SDA
westmassguy wrote: »A compact sub/sat system could be done easily too.Dennis Gardner wrote: »They could easily make a sub sat version based on something like the Blackstone line with ring tweeters that would be both affordable and meet WAF. The mains could actually be quite small if they don't have to go below 80hz. Dual 8-10 inch high quality/power subs to complete the SDA SubSat would be sweet.
More speakers= Better, or Bigger speaker cabs= better (for a large market)? I say SDAs in modern tower form. Something sleek but far from anemic.2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
Well I think F1 nut took the words right out of my mouth. You need room for them but any speaker that is going to try to represent realistic live or studio music is going to be of a noticeable size and nothing does it properly like SDA's, besides the 2B's aren't "that large".POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
SDA effect depends on the dimensional woofer being roughly a head's width apart from the other driver on the horizontal plane. How do you accomplish that in a skinny tower?
blasphemy -
For SDA's, nothing compares to the sound stage they create.
I think you could do a sub/satellite system or a tower system that isn't as bulky as those in the past would probably be more acceptable to folks today. I think it's possible to do that as well.
Personally, I think you could make something sleek like Anthony Gallo's reference 3.5 speakers or the equivalent satellites that he has. I've always thought those speakers were amazing sounding as well.
For the 3.5's, just rotate the mid drive section 90 degrees (see satellites below for a better image), wire for SDA and I think you would have something pretty sweet.
The satellites, just wire for SDA and you should have something that would work.
I know there are some requirements around spacing of the drivers being a certain distance apart (ear to ear on a human head right?). Just make sure that is the case and I think speakers looking something like that would be phenomenal.
Just my opinion though.
Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Yamaha RX-V3800 Receiver
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable -
My question is, why haven't any other manufacturers used sda tech in their speakers? I'm trying to wrap my head around it, as sdas have a cult following. Is there some patent law preventing anyone from doing this?2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
There are several other digital implementations of crosstalk cancellation out there, carver had theirs, ambiophonics, plus the newer BACCH filter. I would think in this day and age a digital version would be more effective and easier to setup as you wouldn't need the second driver. That being said, I think a lot of folks wouldn't like the idea of having to throw their audio through another ADA phase.2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
ummm yea a patent is the likely culprit...and others have done it Carver sonic holography is one. Difference is Bob's was electronic not passive. SDA type tech lives today in soundbars and yes many are doing it. -
No doubt, passive SDA works the best.Political Correctness'.........defined
President of Club Polk -
blasphemy
Not if done properly. Think mini CRS+, with a quality sub.SDA effect depends on the dimensional woofer being roughly a head's width apart from the other driver on the horizontal plane. How do you accomplish that in a skinny tower?
You could do an MTM/d'appolito arrangement, with some type of module either molded in as part of the enclosure, or hanging off the side. Think mini SRS-3.1tl
Home Theater/2 Channel:
dhsspeakerservice.com/ -
Highly patented with lots of IP around it.
actually there are some really cool things we can do with SDA when we control the source and the amplification.... how do I know this? We are playing with some stuff... the technology is really interesting at small scale as well as full scale towers.No doubt, passive SDA works the best.
Width is always an issue as pointed out earlier. For a full analog set up to work properly the distance between the centers of the drivers has to be about 6 inches.... so the cabinet gets wide quick even if you do pincushion baskets and do an external driver mount to minimize the sides... like I said, how do I know this... we are playing with stuff. Always, it is what we do. With powered SDA arrays you can get the drivers closer because you can simulate the distance with delays and other fun stuff.... it has to work in an analog set up though to do some of the things we want so we are working on the width issue. it takes time and experimentation. It is really fun working with Stu on this stuff.
At the end of the day maybe nothing will come of it, but I thought it was worth getting your opinions on the pros and cons of the technology. The forums are a unique place and I like to get your feedback on things when possible. Of course design is not a democracy, so at some point we have to do what we thing will be best. In every company I've ever worked in less than half of the projects in R&D ever come out. It is the nature of new product development and innovation. I like to think in terms of having an innovation surplus. A tree doesn't make the exact number of leaves it needs, it makes many more than that, and at the end of every year it heads them and then sprouts new ones. New product ideas are kind of like that.
Friday deep thoughts.... but always good to have fun with engineers!
Female engineer's are hot.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
Narrow towers are for girls.
White lab coats.......nice touch.
Somebody needs to clean those SRT towers.Political Correctness'.........defined
I think it's best to leave the signal as unmolested as possible. Audiophiles in general do not like DSP. Being passive was the beauty of the original SDA.Political Correctness'.........defined
Conradicles wrote: »Narrow towers are for girls.
I thought girls liked girth and length?? No?? LOL...
And it is the simplest for the consumer to setup, one extra wire that's it.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
I read this whole thread and as an avid SDA fan for many years believe "YES" the series should be resurrected all new cabinets.New style, but by all means keep the faith as in driver/passive combo, similar but better c/o, better tweeter you get it.
Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Me? I'd like to see a speaker about the height of the 707's (around the same height as my SRS 2's) priced a little higher. They would HAVE to be a wider cabinet because of the speakers in a side by side arrangement. I remember Ben and a few other old timers were throwing around ideas about a more modern 1.2TL. Although we in the forum may not have the expertise, I'm sure your engineers do. I really think Polk SHOULD make this happen. I'd find a way to buy a pair.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Do a new SDA.
It would be a huge marketing tool tying the respected old school with the current new school. All the old rags would be forced to have an opinion on the subject. Peaking interest from the wealthier (in theory) older generation, and in turn the younger generation would follow suit.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
When I still had my 2 channel rig setup, I used my pair of LSi 25's with a Carver C9 Sonic Hologram Generator in the mix. It added that touch of SDA to it. It wasn't classic Polk SDA, but I did quite enjoy it.
This thread and talk does make me go...hmmm.No excuses! -
Do a new SDA.
Back when the SDA line was still sold, I didn't have close to the budget needed to afford a pair. Today is a much different story.
No excuses! -
As a matter of fact, remember late in the 1.2TL's run, I went to an audio store and was talking to a customer and salesman about SDA and they were both of the opinion that the 1.2TL weren't audiophile speakers because of the interconnect cable. They felt it was just another piece to add voice to the chain.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
They didn't know much about audio.Political Correctness'.........defined
LMAO!! Sometimes you just tickle me!2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Funny thing is is he's correct. You now how many times I went into so called audiophile store and they had them set up completely wrong? Many times I seen them demo'd toed in like every other speaker. I never like them because of that. Then one day a friend was telling me about these speakers he just picked for a song. Low and behold the big boys set up correctly I knew at that point I was going to get some SDA's. So it took 20yrs but it was worth the wait.LMAO!! Sometimes you just tickle me!
The pros have all been listed. The main con, I have to say is room / location because of reflections. The width of the room can be tough. I noticed reflections and odd sounds more from my 1Cs than from Polk speakers placed wider than the 1Cs. Narrowing the 1Cs width and keeping a window curtain closed took care of the reflections. Other speakers can work in narrower widths and even be corner placed.
I like the idea of a sat sub. I think you may be able tp get the effect with a narrower width. I also have one other idea, I'll PM about.
I happened to stumble across this thread as I was thinking about SDAs and a question I'll ask after the holidays. One of the thing I'll mention now is old vs. new. There is something about the sound of the vintage 6.5" driver. It's pleasing. I am not sure if its nostalgia, preference, or ears that have become accustomed to the sound. With all the technology, and other developement, why do these still work so well? -
You just can't beat doped paper cones, very natural sound.Political Correctness'.........defined
I agree but I havent gone crazy listening to 30k speakers. I love the sound of paper being driven hard. I think the good electrostatics could be said to "beat" the paper in ways in midrange but not for bass thump obviously.
The advantage of SDA's is largely dependent on the source material and how it was mixed. I think most folks with SDA's have had a recording playing when suddenly we are struck with "what the heck is THIS song! I've never heard anything sound so glorious in my whole life!" lol The same song in your GM tape deck gets fast-forwarded right past.
When freedom is outlawed, only outlaws are free...
