Marantz AVR
Irrenhaus
Irrenhaus Posts: 1,105
So the time has come to upgrade my Onkyo 709. The options I have now are the Marantz 6010 or if I wait a few weeks get the 7010 instead. Not sure if the wait is granted.
Comments welcome.
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Upstatemax
    Upstatemax Posts: 2,785
    I you think you might ever need or want the extra bump in power and extra channels, hold out for the 7010.
    gudnoyez Posts: 8,174
    Upstatemax wrote: »
    +1 hold out for the 7010
  • halo
    halo Posts: 5,618
    Can't go back on the purchase of the 6010 once you've made it. If the 7010 is offering a better feature set of things you're actually going to put to use, hold out for the higher end model. Getting the 7010, you'll likely have no regrets or, at the very least, lessen your chances for buyer's remorse.
