 15" and 1 CV CVT 200 12". 15" ran as LFE. And the 12" in the rear for rear surround bass.
  • mikeyb128
    I ran two dsw500's for home theater and they were awesome for the money. One of polks best subs.
    2 channel:
    Theater:
  • polrbehr
    Honestly, I think even 1 DSW550 would be fine - I can still vividly recall how much output that had in a basement HT. But since the OP mentioned getting two, I figured they were now $399 each it would fit his $800 budget.
  • GlennDog
    GlennDog Posts: 3,153
    I've got a Salk 12 incher on the way . . . Cannot wait, and prolly gonna roll with 2 when I realize 1 is not enough!!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Thorton
    Thorton Posts: 1,324
    GlennDog wrote: »
    Personally, I would just order two now. It's not that one is not enough but it's just so much easier incorporating two for overall output and seamless integration with the mains. How large is the room? Can't go wrong with Salk and Rythmik.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • GlennDog
    Thorton, that's my conundrum
    The room is not that large, maybe 19 x 13 w/8 foot ceilings with three hallways
    I'm thinking with the 3 hallways, that's my gateway to the second sub
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • Thorton
    I know exactly what you're talking about. That's not too big of a room. 1 - 12" may be enough. It all comes down to placement and the room itself. Are you using any room acoustic software to aid in the integration? If not, I highly recommend it. You can get there by ear alone but the software definitely speeds up the process and confirms your hearing for perfect integration.
    DAC: Bricasti M1SE
  • papatom
    papatom Posts: 137
    Thorton wrote: »
    Do you know of any good room acoustic software to use? I've never used any, but always a first for everything!
  • Thorton
    I use REW. It's a free download from the REW site or Hometheater shack. You'll need to buy a calibrated mic for about $100 and use your laptop. There is a learning curve for this. However, there is an abundance of information on how to measure/set-up and use/analyze this software correctly. A number of people use it on this forum. I believe a few people also use Omnimic which is around $300. XTZ is another for around $330.
    These type of software's greatly assist setting up speaker and subwoofer locations in addition to when you add acoustic treatments.
    DAC: Bricasti M1SE
  • GlennDog
    My Integra pre/pro has Audyssey MultiEQ . . . I'll start with that and see if that blends the sound well
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • halo
    halo Posts: 5,618
    The last sub I had that effortlessly filled my HT needs was an SVS 20-39 PCi. If it were me, I would look into a PC-2000: https://www.svsound.com/collections/outlet-specials/products/pc-2000-black-ash-vinyl-outlet
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
  • WLDock
    WLDock Posts: 3,073
  • mrloren
    mrloren Posts: 2,474
    I heard years ago that HSU was behind the outlaw subs
  • gp4jesus
    gp4jesus Posts: 2,019
    mrloren wrote: »
    They had a hand in the design
    *all connected w/Premiere ICs
  • papatom
    papatom Posts: 137
    I don't know about you guys, but I believe things happen and occur for a reason.
    I was watching TRON: Legacy last night and noticed two things with my Velodyne...
    1. I hear a buzzing noise coming from it and 2. I hear a "chattering" noise from somewhere within the cabinet. Remember, this thing is over 11 years old so I have a feeling that it's starting to approach its last leg.
    I've been reading all of your comments and digesting it all. I love hearing suggestions, opinions, etc. and I know at the end of the day - it's all what I like to hear. I think I'm going to order the two PB-1000s' and the one PB-2000 and see which plays better with my system. Start from there. I have friends that use SVS subs and can swear up and down on them and hail them as the best things since sliced bread.
  • papatom
    papatom Posts: 137
    Also one more question - what is the real difference between a ported sub vs. sealed sub? Do you use one or the other based upon specific needs or room configurations?
    Many thanks!
  • voltz
    voltz Posts: 5,384
  • papatom
    papatom Posts: 137
    voltz wrote: »
    Thank you!
