Small Room LSi7 Rig
Very small room. LSi7 on some nice stands. No sub.
Looking at the Topping TP60 and the Topping D20 with a puter as the source.
Thoughts?
    EndersShadow Posts: 17,534
    Not enough juice IMHO bro...
  • boston1450
    boston1450 Posts: 7,474
    Know nothing about Topping. I used Lsi7's in a small room with a 150wpc Carver receiver & it was amazing even without a sub. I was impressed with the bass too
    Randy/Maine
  • Conradicles
    Conradicles Posts: 6,042
    Really? 80 watts sitting a few feet away from the speaks?
  • lightman1
    lightman1 Posts: 10,776
    You can't be proud if you can't be loud, Eric....
    Didn't know they made one that powerful..... only ones I was familiar with were the flea watt amps....
    I just dont know how much I trust that brand to do 80 watts....
    But it looks interesting after some googling.....
  • skrol
    skrol Posts: 3,340
    Watt are one thing but the LSi line tend to be a challenge to drive and need strong current capability to do them justice.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Agree with skrol...those 80wpc class T amps just don't have the peak to peak current swing that even the LSi7s require to get the best out of them.
    You will get sound...but without a sub, they will struggle to dig deep enough for even satisfactory mid-bass let alone any solid lower range stuff.
    heiney9 Posts: 25,082
    I'd definitely find something a little more musical and powerful. You'll even appreciate it at lower listening levels.
  • Joey_V
    Joey_V Posts: 8,521
    heiney9 wrote: »
    agreed
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • cfrizz
    cfrizz Posts: 13,415
    Agreed with the others. My brother has the 7s and they were originally powered by a 50 watt Rotel. After playing it a couple of hours, you could fry an egg on top of the amp. He now drives them with a Parasound 1500, and they sound great and the amp doesn't even get warm.
    For a little speaker, it does do quite well with bass, but if there is a heavy bass line, things can get a little muddy between the bass and the midrange.
    So I would up the power, and consider a small sub if you listen to a lot of music with bass in it.
  • DaveHo
    DaveHo Posts: 3,481
    edited June 2016
    Agree with the others. 4 ohm load and not an easy one at that. I drove them with an Aragon 8008x3. They really shined with that amp.
    If you could have snagged the Parasound hca1000a that was in the FM, I think that would have done them justice.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Lots of good integrated amp choices. The NAD above seems like it would be nice. I once had a pair of those speakers and used a Cambridge Audio integrated, and it sounded great. I currently have a Marantz integrated that I also think could do the trick, although I've never run 4 ohm speakers with it.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited June 2016
    I had LSi 7s and 9's. I loved the 7's with my Yaqin MC100B and the 9's sounded great with the Peachtree Nova 125SE.
    There is a new nova 150. 150/250 wpc 4/8 ohms with a phono input.
    Garage | Polk Monitor 5B's
  • footwedge
    footwedge Posts: 475
    What size is your room? I'm in the process of setting up a 2 channel rig in 10x11room using the 7's too.
  • Conradicles
    footwedge wrote: »
    Very very small. 8 x 10 if memory serves me correctly. It will be interesting!
    As you can see I own a set of LSi-7s I use in my office, along with other gear. I find it necessary to use the DefTech sub with them because even the HK 3490 cannot juice them enough in the lower register.
    I had a chance to hear the Lsi-7s demoed in Beijing, several years ago, on a super powered GamuT amp (worth 1000s and 1000s), don't recall the model. I could NOT believe they were the same speakers. You amp these boys properly and they'll perform for you! But if not, roll in a good 8" sub. or better.
    Back to WORK!
  • Conradicles
    Seems like this little guy could generate some current, but I don't know:
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Honestly, those transformers are robust for a T amp but the storage capacity and the class T topography don't really allow for large current swings.
    They would work wonderfully for some 8ohm highly efficient speakers but 4ohm speakers tend to rely more on high current/robust current swing capabilities over wattage.
