Wel wel wel part 2: xlr or power cord?
Joey_V
Joey_V Posts: 8,600
edited November 2016 in 2 Channel Audio
Which matters more? The xlr pair or a pair of power cords?
Both will be audioquest's best WEL series wiring.
The guy I bought my Wel signature speaker wire has just emailed me out of the blue and offered either or both.
Seeing as we are all on a budget, I can only buy 1 set.
I have tried the aq nrg10 PC in my system and the difference was quite impressive, nearly equal of the AQ Oak speaker wire.
So what say you?
2 power cords or 1 pair xlr?
The retail and used price is about the same.
  • kharp1
    kharp1 Posts: 3,453
    XLR. I've been going back and forth between the Wireworld Equinox 7 Silver and a pair of Signal Plus XLR on both the Marsh and Aleph, and, there is noticeable difference between the two. Mainly, gain is improved with XLR. That could set off another set of issues, however, with your components I doubt it. I, however, have no experience with this level of cabling or power cords. Just my 2 cents.
    Get both. Just do it. You know you want to, you know it's a great deal, and, you know you have a significant other that is somewhat pliable. Just do it.
    Tis much better to beg forgiveness than ask permission.
  • lightman1
    lightman1 Posts: 10,796
    Depends. Do you want a signature sound from source to pre? Or something that might give you a silent background to help you and only you decide which of those cables sounds better after that. <3
    F1nut Posts: 51,770
    Get the IC's since you already have the speaker cables. They'll work best together. You can always get some power cords down the road, but get some from a company that is known for their power products.
  • Joey_V
    Joey_V Posts: 8,600
    I have been reading the opposite, that the power cords are more important than the IC.
    Seems like AQ responses go Speaker wire then Power cords then IC.
    Not sure if it's because IC carries low level signals, while power cords bring in the meat.
    All I know is when I popped out the stocks out of my system and popped in the NRG10 (which are $480), the system just jumped. I assume that the WEL being maximum of AQ NRG should yield a considerable jump.
    I wasnt planning on spending more money on cabling this early
  • mrbiron
    mrbiron Posts: 5,721
    This year?
    That means wait 5 weeks and your conscience can be cleansed.
    Stick with the NRGS for now and go IC. Then, in 5 weeks from then, the seller will contact you for a third time....
    On the 4th, he offers you his beautiful virgin daughter that might have an already paid for college tuition. :p
  • Joey_V
    Joey_V Posts: 8,600
    mrbiron wrote: »
    This year?
    Always the funny guy eh?? hahaha
  • ICs have always made a bigger difference than power cords in my systems. The degree of improvements you receive from power cords (and other power quality enhancements) will depend on several things:
    1. The quality of the power from the utility company.
    2. Whether or not your audio gear is on a dedicated ac circuit (or multiple ac circuits).
    3. The quality of the power supplies in your gear.
    Some people found that a dedicated ac circuit (typical $400 - $500) yielded more improvement than an audio grade power cord. This is particularly true for power amps. High performance power cords provide a little bit of noise filtering, but first reducing the amount of noise in the power line yields better results (and usually for less money).
    I second F1's suggestion to buy power cords from a company known for their power products. I use AudioQuest's ICs and speaker cables, but they came late to the game in power products and power is not really their forte.
  • gp4jesus
    gp4jesus Posts: 2,019
    Get the XLRs
    on a scale of 1-10 about 3 on a good day, -1 on a bad one.
    mine is on 3. Two 20As & one 15A protected by an APC H15
    3.The quality of the power supplies in your gear.
    ??? but I'm sure you're right.
    $400-$500?! Mine $ me less than $75 (wire & outlets). What am I missin'?
    *all connected w/Premiere ICs
  • BlueFox
    BlueFox Posts: 15,251
    For what it is worth, I have found power (cables, conditioners, dedicated lines) gave me the biggest WTF moments. That might be because I had the ICs in place before going berserk on power.
  • gp4jesus wrote: »
    I gauge power quality in terms of voltage stability over a typical 24 hour period and in terms of the total harmonic distortion. THD of 2.5% is national average. Voltage should stay in the range of 119v-125v.
    gp4jesus wrote: »
    Home theater is on two 20As. Two Channel is on three 20As.
    gp4jesus wrote: »
    I was referring to the ability of a component's power supply to filter out power line noise.
    [/quote]
    The price range I quoted was for an electrician install. Most people aren't going to run wire from the breaker panel, fish wire through the walls, and install outlets, and most
    electricians aren't going to install an outlet for less than $75
  • Joey_V
    Joey_V Posts: 8,600
    Well... XLR got bought from under me.
    Couldn't pull the trigger on the XLR. I guess it wasn't meant to be.
    tonyb Posts: 33,072
    Snooze ya lose Joey.....personally I would have taken them over the power cord. Too hard to find matching IC's especially on the used markets.
  • Joey_V
    Joey_V Posts: 8,600
    tonyb wrote: »
    Yeah I was about to do both sets actually.
    But I just didn't want to spend that much just yet as the xlr are twice as expensive as the power cords
    I regret not buying the xlr and biting the bullet but I waffles and I have to deal
    With the consequences.
    I'll have first dibs on future wel sales from
    This guy because he has a full loom.
    Maybe I'll be ready next time.
    But... I put a depo on the power cords!!!
    Good
    Enough for me!
    Nrg10 blew my mind as to the effect of power cords. This being the nrg wel... Should be superb.
    Now where's that PayPal button to complete the sale?
  • lightman1
    They have different colors to suit your decor.
    Post edited by lightman1 on
  • Joey_V
    Joey_V Posts: 8,600
    lightman1 wrote: »
    They have different colors to suit your devor.
    Don't be a jerk Russ haha
    tonyb Posts: 33,072
    LOL....be nice Russ, you know how long it took us to convince Joey cables matter. I'm at least glad to see the cabling is now living up to the rest of the gear. If he still had monster garbage hooked up to that Boulder, you and I would have to pay him a visit, southern style.....with 2 by 4's in hand. lol
  • lightman1
    Just say the word, Tony.....
    Next step is talking him into some dedicated circuits.
  • Joey_V
    Joey_V Posts: 8,600
    lightman1 wrote: »
    Already got a few.
    But I am already planning the real room.
    10g ROMEX electrical wiring, dedicated fuse box, 6 dedicated 20 amp outlets. Furutech outlets.
    It's going to be killer.
    Everything I did wrong, I'm going to do right.
    The next room, I'm going to unleash.
    I held back too much.
  • Joey_V
    Joey_V Posts: 8,600
    tonyb wrote: »
    You seem like the violent type.
    tonyb Posts: 33,072
    Joey_V wrote: »
    tonyb wrote: »
    Who...me ?
    Nah....I just subscribe to the old saying of speak softly and carry a big stick. lol
    Least you scooped up the PC, now it's just a matter of watching and waiting for more IC's to surface.
  • Joey_V
    Joey_V Posts: 8,600
    tonyb wrote: »
    Joey_V wrote: »
    tonyb wrote: »
    Who...me ?
    Yeah just paid for it.
    2x PC.
    Ouch
  • @DarqueKnight
    I'm in the process of setting up a 2 channel rig and thinking of running 2 20 amp dedicated circuits at the most. What do you have connected to these 3 20 amp circuits?
  • BlueFox
    I suspect DK is similar to mine, a circuit for each amp, and one for the source gear.
  • Then I should be golden with 2 since I'm not running mono's?
  • footwedge wrote: »
    @DarqueKnight
    Bluefox is correct. I have a 20A circuit for each monoblock power amp, both of which are terminated with a PS Audio Soloist SE in-wall passive power conditioner. The power amp circuits are on separate legs of the breaker panel. The third 20A circuit feeds the source components and preamplifiers. That circuit is also terminated with a PS Audio Soloist SE in-wall passive power conditioner. Also on the third 20A circuit is a PS Audio P10 ac regenerator between the Soloist and the components. Power cords are PS Audio AC12.
  • Joey_V
    Joey_V Posts: 8,600
    I would use a single outlet for each plug.
    If I have monoblocks I will need 2 dedicated outlets. The preamp and source go into each. That makes 4.
    I'm sure there are more. Phono. TT.
    If your source is a transport + dac that's 2.
  • rpf65
    rpf65 Posts: 2,127
    Why would you plug your sources directly into an outlet? You should be plugging them into a surge protecror/conditioner, or better yet a regenerator.
  • BlueFox
    The source gear should be plugged into a Shunyata Denali. You can thank me later. If you feel like spending money then each amp should be plugged into its own 2 port Denali, but it is worth it if you want maximum performance from your gear.
  • Joey_V
    Joey_V Posts: 8,600
    rpf65 wrote: »
    Into an outlet means the whole unit, conditioner or other.
