RTI A7 Bi Amp Impedance / Resistance
124
    F1nut Posts: 51,799
    Well, you certainly would be increasing the wire gauge, so give it a shot and let us know what you think.
  • lightman1
    lightman1 Posts: 10,796
    gp4jesus wrote: »
    The only difference when bi-wiring is you are effectively increasing the wire gauge, which could be done with a single run as well.
    Suppose I cut the length in half (10' to 5') and take the (now) spare (5') piece and re-connect as double 5' run of 10 ga. Should I hear a difference?
    But then you would be bringing your speakers in closer and possibly narrowing the soundstage. Thereby a possible change from the original soundstage could negate any diffence you may hear in the 5' parallel run.
    Anybody?
  • gce
    gce Posts: 2,158
    You could move your chair 5' to compensate. :|
    Anaheim Hills CA,
  • gp4jesus
    gp4jesus Posts: 2,019
    I did... ...about 15 years ago. Had a pair of dual 12" driver isobaric subs. Originally each connected w/ a single 10' run, one driver daisy chained (and soldered) to the other. Took several weeks, HOURS of listening, and a bunch of testing to dial them in.
    Ohhhh I forgot to mention... ...I used 10 ga wire - calculated length resistance .01 ohms for 10 feet - important I think to mention. Anyway, "Al-ri-ght, they're dialed in." Listening bliss, right? Nope. What does a single tweak-a-holic do now?
    Well I noticed I didn't really need 10' to connect them, so for fun I cut the wire in half. Then "Hey! I'll give each driver their OWN connection," (BI-WIRED!), soldering them at the driver end.
    Now I have a new problem because they're LOUDER!! And I don't mean a teeny weeny bit louder either. Some testing and (a few less hours than before) of listening later, dialed in again.
    For 15 years I've puzzled over why such a tiny change produced a big difference. What do I know: they were nominally 4 ohms w/a 3 ohm low point in their impedance curve and the "bi-wire" reduced the resistance a mere .0075 ohms.
    Recently I had an "ah-ha" moment: each driver in an isobaric alignment presents a different load along w/different back EMF "characteristics" to the amp. I theorized those "characteristics' interfered with each other. Bi-wiring separated them.
    Anyone got a better theory?
    *all connected w/Premiere ICs
    F1nut Posts: 51,799
    Bi-wiring doesn't really separate them. Bi-amping would.
  • gp4jesus
    edited May 2016
    Bi-wiring doesn't separate them.
    You didn't read my post very carefully nor have a clue why they got louder.
    The "bi-wire' theory is just that, a theory. That's why I closed my post asking "Got a better theory?"
    I used to think it was the resistance reduction until I resigned myself that .0075 ohms less resistance couldn't result in a 3-6dB increase in volume
    So I ask again: anyone got a better explanation?
    F1nut Posts: 51,799
    edited May 2016
    Resistance isn't everything.
    A 3-6dB increase in volume? That's quite a bit. Perhaps something wasn't hooked up properly the first time.
    One other thing, lose the attitude.
  • gp4jesus
    edited May 2016
    "I wish I said that." Oh... that's right, I did!
    "I used to think it was the resistance reduction until I resigned myself that .0075 ohms less resistance couldn't result in a 3-6dB increase in volume"
    A 3-6dB* increase* in volume?
    ...is an estimate. 3 dB is the smallest difference we can hear. I'm certain the diff was greater.
    Not a chance. During the "single run" stage of listening & testing I had taken apart & reassembled the TWO unsoldered connections several times.
  • Nightfall
    Nightfall Posts: 10,084
    A combative attitude isn't going to get you very far.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,799
    No kidding, sorry I bothered.
    nooshinjohn Posts: 25,932
    Resistance is futile.
  • don0
    don0 Posts: 78
    edited May 2016
    What happened to your reading comprehension?
    Post edited by don0 on
    txcoastal1 Posts: 13,513
    don0 wrote: »
    What happened to your reading comprihension?
    What happened to your spelling?
  • lightman1
    txcoastal1 wrote: »
    don0 wrote: »
    What happened to your face?
    lightman1 wrote: »
    txcoastal1 wrote: »
    don0 wrote: »
    DSkip wrote: »
    lightman1 wrote: »
    txcoastal1 wrote: »
    don0 wrote: »
    Too much time spent with Russman.
    wait.jpg 109.2K
  • don0
    don0 Posts: 78
    txcoastal1 wrote: »
    don0 wrote: »
    Typo
    Was not talking to you, unless you are f1nut.
  • lightman1
    don0 wrote: »
    txcoastal1 wrote: »
    don0 wrote: »
    Typo
    That's Billy Rayjimbob. F1 is Clyde.
    F1nut Posts: 51,799
    edited May 2016
    Would you like to buy a vowel?
  • Nightfall
    don0 wrote: »
    txcoastal1 wrote: »
    don0 wrote: »
    Typo
    Are you serious? F1Nut was talking to gp4jesus. I believe it is your reading comprehension that's in question.
    afterburnt wrote: »
  • don0
    don0 Posts: 78
    edited May 2016
    Nightfall wrote: »
    don0 wrote: »
    txcoastal1 wrote: »
    don0 wrote: »
    Typo
    Did you know that I was not talking to you?
    I know who f1nut was talking to but he misunderstood what was said about resistance.
    He also knows why I made the comment about his readingcomprehension. He did the same thing that he accused me of, on one of gp4jesus's post above.
    F1nut Posts: 51,799
    No dono, there's nothing wrong with my reading comprehension and if you knew anything about isobaric subs you would have known where I was going. In the meantime, stop embarrassing yourself.
  • Nightfall
    lightman1 wrote: »
    Seizure?
    afterburnt wrote: »
  • lightman1
    Trying to be a bada$$ fail.
  • gp4jesus
    DSkip wrote: »
    ...the hookup order on the subwoofers changed*. I suspect when you rewired them, the amp was presented with a lower ohm load, thereby drawing more power out of the amp. This should have roughly doubled the output.
    You are absolutely correct about how an impedance change affects amp output and, ultimately, volume, everything else being equal.
    A couple of side notes:
    1. I neglected to mention earlier these subs were quasi DIY - home made based upon on a tried & true commercial design - the source of the impedance curve info.
    2. I hard wired the speaker wires resulting in each having a 10' "tail" before and two 5' tails after the bi-wire.
    3. Right after I put these in service I discovered the (dedicated) amp* ran significantly warmer at lower volumes than w/any others speakers at high volumes. I kept it* on a milk crate to enhance convection cooling. That didn't change after the bi-wire.
    * using it in my home theatre today
    Unfortunately for those so willing to help, I'm certain the drivers were paralleled before the bi wire. Due to the isobaric alignment I was VERY careful soldering the drivers the first time. I would have noticed the series wiring "mistake" during the bi-wire mod. Further, I regret not following MY protocol - rewiring one, listening to each "solo," then deciding to either rewire the other or reverse the former.
    Thanks for your thoughts, Tony
  • lightman1
    You say the woofers are in an isobaric array. Are the woofers head to head, back to back or front to back? And did you wire one woofer in phase and the other out of phase in parallel?
  • gp4jesus
    edited May 2016
    Front to front. Ext dimensions (LWH) 14" X 14" X ~42", 3 cu ft, to the best of my recollection.
  • lightman1
    Right on. And going back to the wiring at the terminals. Is one wired in phase and the other wired in reverse phase. (Out of phase)?
  • gp4jesus
    Sorry lightman1.
    Unless you have a way to travel to the year 1991, month of May or June, Los Alamitos, CA, I can't say but...
    I also forgot mention those were part of a 2 channel tri-amped system using 3 different brands of amps. Part of the challange of correctly setting up same includes checking each amp for phase inversion. Failing to do so makes for very disappointing SQ.
    1991 wasn't my "first rodeo" in the world of bi & tri amped systems.
    Thanks, Tony
