Small Room LSi7 Rig
Conradicles
Very small room. LSi7 on some nice stands. No sub.
Looking at the Topping TP60 and the Topping D20 with a puter as the source.
Thoughts?
Thoughts?
Not enough juice IMHO bro..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Know nothing about Topping. I used Lsi7's in a small room with a 150wpc Carver receiver & it was amazing even without a sub. I was impressed with the bass too..
Randy/Maine -
EndersShadow wrote: »Not enough juice IMHO bro...
Really? 80 watts sitting a few feet away from the speaks? -
You can't be proud if you can't be loud, Eric....
Conradicles wrote: »EndersShadow wrote: »Not enough juice IMHO bro...
Didn't know they made one that powerful..... only ones I was familiar with were the flea watt amps....
I just dont know how much I trust that brand to do 80 watts....
But it looks interesting after some googling....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Watt are one thing but the LSi line tend to be a challenge to drive and need strong current capability to do them justice.Stan
Main 2ch:
HT:
Other stuff:
Agree with skrol...those 80wpc class T amps just don't have the peak to peak current swing that even the LSi7s require to get the best out of them.
You will get sound...but without a sub, they will struggle to dig deep enough for even satisfactory mid-bass let alone any solid lower range stuff."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
I'd definitely find something a little more musical and powerful. You'll even appreciate it at lower listening levels.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
agreedMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Agreed with the others. My brother has the 7s and they were originally powered by a 50 watt Rotel. After playing it a couple of hours, you could fry an egg on top of the amp. He now drives them with a Parasound 1500, and they sound great and the amp doesn't even get warm.
For a little speaker, it does do quite well with bass, but if there is a heavy bass line, things can get a little muddy between the bass and the midrange.
So I would up the power, and consider a small sub if you listen to a lot of music with bass in it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Agree with the others. 4 ohm load and not an easy one at that. I drove them with an Aragon 8008x3. They really shined with that amp.
If you could have snagged the Parasound hca1000a that was in the FM, I think that would have done them justice. -
This will have no issue with that 4 ohm load.http://nadelectronics.com/products/digital-music/D-3020-Hybrid-Digital-Amplifier#heading-reviews
Lots of good integrated amp choices. The NAD above seems like it would be nice. I once had a pair of those speakers and used a Cambridge Audio integrated, and it sounded great. I currently have a Marantz integrated that I also think could do the trick, although I've never run 4 ohm speakers with it.
I had LSi 7s and 9's. I loved the 7's with my Yaqin MC100B and the 9's sounded great with the Peachtree Nova 125SE.
There is a new nova 150. 150/250 wpc 4/8 ohms with a phono input.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
What size is your room? I'm in the process of setting up a 2 channel rig in 10x11room using the 7's too.
Very very small. 8 x 10 if memory serves me correctly. It will be interesting!
As you can see I own a set of LSi-7s I use in my office, along with other gear. I find it necessary to use the DefTech sub with them because even the HK 3490 cannot juice them enough in the lower register.
I had a chance to hear the Lsi-7s demoed in Beijing, several years ago, on a super powered GamuT amp (worth 1000s and 1000s), don't recall the model. I could NOT believe they were the same speakers. You amp these boys properly and they'll perform for you! But if not, roll in a good 8" sub. or better.
Back to WORK!Currently orbiting Bowie's Blackstar.!
Seems like this little guy could generate some current, but I don't know:
Honestly, those transformers are robust for a T amp but the storage capacity and the class T topography don't really allow for large current swings.
They would work wonderfully for some 8ohm highly efficient speakers but 4ohm speakers tend to rely more on high current/robust current swing capabilities over wattage."Some people find it easier to be conceited rather than correct."
