2.3 TL high static/white noise from top tweet and some from tweet below
I really have no idea where to start. It's the right speaker only. Xovers were done by previous owner. I've never open these puppies up, but I guess I'm about to.
But not tonight, maybe in the next day or so after I get some feedback . . . For tonight I'll have to roll my Salks in
Don't get me wrong, I like rolling equipment. I just don't want to be forced to do it
Other than a loose connection, what are my first 2-3 things to look for?
TY !
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
  • agfrost
    agfrost Posts: 2,479
    Try a different pair of speakers to make sure it's the 2.3TL and not anything earlier in the chain?
    Jay
    F1nut Posts: 52,104
    Loose connection or cold solder joint.
  • lightman1
    lightman1 Posts: 10,797
    Bad music. Maybe boy bands. A good set of speakers have been known to commit hara-kiri when exposed to it.
  • GlennDog
    GlennDog Posts: 3,158
    edited July 2016
    The Salks are in and static is coming from the right ribbon!
    I checked the bias in both mono blocks and they're where they should be
    I guess I'll switch out the tubes in the preamp
    What's next gents?
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    txcoastal1 Posts: 13,519
    Flip each L/R source RCA and or preamp/amp till you narrow which piece of gear it follows...don't forget to power down each time
  • agfrost
    You might start switching speaker cables left-to-right, then interconnects as well, to see if one of them is the guilty party.
    Jay
  • GlennDog
    Thanks for all your help guys, but it turns out to be minor surgery
    Apparently, the tubes I recently acquired from the "RealGreatGreatSeller" from the Great White North are faulty
    I'll have to send back and get a refund. I hope he's cooperative
    On the upside, I'm really glad that the Polks don't require disassembly and the Salks sound fine
    Thanks again for your quick responses!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    Nope I think that was a little premature
    the static is coming back What the eff?..
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    Too much crazy stuff in too short of time. I'm gonna throttle back and post later
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • lightman1
    Recent tube change? Could be dirty pins.
  • GlennDog
    edited July 2016
    Yes, sir! It's a tube issue for sure . . . 12ax7 input tube in right side mono block
    (Too many changes in a short time, .... I owe GreatGreatSeller an apology)
    Not sure if it's defective or dirty pins, it was just delivered in the last week or so and pins were supposed to have been cleaned . . . . I'll be purchasing some de-oxit STAT
    Dag Nabit! These tiny Salks pack a mighty punch and sound eff'n great!!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • lightman1
    B) Keep on rockin' \m/
