RTI A7 Bi Amp Impedance / Resistance
Well, you certainly would be increasing the wire gauge, so give it a shot and let us know what you think.Political Correctness'.........defined
President of Club Polk -
But then you would be bringing your speakers in closer and possibly narrowing the soundstage. Thereby a possible change from the original soundstage could negate any diffence you may hear in the 5' parallel run.
Anybody? -
You could move your chair 5' to compensate.
Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
I did... ...about 15 years ago. Had a pair of dual 12" driver isobaric subs. Originally each connected w/ a single 10' run, one driver daisy chained (and soldered) to the other. Took several weeks, HOURS of listening, and a bunch of testing to dial them in.
Ohhhh I forgot to mention... ...I used 10 ga wire - calculated length resistance .01 ohms for 10 feet - important I think to mention. Anyway, "Al-ri-ght, they're dialed in." Listening bliss, right? Nope. What does a single tweak-a-holic do now?
Well I noticed I didn't really need 10' to connect them, so for fun I cut the wire in half. Then "Hey! I'll give each driver their OWN connection," (BI-WIRED!), soldering them at the driver end.
Now I have a new problem because they're LOUDER!! And I don't mean a teeny weeny bit louder either. Some testing and (a few less hours than before) of listening later, dialed in again.
For 15 years I've puzzled over why such a tiny change produced a big difference. What do I know: they were nominally 4 ohms w/a 3 ohm low point in their impedance curve and the "bi-wire" reduced the resistance a mere .0075 ohms.
Recently I had an "ah-ha" moment: each driver in an isobaric alignment presents a different load along w/different back EMF "characteristics" to the amp. I theorized those "characteristics' interfered with each other. Bi-wiring separated them.
Anyone got a better theory?Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Bi-wiring doesn't really separate them. Bi-amping would.Political Correctness'.........defined
You didn't read my post very carefully nor have a clue why they got louder.Bi-wiring doesn't separate them.
The "bi-wire' theory is just that, a theory. That's why I closed my post asking "Got a better theory?"
I used to think it was the resistance reduction until I resigned myself that .0075 ohms less resistance couldn't result in a 3-6dB increase in volume
So I ask again: anyone got a better explanation?Post edited by [Deleted User] onSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Resistance isn't everything.
A 3-6dB increase in volume? That's quite a bit. Perhaps something wasn't hooked up properly the first time.
One other thing, lose the attitude.
"I wish I said that." Oh... that's right, I did!Resistance isn't everything.
"I used to think it was the resistance reduction until I resigned myself that .0075 ohms less resistance couldn't result in a 3-6dB increase in volume"
...is an estimate. 3 dB is the smallest difference we can hear. I'm certain the diff was greater.A 3-6dB* increase* in volume?
Not a chance. During the "single run" stage of listening & testing I had taken apart & reassembled the TWO unsoldered connections several times.Perhaps something wasn't hooked up properly the first time.
A combative attitude isn't going to get you very far.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
No kidding, sorry I bothered.
What happened to your reading comprehension?Post edited by don0 on -
What happened to your spelling?2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »
What happened to your face? -
txcoastal1 wrote: »
txcoastal1 wrote: »
Too much time spent with Russman.
That's Billy Rayjimbob. F1 is Clyde. -
Was not talking to you, unless you are f1nut.
Would you like to buy a vowel?Political Correctness'.........defined
Are you serious? F1Nut was talking to gp4jesus. I believe it is your reading comprehension that's in question.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Did you know that I was not talking to you?
I know who f1nut was talking to but he misunderstood what was said about resistance.
He also knows why I made the comment about his readingcomprehension. He did the same thing that he accused me of, on one of gp4jesus's post above.
No dono, there's nothing wrong with my reading comprehension and if you knew anything about isobaric subs you would have known where I was going. In the meantime, stop embarrassing yourself.Political Correctness'.........defined
Trying to be a bada$$ fail.
You are absolutely correct about how an impedance change affects amp output and, ultimately, volume, everything else being equal....the hookup order on the subwoofers changed*. I suspect when you rewired them, the amp was presented with a lower ohm load, thereby drawing more power out of the amp. This should have roughly doubled the output.
A couple of side notes:
1. I neglected to mention earlier these subs were quasi DIY - home made based upon on a tried & true commercial design - the source of the impedance curve info.
2. I hard wired the speaker wires resulting in each having a 10' "tail" before and two 5' tails after the bi-wire.
3. Right after I put these in service I discovered the (dedicated) amp* ran significantly warmer at lower volumes than w/any others speakers at high volumes. I kept it* on a milk crate to enhance convection cooling. That didn't change after the bi-wire.
* using it in my home theatre today
Unfortunately for those so willing to help, I'm certain the drivers were paralleled before the bi wire. Due to the isobaric alignment I was VERY careful soldering the drivers the first time. I would have noticed the series wiring "mistake" during the bi-wire mod. Further, I regret not following MY protocol - rewiring one, listening to each "solo," then deciding to either rewire the other or reverse the former.
Thanks for your thoughts, Tony
You say the woofers are in an isobaric array. Are the woofers head to head, back to back or front to back? And did you wire one woofer in phase and the other out of phase in parallel?
Any of these configurations?
Front to front. Ext dimensions (LWH) 14" X 14" X ~42", 3 cu ft, to the best of my recollection.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Right on. And going back to the wiring at the terminals. Is one wired in phase and the other wired in reverse phase. (Out of phase)?
Sorry lightman1.
Unless you have a way to travel to the year 1991, month of May or June, Los Alamitos, CA, I can't say but...
I also forgot mention those were part of a 2 channel tri-amped system using 3 different brands of amps. Part of the challange of correctly setting up same includes checking each amp for phase inversion. Failing to do so makes for very disappointing SQ.
1991 wasn't my "first rodeo" in the world of bi & tri amped systems.
Thanks, TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
