SDA
245678
  • HzTweaker
    HzTweaker Posts: 988
    A compact sub/sat system could be done easily too.
    They could easily make a sub sat version based on something like the Blackstone line with ring tweeters that would be both affordable and meet WAF. The mains could actually be quite small if they don't have to go below 80hz. Dual 8-10 inch high quality/power subs to complete the SDA SubSat would be sweet.
    More speakers= Better, or Bigger speaker cabs= better (for a large market)? I say SDAs in modern tower form. Something sleek but far from anemic.
  • PolkieMan
    PolkieMan Posts: 2,446
    Well I think F1 nut took the words right out of my mouth. You need room for them but any speaker that is going to try to represent realistic live or studio music is going to be of a noticeable size and nothing does it properly like SDA's, besides the 2B's aren't "that large".
  • DaveHo
    DaveHo Posts: 3,582
    SDA effect depends on the dimensional woofer being roughly a head's width apart from the other driver on the horizontal plane. How do you accomplish that in a skinny tower?
    pitdogg2 Posts: 27,136
    blasphemy
  • For SDA's, nothing compares to the sound stage they create.
    I think you could do a sub/satellite system or a tower system that isn't as bulky as those in the past would probably be more acceptable to folks today. I think it's possible to do that as well.
    Personally, I think you could make something sleek like Anthony Gallo's reference 3.5 speakers or the equivalent satellites that he has. I've always thought those speakers were amazing sounding as well.
    For the 3.5's, just rotate the mid drive section 90 degrees (see satellites below for a better image), wire for SDA and I think you would have something pretty sweet.
    The satellites, just wire for SDA and you should have something that would work.
    I know there are some requirements around spacing of the drivers being a certain distance apart (ear to ear on a human head right?). Just make sure that is the case and I think speakers looking something like that would be phenomenal.
    Just my opinion though.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
  • mikeyb128
    mikeyb128 Posts: 2,885
    My question is, why haven't any other manufacturers used sda tech in their speakers? I'm trying to wrap my head around it, as sdas have a cult following. Is there some patent law preventing anyone from doing this?
    2 channel:
    Theater:
  • There are several other digital implementations of crosstalk cancellation out there, carver had theirs, ambiophonics, plus the newer BACCH filter. I would think in this day and age a digital version would be more effective and easier to setup as you wouldn't need the second driver. That being said, I think a lot of folks wouldn't like the idea of having to throw their audio through another ADA phase.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
    mikeyb128 wrote: »
    ummm yea a patent is the likely culprit...and others have done it Carver sonic holography is one. Difference is Bob's was electronic not passive. SDA type tech lives today in soundbars and yes many are doing it.
    F1nut Posts: 51,866
    No doubt, passive SDA works the best.
  • westmassguy
    westmassguy Posts: 6,850
    blasphemy
    Not if done properly. Think mini CRS+, with a quality sub.
    DaveHo wrote: »
    You could do an MTM/d'appolito arrangement, with some type of module either molded in as part of the enclosure, or hanging off the side. Think mini SRS-3.1tl
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • D2Lo
    D2Lo Posts: 352
    mikeyb128 wrote: »
    Highly patented with lots of IP around it.
  • D2Lo
    D2Lo Posts: 352
    actually there are some really cool things we can do with SDA when we control the source and the amplification.... how do I know this? We are playing with some stuff... the technology is really interesting at small scale as well as full scale towers.
    Width is always an issue as pointed out earlier. For a full analog set up to work properly the distance between the centers of the drivers has to be about 6 inches.... so the cabinet gets wide quick even if you do pincushion baskets and do an external driver mount to minimize the sides... like I said, how do I know this... we are playing with stuff. Always, it is what we do. With powered SDA arrays you can get the drivers closer because you can simulate the distance with delays and other fun stuff.... it has to work in an analog set up though to do some of the things we want so we are working on the width issue. it takes time and experimentation. It is really fun working with Stu on this stuff.
    At the end of the day maybe nothing will come of it, but I thought it was worth getting your opinions on the pros and cons of the technology. The forums are a unique place and I like to get your feedback on things when possible. Of course design is not a democracy, so at some point we have to do what we thing will be best. In every company I've ever worked in less than half of the projects in R&D ever come out. It is the nature of new product development and innovation. I like to think in terms of having an innovation surplus. A tree doesn't make the exact number of leaves it needs, it makes many more than that, and at the end of every year it heads them and then sprouts new ones. New product ideas are kind of like that.
    Friday deep thoughts.... but always good to have fun with engineers!wji3t1kpo9ry.jpeg
  • Female engineer's are hot.
    – Kevin Alfred Strom
  • Conradicles
    Conradicles Posts: 6,354
    Narrow towers are for girls.
    F1nut Posts: 51,866
    White lab coats.......nice touch.
    Somebody needs to clean those SRT towers.
    F1nut Posts: 51,866
    I think it's best to leave the signal as unmolested as possible. Audiophiles in general do not like DSP. Being passive was the beauty of the original SDA.
    Toolfan66 Posts: 18,117
    I thought girls liked girth and length?? No?? LOL...
  • PolkieMan
    And it is the simplest for the consumer to setup, one extra wire that's it.
  • I read this whole thread and as an avid SDA fan for many years believe "YES" the series should be resurrected all new cabinets.New style, but by all means keep the faith as in driver/passive combo, similar but better c/o, better tweeter you get it. B)
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • xsmi
    xsmi Posts: 1,804
    Me? I'd like to see a speaker about the height of the 707's (around the same height as my SRS 2's) priced a little higher. They would HAVE to be a wider cabinet because of the speakers in a side by side arrangement. I remember Ben and a few other old timers were throwing around ideas about a more modern 1.2TL. Although we in the forum may not have the expertise, I'm sure your engineers do. I really think Polk SHOULD make this happen. I'd find a way to buy a pair.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • hochpt21
    hochpt21 Posts: 5,423
    Do a new SDA.
    It would be a huge marketing tool tying the respected old school with the current new school. All the old rags would be forced to have an opinion on the subject. Peaking interest from the wealthier (in theory) older generation, and in turn the younger generation would follow suit.
  • Strong Bad
    Strong Bad Posts: 4,278
    When I still had my 2 channel rig setup, I used my pair of LSi 25's with a Carver C9 Sonic Hologram Generator in the mix. It added that touch of SDA to it. It wasn't classic Polk SDA, but I did quite enjoy it.
    This thread and talk does make me go...hmmm.
    No excuses!
  • Strong Bad
    hochpt21 wrote: »
    Do a new SDA.
    Back when the SDA line was still sold, I didn't have close to the budget needed to afford a pair. Today is a much different story.
    No excuses!
  • xsmi
    xsmi Posts: 1,804
    As a matter of fact, remember late in the 1.2TL's run, I went to an audio store and was talking to a customer and salesman about SDA and they were both of the opinion that the 1.2TL weren't audiophile speakers because of the interconnect cable. They felt it was just another piece to add voice to the chain.
    F1nut Posts: 51,866
    They didn't know much about audio.
  • xsmi
    xsmi Posts: 1,804
    LMAO!! Sometimes you just tickle me!
    edited September 2016
    xsmi wrote: »
    Funny thing is is he's correct. You now how many times I went into so called audiophile store and they had them set up completely wrong? Many times I seen them demo'd toed in like every other speaker. I never like them because of that. Then one day a friend was telling me about these speakers he just picked for a song. Low and behold the big boys set up correctly I knew at that point I was going to get some SDA's. So it took 20yrs but it was worth the wait.
  • pkquat
    pkquat Posts: 748
    The pros have all been listed. The main con, I have to say is room / location because of reflections. The width of the room can be tough. I noticed reflections and odd sounds more from my 1Cs than from Polk speakers placed wider than the 1Cs. Narrowing the 1Cs width and keeping a window curtain closed took care of the reflections. Other speakers can work in narrower widths and even be corner placed.
    I like the idea of a sat sub. I think you may be able tp get the effect with a narrower width. I also have one other idea, I'll PM about.
    I happened to stumble across this thread as I was thinking about SDAs and a question I'll ask after the holidays. One of the thing I'll mention now is old vs. new. There is something about the sound of the vintage 6.5" driver. It's pleasing. I am not sure if its nostalgia, preference, or ears that have become accustomed to the sound. With all the technology, and other developement, why do these still work so well?
    F1nut Posts: 51,866
    You just can't beat doped paper cones, very natural sound.
  • tat
    tat Posts: 159
    I agree but I havent gone crazy listening to 30k speakers. I love the sound of paper being driven hard. I think the good electrostatics could be said to "beat" the paper in ways in midrange but not for bass thump obviously.
    The advantage of SDA's is largely dependent on the source material and how it was mixed. I think most folks with SDA's have had a recording playing when suddenly we are struck with "what the heck is THIS song! I've never heard anything sound so glorious in my whole life!" lol The same song in your GM tape deck gets fast-forwarded right past.
    When freedom is outlawed, only outlaws are free...
